- Joined
- Sep 26, 2010
- Messages
- 9,807
Originally Posted by JP69
Originally Posted by MaximaGuy
Originally Posted by rooflessVW
It's a 2018 Mercedes. Why are you changing the differential oil? Leave it alone before you make things worse trying to fix something that isn't broken.
Changing the differential and x-case right after 10K miles is a best known method in my maintenance book
It's your money to burn, but you definitely do not need to do the rear or front differential early. On Mbworld forums changing differential fluid every 100,000 miles was deemed to be a safe and conservative schedule. I also think there is no benefit to changing transfer case fluid ahead of schedule. I would just follow the service intervals set forth in the owner's manual. The only exception is if you own AMG, then owner's manual recommends early change in differential fluids.
The vast majority of all axle wear occurs during the first 15K miles and since axles do not have pressurized oiling systems or filters, there is merit to changing the oil early. For example, look at the iron levels in the rear axle of my retired 2010 FX4--despite longer and longer runs, the iron per mile continues to drop and that is no coincidence.
