3.5 Ecoboost issues solved for 2018?
by JLTD - 12/11/19 08:30 PM
14 Grand Caravan Broken Exhaust Valve
by cptbarkey - 12/11/19 07:48 PM
Put the winter tires on the Impala today.
by JimPghPA - 12/11/19 07:31 PM
Chasing down a brake issue
by HawkeyeScott - 12/11/19 07:14 PM
Total Quartz 9000 Energy 5w40
by BurntMusic - 12/11/19 06:53 PM
Mazda 3 i-ACTIV AWD diagonal test
by buster - 12/11/19 05:35 PM
Tires or Toyota ABS
by ford46guy - 12/11/19 05:33 PM
RV chase straight out of the Movies
by KeithS_NW_Ohio - 12/11/19 04:56 PM
Will the octane change?
by Mar57 - 12/11/19 04:45 PM
DIY brake lines help
by LeakySeals - 12/11/19 04:20 PM
random misfire code but not missing
by bowlofturtle - 12/11/19 03:31 PM
Pressure washing Santa Fe clay tile
by henni - 12/11/19 02:55 PM
Confused. Mercon V or Dexron VI?
by AcadiaDave - 12/11/19 02:33 PM
Sooty Oil in Ford Focus
by RW1 - 12/11/19 02:27 PM
oil sample shelf life?
by novadude - 12/11/19 12:51 PM
whoa!!walmart ammo clearance
by joel95ex - 12/11/19 11:56 AM
Carpro Reset
by BeerCan - 12/11/19 10:46 AM
TyMillerfc, AcadiaDave, lmt1911, m14308, MyFirstNamePaul
70104 Registered Users
121 registered members (4WD, 69Torino, 2010Civic, 2009Edge, 77GrandPrix, 2002 Maxima SE, 6 invisible), 1,782 guests, and 31 spiders.
Topics298,598
Posts5,138,910
Members70,104
Most Online3,589
Nov 2nd, 2019
Page 782 of 838 1 781 782 783 838
Re: Post your latest oil change [Re: Superbuick96] #5128658 06/08/19 02:34 PM
B
beanoil Offline
B
2020 Toyota Sienna
500 miles
FF and factory Denso out.
NAPA 0w20 syn, Denso first time fit in.
5 ounces of LubeGard BioTech.
Yes I'm certain it did not need to be done, and that some may have chosen a different oil, or no additive.
This is one of the easiest changes I've ever done. I read many comments about the cartridge and cap design, and problems with them.
I see none of it. Removed small cap, push the drain tap in the bottom of the big cap, unscrew big cap holding filter, replace cartridge, re-assemble.
Re: Post your latest oil change [Re: Superbuick96] #5128703 06/08/19 04:02 PM
M
Merek Offline
M
[Linked Image]
2004 GMC Sierra w/ 5.3
112,321 miles
Out Pennzoil Platinum 5w30 AC Delco PF46 filter - used for 1 yr 5 months 3,942 miles
In Shell Rotella Gas Truck 5w30 AC Delco PF46 filter
Honestly didn't really need to change the oil just got tired of looking at the OLM which was dropping like crazy and down to 22% remaining, it was a good day to change oil and I wanted to give the Shell RGT a try. I have been using PP 5w30 in this truck for awhile now and would definitely go back to it which has served me well. I concur with everyone else that says the RGT is quieter and makes it run smoother, it also doesn't have that typical Rotella smell either. The old oil was seriously black which really surprised me for only having about 4k miles on it.
Re: Post your latest oil change [Re: Superbuick96] #5128734 06/08/19 05:08 PM
U
UncleDave Offline
U
Motorhome...
UD
[Linked Image]
Uncle Dave
Cat 3126/2 MB3500/Titan/RX400H/17 Ridgeline
700HP V10/ 725HP BBC/ Raptor 700/ KFX450/ YZ250/Onan 8K/ Cat3011C
Re: Post your latest oil change [Re: Superbuick96] #5128761 06/08/19 06:02 PM
T
ttamian83 Offline
T
2018 Hyundai Elantra SEL
9937 miles (2657 OCI)
Out: Dealer bulk 5W-30 synthetic blend and OEM filter/crush washer installed by The Hulk
In: Amsoil XL 5W-30 and OEM filter/crush washer
I let the dealership do one oil change because it was free. I've hated how the car responded to it, so took it out early and put the good stuff back in at a human torque.
2018 Hyundai Elantra SEL (Amsoil XL 5w-30 & Hyundai OEM filter)
Re: Post your latest oil change [Re: beanoil] #5128786 06/08/19 06:25 PM
caprice_2nv Offline
Originally Posted by beanoil
2020 Toyota Sienna
500 miles
M
When I worked in an Express lube I did lots of Toyota cartridge filters. They were only a pain when the previous person over tightened them.
If I bought a new vehicle ever I'd drain the factory fill as early as you did but probably no additive.
84 Olds Cutlass - 350 Olds
83 Chevy Caprice - 305 Sbc
79 Honda CX500
Re: Post your latest oil change [Re: Superbuick96] #5128825 06/08/19 07:19 PM
A
AlienBug Offline
A
2005 Ford Freestyle
179,000 miles
Out:
Motorcraft FL 820s
Motorcraft 5w-20
In:
Fram TG2
Motorcraft 5w20
Don
2005 Ford Freestyle SEL, 158k, Motorcraft 5w20 synblend, Motorcraft filter
2007 Ford Fusion SE 2.3l, 125k, Mobil 1 EP 0w20, Motorcraft filter
Re: Post your latest oil change [Re: AlienBug] #5128873 06/08/19 08:08 PM
O
OCDoiler Offline
O
2015 4Runner with 39,750 miles.
Implementing the 5 P's in all facets of life...
2018 Tundra
2015 4Runner
1998 Acura CL
Re: Post your latest oil change [Re: Superbuick96] #5129408 06/09/19 02:08 PM
P
PeterGreen Offline
P
2012 Acura TL 6MT
87608 miles
3744 since last OC
Out: 4 qts Pureplus 5W30 plus some Havoline 5W20 makeup oil
In: Mobil 1 5w30 Advanced full synthetic
also changed Fram Ultra filter with same (filter had two oil changes on it)
MM down to 15%
Re: Post your latest oil change [Re: Superbuick96] #5130254 06/10/19 11:59 AM
R
Red91 Offline
R
97 civic
1.6 4 banger
Out: castrol 5/30, fram core filter
In: Napa 5/20, Napa proselect filter
07 focus
2.0 4 banger
Out: unknown, service champ filter
In: Napa 5/20, Napa gold filter
05 Chevy Impala
3.4 V6
Pit crew QS 10/30
Re: Post your latest oil change [Re: Superbuick96] #5130547 06/10/19 04:30 PM
R
Red91 Offline
R
99 Camry solara
3.0 v6
Out: probably acdelco 5/30, Napa gold filter
In: Napa 5/30, Napa gold filter
05 Chevy Impala
3.4 V6
Pit crew QS 10/30
Re: Post your latest oil change [Re: Red91] #5130805 06/10/19 07:55 PM
Malo83 Offline
1983 Silverado 2wd
305ci
230,798 mi.
Out,
O'Rielly 20w50
STP S373 2qt filter
In,
Pennzoil High Mileage 10w40
STP S373 2qt filter
Re: Post your latest oil change [Re: Superbuick96] #5130902 06/10/19 09:23 PM
67lemans Offline
1997 jeep grand Cherokee
out whatever the PO had before and a car quest filter
in STP 10W40 and a super tech filter
http://www.southeastbinders.com/
88 f150 4.9 valvoline 5w30
08 jeep patriot oreilly's syn 5w20
Re: Post your latest oil change [Re: Superbuick96] #5131341 06/11/19 11:01 AM
T
ToyotaCorolla04 Offline
T
2016 Subaru Forester 2.5L
24,000 miles
Out:
Idemitsu 0W-20
Subara OEM Filter 15208AA15A
In:
M1 AFE 0W-20
This was my first DIY oil/filter change since buying the car and having the dealership do the first 3 complimentary changes.
Eager to monitor how the car behaves and feels about moving from the Idemitsu to M1 AFE...
Re: Post your latest oil change [Re: Superbuick96] #5131353 06/11/19 11:22 AM
Brian553 Online Content
Online Content
2017 Kia Rio EX, 1.6L Gamma
Out: 3qt Delvac 1300 15w40 + 0.5 qt Pennzoil Platinum High Mileage 5w20
Hours on oil: 103
Miles on oil: 4805
[email protected]: 72715
Off: Purolator ONE PL14459
Hours on filter: 207
Est. miles on filter: 9380
In: 3.5qt of 75% Delvac 1300 15w40 / 25% 0w-40 Mobil 1 Euro FS
On: Fram Ultra XG9688
Delvac 1300........Valvoline Maxlife FS ATF........Liquid Wrench
Mobil 1 HM..........Valvoline Asian AF..................Berryman's B12
Re: Post your latest oil change [Re: Superbuick96] #5131554 06/11/19 03:10 PM
P
Puckrobber Offline
P
1995 Mercury Cougar XR7 w/4.6L V8 at 57,828 miles.
OUT: 5 qts. of Motorcraft 5W-20 Syn-blend Oil and Motorcraft FL820 oil filter
IN: 5 qts. of Mobil 5000 10W-40 Conventional Oil and FRAM Extra Guard PH2 Oil Filter
First oil change on it since 2016. crzy Figured I'd go the "thickie" route, and give it a little extra for the warm Summer months. On the 12 mile drive back home, it drove smooth & quiet. Even had a little extra "oomph" to it.
2005 Ford Explorer AWD - 171,850 miles (Mobil Super 5000 5W-30)
2016 Nissan Altima S - 77,050 miles (Castrol Syn. 0W-20)
