Originally Posted by CompGUY
Originally Posted by Cujet
I've owned a few pressure washers. I've never had one do that. However, I never have any water in the hose of mine. As the hose is always stored empty.
Interesting the manual says to pull the trigger and let the air out befoe starting..
Yes you need to do that DO NOT run pump without bleeding air before start up.
The problem you believe you have their is no issue it's a high quality pump and is normal procedure for start up you will find it's no big deal.
