2020 Kia Forte Engine
by artbuc - 01/24/20 03:27 PM
Torn filter that's NOT a motorcraft.
by mpgo4th - 01/24/20 03:22 PM
K&N PS-1008 $3.36
by jayjr1105 - 01/24/20 03:14 PM
Forum notifications?
by jayjr1105 - 01/24/20 02:50 PM
Thinking about transmission cooler for Honda
by jayjr1105 - 01/24/20 02:26 PM
Goodyear Assurance Comfortred Touring
by Keystone - 01/24/20 02:03 PM
Honda Pilot OCI - Pennzoil Platinum
by Skier - 01/24/20 12:48 PM
cold radiator hose
by macdole99 - 01/24/20 12:43 PM
Orbital Buffer - Boat Detailing
by PontiacHO - 01/24/20 10:32 AM
Do bolt threads grab at the same spot every time?
by motor_oil_madman - 01/24/20 10:26 AM
Amazoom Valvoline 5w30 deal
by volk06 - 01/24/20 09:28 AM
Forscan for Windows
by Donald - 01/24/20 07:30 AM
Group IV/V confirmed gear oils?
by metroplex - 01/24/20 06:34 AM
SATA Tools
by demarpaint - 01/24/20 05:10 AM
C-130
by Exhaustgases - 01/24/20 01:29 AM
Anyone Here Have a 9-Shot Rough Rider?
by ZeeOSix - 01/24/20 12:43 AM
Standard wix cartridge filter
by Bettez88 - 01/23/20 09:50 PM
Adaptive Driving Beam, Thoughts?
by Vern_in_IL - 01/23/20 09:07 PM
Pete44, Connie7, 2020XT, 4strokes, Perseus
70518 Registered Users
111 registered members (4WD, ArrestMeRedZ, AlaskaMike, Anthony, aircooled, 15 invisible), 3,026 guests, and 16 spiders.
Topics300,499
Posts5,177,330
Members70,518
Page 1 of 4 1 2 3 4
2019 Chevrolet Colorado w/ 3.6L GDI V6 + 8-Speed Trans Any Good? #5126841 06/06/19 09:02 AM
L
LoneRanger Offline OP
L
Curious about a long box 2WD version of the 2019 Colorado p/u. Seems most of the 2WD's for some reason are equipped with the 3.6 direct injection VVT V6 and GM is boasting 20/26 city/highway fuel economy on this combo w/ the 8-speed transmission.
Seems like a lot of engine for this size truck, what do you think?
'19 F-150 2.7 twin turbo DI V6 .....(Motorcraft synblend 5W30 SN+)
'19 GMC Terrain 1.5 turbo DI I4....(Warren 0W20 1DexosGen2)
'16 Moto Guzzi NTX 1151cc v-twin (Eni 10W60)
Re: 2019 Chevrolet Colorado w/ 3.6L GDI V6 + 8-Speed Trans Any Good? [Re: LoneRanger] #5126853 06/06/19 09:17 AM
W
WyrTwister Offline
W
Turbo or non-turbo
A lot of engine ? If turbo , maybe . If non-turbo , probably not .
And it depends on what you plan to use the truck for .
Wyr
God bless
Re: 2019 Chevrolet Colorado w/ 3.6L GDI V6 + 8-Speed Trans Any Good? [Re: LoneRanger] #5126869 06/06/19 09:37 AM
J
Jimzz Offline
J
Good engine, just don't let the oil get low. Some complained about the 8-speed transmission when it first came out but I have not seen as many complaints since then. So not sure if the software updates fixed it or new fluids?
It, and the GMC Canyon, are on my short list to replace my current truck next year.
yup
Re: 2019 Chevrolet Colorado w/ 3.6L GDI V6 + 8-Speed Trans Any Good? [Re: LoneRanger] #5126872 06/06/19 09:38 AM
dadto2 Offline
That Colorado is bigger than you think... I wonder, though, why that MPG is just about what I get in my 2wd Sierra with the 4.3? (more like 20/24) I was considering trading my '05 Colorado for a newer model, then realized that Colorado and full size cost almost the same, and get nearly the same MPG. Might as well get a truck that we fit in comfortably. (Our oldest son - 12 years - is already 5'10" and nowhere near finished growing!)
'16 GMC Sierra 1500 Crew Cab 4.3
'15 Volvo S60 T5 AWD
'99 Volvo S70 2.4
Re: 2019 Chevrolet Colorado w/ 3.6L GDI V6 + 8-Speed Trans Any Good? [Re: LoneRanger] #5126885 06/06/19 09:52 AM
L
L
I like them well enough but tbh they seem overpriced, at least in the ads. Their MSRP's are way too close to full size trucks of similar trim levels, so unless dealers are actually selling them way lower with hefty money off MSRP then they may not be a good value.
I noticed Ford has done this same MSRP thing on the new Ranger-- basically a compact truck at pricing that starts to approach full size territory in some cases.
For a 2019 Colorado long box crew cab 2WD LT 3.6 I'd only go $27K out the door, tops. I might lay that gauntlet down to a couple local dealers, after driving one to make sure I even like how they drive.
4WD is out, don't need it, posi-trac (old school GM speak for locking diff) 2WD with good tires will do everything I need. 4WD for me would just add extra weight and wear and tear, including front tire wear from the camber settings necessary for 4WD.
Re: 2019 Chevrolet Colorado w/ 3.6L GDI V6 + 8-Speed Trans Any Good? [Re: LoneRanger] #5126896 06/06/19 10:02 AM
R
ragtoplvr Offline
R
To the best of my knowledge the failure of the long and complex timing chain system is not fixed, only improved enough so it does not fail in warranty. IMHO it is NOT a good engine. Give me pushrods.
Replacement requires the removal of the front of the engine. This is a $2000 + job, only that cheap because the engine does not need removed on the trucks. I have serious doubts a dealer mechanic can replace it without oil leaks later, only experience will tell.
You also have higher maintenance costs from the more frequent oil changes needed from the excess soot in the oil from the direct injection. This accelerates chain wear. You are talking 5K miles max, and you must be using Dexos oil.
Rebuild costs of the 8 speed are high, and eventually it will fail. The cost for that is more than the timing chain.
IMHO You can count on needing a major repair before 200K.
This is why the resale will be lower than something with quality.
Re: 2019 Chevrolet Colorado w/ 3.6L GDI V6 + 8-Speed Trans Any Good? [Re: LoneRanger] #5126909 06/06/19 10:10 AM
W
Whimsey Offline
W
While the ford dealer having service done I looked at a new Ranger. It was not totally loaded yet still listed for almost $47,000 crzy.
Whimsey
Re: 2019 Chevrolet Colorado w/ 3.6L GDI V6 + 8-Speed Trans Any Good? [Re: ragtoplvr] #5126929 06/06/19 10:33 AM
A
ad244 Offline
A
You just described every modern Chevy.
Re: 2019 Chevrolet Colorado w/ 3.6L GDI V6 + 8-Speed Trans Any Good? [Re: ragtoplvr] #5126942 06/06/19 10:59 AM
ls1mike Offline
This was discussed at length. It use a totally different system from the old one and has been fixed. It has the LGZ which is a variant of the LGX. Timing system shares nothing with the ones that had these issues.
GMboy make a really good post about it.
The LGZ was introduced in 2016 (The truck engine). The is the 4th gen 3.6. The LFX before it used in tons of cars has not exhibited the issue either. The LLT was the main culprit of timing chain failures. 2008 until 2011 or 2016-17 depending on platform.
The issue is GM used the LLT in a lot of cars for too long and people don't know the difference between the engines. It was used until 2016-17 in the Traverse/Enclave .GM should have stopped using that design all together in 2011. They are not going to us the LGZ or LGX in the current Traverse or Enclave instead they will use the LFX. It is a cost saving measure, not sure how but that is what they say.
The LLT was used up until 2011 in the CTS and various other platforms (Camaro, Holden, Lacrosse, Outlook). That is where your failures are.
LFX was used after the LLT has had some failures on par with other manufactures timing chains. Nothing like the LLT. The LLT timing system was just a bad design.
Mike
00 Trans Am WS6 5.7 LS1
17 Silverado 3500HD 6.0
14 Caprice PPV 6.0
15 Malibu LTZ Turbo
12 Passport TT
Re: 2019 Chevrolet Colorado w/ 3.6L GDI V6 + 8-Speed Trans Any Good? [Re: LoneRanger] #5126948 06/06/19 11:06 AM
U
userfriendly Offline
U
The design was likely OK until 0W20 came along.
Re: 2019 Chevrolet Colorado w/ 3.6L GDI V6 + 8-Speed Trans Any Good? [Re: LoneRanger] #5126990 06/06/19 11:49 AM
B
benjy Offline
B
a nissan frontier is a better value for sure + NO direct injection issues because its still port injected. prices vary with cab styles + engines, manual cheaper but slush box an option. you said 2 wd so be aware pickups are very light in the rear + not good in slippy conditions. i love my preowned 2011 SV 4.0 V-6 with 6 spd manual + 4 WD + average 19 mpg with mostly local + some short trips in my hilly-mountainous area. plenty of room + good power as i haul coal yearly. GM + Ford are NUTS with their prices IMO!!!!
Re: 2019 Chevrolet Colorado w/ 3.6L GDI V6 + 8-Speed Trans Any Good? [Re: LoneRanger] #5127013 06/06/19 12:12 PM
O
oilpsi2high Offline
O
The 3.6 is garbage.
The GM 8 speed is garbage.
The truck itself is OK - I like the idea, but GM blew the execution IMO. Read consumer reviews and you'll find that there are a lot of problems with them - leaks, AC issues, trans problems, electronic bugs. Not sure if those were fixed with the 2019 models yet but from what I've read the problems still exist.
https://www.edmunds.com/chevrolet/colorado/2018/crew-cab/consumer-reviews/
From what I can see, most people who buy these wish they went with the Silverado.
I'd get a 5.3 Custom Silverado and be done with it.
Also, why do you want 2WD?
Re: 2019 Chevrolet Colorado w/ 3.6L GDI V6 + 8-Speed Trans Any Good? [Re: ls1mike] #5127022 06/06/19 12:19 PM
O
oilpsi2high Offline
O
For the most part, this.
GM replaced engine problems with trans problems though. Still a major powertrain issue.
The gripe I have with the new 3.6 is the torque curve. There's NO WAY I would hook 5000 lbs up to that truck and tow in the mountains with it. It's rated for 7k but there's no way I would trust that figure.
I test drove a 3.6 Colorado and it was just awful. I felt like I was driving a 90's Isuzu. It makes NO power until you are over 4000 RPMs, then the engine sounds like an angry 350Z. Don't let the sound deadening and tech features fool you - this truck was designed in the late-2000's, and it rides and drives like one, too.
Re: 2019 Chevrolet Colorado w/ 3.6L GDI V6 + 8-Speed Trans Any Good? [Re: LoneRanger] #5127045 06/06/19 12:46 PM
Danno Offline
Friend of mine just traded in a 2017 Canyon on a 2019 Ranger Limited. Took a loss.
The GM had transmission issues that were unsolvable - mostly around shuddering.
2019 Jeep Grand Cherokee Summit 5.7L Hemi
2019 RAV4 Limited Hybrid
2016 Sorento SX V6 AWD
2010 Mazda 3 2.0L
Re: 2019 Chevrolet Colorado w/ 3.6L GDI V6 + 8-Speed Trans Any Good? [Re: LoneRanger] #5127067 06/06/19 01:11 PM
U
U
Unsolvable transmission problem? First get rid of the water thin Dexox VI and go from there.
Page 1 of 4 1 2 3 4
