Amsoil discontinues ACD SAE 30/10w30 HDEO
by CleverUserName - 01/22/20 07:34 PM
Chromium-based Microsoft Edge
by uc50ic4more - 01/22/20 07:13 PM
Reason for new car problems
by Exhaustgases - 01/22/20 05:50 PM
Selling the VW need a replacement.
by ram_man - 01/22/20 05:48 PM
Williams Tools Made in Taiwan
by BBDartCA - 01/22/20 05:32 PM
Synthetic Power Steering Fluid?
by TXCarGeek - 01/22/20 05:03 PM
New 5% RA discount code
by bullwinkle - 01/22/20 04:12 PM
17 Dodge Ram 6.7, 5K
by merdog - 01/22/20 02:16 PM
Mobile 1 in a Subaru Manual transaxle?
by someoldguy - 01/22/20 01:17 PM
Castrol and NASCAR
by kstanf150 - 01/22/20 01:14 PM
AMSoil Signature / AMSoil European - 5-40
by 335xiE92FBO - 01/22/20 12:06 PM
How happy are you in your profession ?
by Mr Nice - 01/22/20 11:52 AM
Npt fitting torque?
by motor_oil_madman - 01/22/20 11:47 AM
Tracing wires in walls
by Dave Sherman - 01/22/20 11:32 AM
WM Castrol HM magnatec 6 GALLON BOX $45
by GMguy84 - 01/22/20 11:30 AM
Steering Lubricant Suggestion
by lancerplayer - 01/22/20 11:08 AM
Neglected AW55-50 - Plan Of Attack?
by Bailes1992 - 01/22/20 09:14 AM
BMW caliper pins, no lube?
by ledslinger - 01/22/20 08:58 AM
EricWestland, Brian200001, Phildrum, 335xiE92FBO, oldrover
70505 Registered Users
115 registered members (aba4430, Astro_Guy, 2009Edge, 2015_PSD, atikovi, 16 invisible), 2,498 guests, and 18 spiders.
Topics300,443
Posts5,175,925
Members70,505
brass ball valve ok for pool #5120687 05/30/19 07:46 PM
R
raaizin Offline OP
R
My pool is built in such a way that the filter is located below the waterline. When I blow out the line and close the valve at winter closing. The valve leaks over the course of the winter and as a result it cracks the valve as the water seeks its own level. I noticed the plastic ball valves fail and cause me issues. I am considering a brass valve for the deep end and was wondering what the water chemistry would have on valve. Would Chlorine destroy the valve. Any suggestions on how to fix permanently.
Re: brass ball valve ok for pool [Re: raaizin] #5120739 05/30/19 08:55 PM
R
rekit Offline
R
At the Refinery we used "Double Block and Bleed". Two closed valves a small distance apart with an open valve or plug between them. Sounds extreme for a pool but it is just 2 more valves and 2 bleeder valves or plugs. Point bleeder down if you can -horizontal section. And you can use plastic.$$
Or disconnect the pipe and cap off?
Re: brass ball valve ok for pool [Re: raaizin] #5121012 05/31/19 06:48 AM
J
JLawrence08648 Offline
J
There are ball valves with bleeder valves to remove the remainder of the water in the valve, just unscrew the bleeder valve.
