HF 30% Off $10 and Under
by TheLawnRanger - 01/21/20 06:02 PM
Stolen Battery-New one on Me
by bunnspecial - 01/21/20 05:29 PM
2006 Acura TSX Buying Advice
by maverickfhs - 01/21/20 04:35 PM
Castrol GTX Diesel 15W-40, CK4
by HDoilDude - 01/21/20 04:30 PM
Combo of P0068 and P307A
by Alfred_B - 01/21/20 04:30 PM
Are the plastic battery trays necessary?
by littlehulkster - 01/21/20 03:18 PM
Amsoil ATV/UTV Powertrain Fluid
by IowaFord - 01/21/20 02:13 PM
Motorcraft FL500s 3,630 miles.
by mpgo4th - 01/21/20 01:36 PM
Xcel Class Action Suit
by John_K - 01/21/20 12:33 PM
RV Freightliner Cummins ISB 6.7 oil question
by 1978elcamino - 01/21/20 11:48 AM
Why I became a pilot and not a doctor...
by jetman - 01/21/20 10:52 AM
Wrong oil or not ?
by M119 - 01/21/20 10:48 AM
30 monograde
by mpack88 - 01/21/20 10:15 AM
Extended life destroys copper?
by mpack88 - 01/21/20 09:49 AM
Project Farm Lucas transmission additive video
by 1978elcamino - 01/21/20 09:43 AM
1.8t 0w40, plus a situation.
by WMNN1988 - 01/21/20 09:25 AM
Mobil 1™ ESP X2 0W-20 US Availability
by TheIceStormof06 - 01/21/20 08:46 AM
Wire harness/connector
by Redright9 - 01/21/20 07:58 AM
IowaFord, Origami99, reylafo, PastPresMike, RedBeard83
70497 Registered Users
112 registered members (4WD, 67ZL1, ArrestMeRedZ, 2000ltdken, Astro14, 9 invisible), 2,215 guests, and 26 spiders.
Topics300,404
Posts5,175,043
Members70,497
Page 9 of 15 1 8 9 10 15
Re: Understanding Viscosity and HTHS [Re: RDY4WAR] #5120523 05/30/19 04:37 PM
Shannow Online Content
Online Content
Originally Posted by RDY4WAR
Just because you're an engineer doesn't mean you're always right. An engineer designed the Mustang II after all.
If anything, it's more unsettling that an engineer is willing to push what is essentially psuedoscience.
Please don't lump us practicing engineers (mechanical with 30 years of bearing design, construction, turbine operation and maintenance, and lubrication) in with this...
If it's the truth....it can handle the pressure !!!
Re: Understanding Viscosity and HTHS [Re: RDY4WAR] #5120528 05/30/19 04:43 PM
G
Gokhan Offline
G
I agree but not necessarily for the Mustang II part.
So, with no degree, training, and experience in engineering and science, you claim to have a better engineering and scientific judgement.
Also, when you first joined this forum, I was the one to welcome you and answer your question about ZDDP in glory detail.
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/4853520/primary-vs-secondary-zddp
2020 Toyota Prius Prime XLE plug-in hybrid, 2ZR-FXE engine, ~ 2,000 mi
TGMO 0W-16 SN/RC Japan
OEM spin-on oil filter Japan
Re: Understanding Viscosity and HTHS [Re: Shannow] #5120531 05/30/19 04:45 PM
G
Gokhan Offline
G
+1
Re: Understanding Viscosity and HTHS [Re: Gokhan] #5120544 05/30/19 05:09 PM
RDY4WAR Offline
At no point did I claim to have better engineering and scientific judgement. Where you got that, I have no idea. I don't have a degree. I build and race engines, and am mostly self-taught. I look to engineers, like yourself, to expand my knowledge. Which is why it's upsetting for someone like myself when pseudoscience gets presented as hard facts as it feels like I'm being taken for a fool. I may not be an engineer, but I know when information is incompatible with the scientific method.
Nikola Tesla said it best... "Today's Scientists have substituted mathematics for experiments, and they wander off though equation after equation, and eventually build a structure which has no relation to reality."
"He who is without oil, shall throw the first rod." - Compressions 9:1
Re: Understanding Viscosity and HTHS [Re: RDY4WAR] #5120569 05/30/19 05:45 PM
G
Gokhan Offline
G
It's fair enough, but when you call an honest scientific effort pseudoscience, it implies that. Pseudoscience refers to astrology, alchemy, alternative medicine, etc. If you do hold a degree and make similar statements, it implies that you either don't respect your colleagues because you lack maturity or simply are not capable of understanding their work and lack a deep understanding of science and engineering beyond a superficial knowledge from your training or more likely some combination of the two.
It is not pseudoscience. It's based on the ASTM D341 viscosity - temperature relationship (are you calling that pseudoscience?) and a simple empirical relationship between the VII content, viscosity, and shear. Don't forget that it's meant as an estimator and prone to certain errors.
I told you to send me the parameters of your boutique oils so that I can take a look but you never did. In your case, no VII is involved; so, the only error could result from ASTM D341 or the errors in your KV, HTHSV, and density values.[/quote]
Re: Understanding Viscosity and HTHS [Re: JustN89] #5120572 05/30/19 05:49 PM
J
JAG Offline
J
I was and still am suggesting that online motor oil patent data be used to check how accurately the tool’s various predictions/outputs are. I would do it myself but I don’t want that to encroach on my too-little free time. Creating and using models has been my profession for well over a decade. The tool should undergo a process with the catch phrase name (that I dislike) called verification and validation (V&V). There is little to criticize until it is known how accurate its outputs are. Also, after seeing how it performs, the model could and should be tweaked to improve it. This is how it’s done in this line of work.
There are many valid ways to build models. Some of those ways can even result in models that can make predictions about things involving highly complex Newtonian physics (ex. maneuvering missile flight) or other complex laws without the model having explicit “knowledge” of said physics or laws. Those models typically gain their predictive capabilities by analyzing a lot of input data, then their internal variables get tuned such that the models’ outputs match the input data’s associated outputs as well as possible. One famous example of this is machine learning. On the much more primitive end, there is curve-fitting data to make predictions at other locations for which there is no input data. Enough rambling from me...
Re: Understanding Viscosity and HTHS [Re: JAG] #5120627 05/30/19 06:52 PM
G
Gokhan Offline
G
It sounds like you do some great interesting engineering work, JAG!
Re: Understanding Viscosity and HTHS [Re: GaryPoe] #5120634 05/30/19 06:56 PM
G
Gokhan Offline
G
Originally Posted by GaryPoe
Keep the wheels turning. I like your content and frankly look forward to it @Gokhan oilburner
Thanks, GaryPoe!
Here is an application of the base-oil/HTHSV calculator to the Valvoline Advance Synthetic oils, which have unusually superior viscosity characteristics:
https://www.bobistheoilguy.com/foru...vii-and-wear-its-complicated#Post5120623
Re: Understanding Viscosity and HTHS [Re: Gokhan] #5120660 05/30/19 07:18 PM
J
JAG Offline
J
Thank you. I do find it very interesting and will likely spend my whole career at the same place. I avoid mentioning identifying details of it online because of its nature. It’s awkward to always be vague about it but it’s best to keep it that way.
Re: Understanding Viscosity and HTHS [Re: Gokhan] #5120761 05/30/19 09:29 PM
G
Garak Offline
G
The relationship has not yet been demonstrated in an empirical fashion. We're barely reaching out of the thought experiment juncture.
Plain, simple Garak.
Re: Understanding Viscosity and HTHS [Re: JustN89] #5120788 05/30/19 10:12 PM
Z
ZeeOSix Offline
Z
Engineers put a spacecraft in orbit around the moon, and men on the moon surface with slide rules, pencil drawings/blue prints with no actual test simulations in near zero gravity and no atmosphere to verify the LEM could actually land successfully on the moon surface. whistle Pretty amazing stuff done by Engineers with mathematical equations.
Re: Understanding Viscosity and HTHS [Re: JustN89] #5120796 05/30/19 10:20 PM
d00df00d Online Content
Online Content
Originally Posted by ZeeOSix
Engineers put men on the moon with slide rules, pencil drawings/blue prints and no actual test simulations in near zero gravity and no atmosphere to verify the LEM could actually land successfully on the moon surface. whistle Pretty amazing stuff done by Engineers with mathematical equations.
Shark: jumped.
Someone please lock this thread.
2008 BMW M3 Sedan 6MT
Re: Understanding Viscosity and HTHS [Re: d00df00d] #5120816 05/30/19 11:17 PM
G
Gokhan Offline
G
Shark: jumped.
ZeeOSix is not a shark. He's a knowledgeable engineer, specialized in fluids and heat. He makes very good posts. What he said here is true.
Re: Understanding Viscosity and HTHS [Re: JustN89] #5120850 05/31/19 12:48 AM
O
OilUzer Offline
O
Why train drivers (British) are called Engineers in US? grin2 can you even find a calculator in the cab?
Re: Understanding Viscosity and HTHS [Re: JustN89] #5120865 05/31/19 01:54 AM
U
userfriendly Offline
U
I don't need one.
