Leather conditioner
by dawgn86 - 10/20/19 10:15 AM
Rockville MD fall car show pictures
by atikovi - 10/20/19 09:21 AM
Battery Jumpstarter Recommendation
by dkryan - 10/20/19 08:50 AM
Why the guard on wheel balancers?
by atikovi - 10/20/19 07:18 AM
NY Yankee fans...
by gfh77665 - 10/20/19 12:56 AM
168 inch pounds feels really--really tight
by perfect_oil - 10/19/19 11:36 PM
Older fram ultra
by tblt44 - 10/19/19 08:42 PM
Best price on Colt 9MM pattern mags?
by GumbyJarvis - 10/19/19 08:20 PM
Using a trim router for cutting sheetrock
by JLawrence08648 - 10/19/19 08:09 PM
C&P of a Tough Guard w/50,000 miles to be posted soon
by MrQuackers - 10/19/19 08:04 PM
Chevy dealer, 7 free oil changes?
by Zacc - 10/19/19 07:34 PM
School me..1200 amp jumper
by Schmoe - 10/19/19 07:19 PM
YouTube Finish Test
by RayCJ - 10/19/19 07:09 PM
Overfilled, drained some, still too full?
by OCDriver - 10/19/19 06:16 PM
Wix made in Korea?
by JGmazda - 10/19/19 06:01 PM
Oil change interval question
by SkipCam - 10/19/19 05:49 PM
Remove Spark Plug Wires
by borgward - 10/19/19 04:53 PM
Pinion yoke loose, is the bearing ruined?
by Fsharp - 10/19/19 03:45 PM
lexus4life, visco17, Patrick1201, BloodyButUnbowed, Kazuhiro
69618 Registered Users
73 registered members (53' Stude, andreigbs, Astro_Guy, askani79705, 69GTX, 64bawagon, 6 invisible), 2,169 guests, and 25 spiders.
Topics296,205
Posts5,093,501
Members69,618
Most Online3,532
Jul 30th, 2019
0w30 Showdown of European Oils #5114056 05/23/19 10:12 PM
Marco620 Offline OP
https://www.ato24.de/en/blog/comparison-0w-30-engine-oils
Lots of numbers and graphs. Reminded me of an old amsoil chart. I was searching for hths and a couple rabbit holes later and found this. Hope its helpful and or informative to someone.
15' Civic 1.8 i-vtec 280,000 mi Redline 0w20, BP CVT Fluid,Redline Si-1
Doberman Whisperer!
Redline Oil,Honda,Doberman,CZ & SONY Aficionado
Re: 0w30 Showdown of European Oils [Re: Marco620] #5114169 05/24/19 03:51 AM
K
Kamele0N Offline
K
Shell....Mobil1............Total.......
2008 Toyota Yaris 1ND-TV 1.4 D4-D Tech9 5W30 C3 VW 504/507
1997 Toyota Landcruiser KZJ95 3.0 TD Elf Evolution NF900 5W40
Re: 0w30 Showdown of European Oils [Re: Marco620] #5114260 05/24/19 07:43 AM
B
BMWTurboDzl Offline
B
LL12FE ain't so bad
435i
Re: 0w30 Showdown of European Oils [Re: Marco620] #5114304 05/24/19 08:22 AM
R
RamFan Online Sleepy
Online Sleepy
R
Nice find, thanks for sharing!
18 Giulia Ti Sport Q4
  • 2.0T I4 - 18k - PP Euro LX 0w30 - Mobil 1 - 10k/1yr
16.5 CX-5 Touring AWD
  • 2.5L I4 - 64k - Castrol Edge EP 0w20 - Denso - 7.5k/1yr
Re: 0w30 Showdown of European Oils [Re: Marco620] #5114383 05/24/19 09:55 AM
O
oil_film_movies Offline
O
INHALTSVERZEICHNIS on the web page means "Contents" in non-German-speak, BTW.
Interesting text. A lot did get lost in translation. It's hard to tell if they are simply not getting some things right, or the translator skewed the words a little. Not bad overall.
Surprised just how low the SA is in BMW TwinPower. All listed are decent oils to use.
Re: 0w30 Showdown of European Oils [Re: oil_film_movies] #5114407 05/24/19 10:23 AM
CT8 Offline
Within the ratings oil is oil.
2015 F150 2.7
2018 F350 6.2
Re: 0w30 Showdown of European Oils [Re: Marco620] #5114541 05/24/19 12:27 PM
A
aba4430 Offline
A
Is there a contradiction in the first three charts?
1. The Helix is the highest in the viscosity graphs (40 and 100 deg C). Summary is "➥ In short: The higher the result values (mm²/s), the more constant the viscosity remains at high temperatures and thus allows longer constant lubrication despite increasing temperature changes."
2. The Helix has the lowest viscosity index. However, the summary is, "➥ In short: The higher the viscosity index of the engine oil, the lower the change in viscosity at high temperatures."
2018 Nissan Titan CC Pro4X
2017 Subaru Outback 2.5
Subaru RGV12100
2013 Suzuki SX4 Sportback
2000 BMW 328Ci
1998 BMW Z3 2.8
1995 JD LX178
1987 Subaru Brat
Re: 0w30 Showdown of European Oils [Re: aba4430] #5114578 05/24/19 01:00 PM
R
Online Sleepy
R
My understanding is that VI has more to do with decreasing viscosity changes during low temperatures as opposed to high temperatures.
Re: 0w30 Showdown of European Oils [Re: RamFan] #5114586 05/24/19 01:12 PM
CT8 Offline
[/quote]My understanding is that VI has more to do with decreasing viscosity changes during low temperatures as opposed to high temperatures.
[/quote]
Explain your understanding about the Viscosity modifiers.
2015 F150 2.7
2018 F350 6.2
Re: 0w30 Showdown of European Oils [Re: Marco620] #5114616 05/24/19 01:35 PM
sloinker Offline
I'm thinking that the use of viscosity modifiers in some of the sample oils is negligible if used at all. The Ravenol for instance is a PAO oil with a few drops of ester so inherently covers a wide viscosity range. I imagine a few more of the samples have the same or similar make-ups negating the use VI.
'16 Tiguan TSI Ravenol VST 5W40
'15 VW Golf TDI Ravenol VMP 5W30
'15 VW Golf Sportwagen TDI VMP 5W30
'14 Dodge Grand Caravan 3.6 Red Line Blue Label 5W20
'64 Plymouth Fury440 Red Line Blue Label 10W40
Re: 0w30 Showdown of European Oils [Re: RamFan] #5114845 05/24/19 07:37 PM
O
O
VII chemicals thicken a base-oil when hot. Hardly any effect at all when cold. For example, if you formulate a 0w30, you need to use thin base oils to get the "0w" rating, then you need to add VII to get the "30" rating. .... If you DIDN'T add any VII, then you might get something like a lighter-side "20" weight oil (kv100) hot.
Re: 0w30 Showdown of European Oils [Re: oil_film_movies] #5115068 05/25/19 01:14 AM
K
Kamele0N Offline
K
Interesting text. A lot did get lost in translation. It's hard to tell if they are simply not getting some things right, or the translator skewed the words a little..
Sometimes its hard to translate words/phrases between languages....because often either one language or another doesnt use the same words for the same thing...
For an example...if german is expressing that he or she was lucky....it sounds like (in slang) "ich habe kartofel gehabt".....wich translates into my language as " I had a potato (with that thing/whatever)" smile
Re: 0w30 Showdown of European Oils [Re: oil_film_movies] #5115891 05/25/19 10:19 PM
R
Online Sleepy
R
My comment wasn’t geared towards VII but the actual VI. I don’t think I communicated that clearly in my original post. Say you have two 0w30 oils, one with a VI of 180 and one with a VI of 205. At operating temperature they will both have the viscosity of an Xw30. However the oil with the VI of 205 should maintain a viscosity that’s closer to its operating viscosity in colder temps as compared to the oil that has a VI of 180, in theory at least.
