Ratcheting Wrenches
by Redright9 - 02/20/20 07:27 AM
Buick Regal 2.0T Ecotec Engines
by ET16 - 02/20/20 06:34 AM
Fuchs Titan GT1 Evo 0w20 LL014FE
by kr_bitog - 02/20/20 05:46 AM
Tungsten Ravenol
by V10 - 02/20/20 01:37 AM
Can an SSD make this much difference?
by 14Accent - 02/20/20 01:14 AM
The Big Oil Change - Sinclair Oil 1960's
by StevieC - 02/19/20 10:47 PM
A new topper for my truck
by HM12460 - 02/19/20 10:12 PM
AAP/Carquest platinum pads/rotors
by parshisa - 02/19/20 10:03 PM
Apple watch - high data usage
by Quattro Pete - 02/19/20 09:46 PM
Gas in the 80's vs Today
by alcyon - 02/19/20 09:34 PM
1993 Hilux 3.0 diesel
by Mayberryminitruc - 02/19/20 08:58 PM
WrightGrip 2.0 wrench set
by spasm3 - 02/19/20 08:57 PM
Don't forget about your clutch fluid
by Number_35 - 02/19/20 08:40 PM
Financial Advice
by cpayne5 - 02/19/20 08:28 PM
2003 Accord 6 Cylinder EX No start
by Gito - 02/19/20 08:03 PM
Oil Advice For 1990s Era Yamaha ATVs
by DockHoliday - 02/19/20 07:42 PM
2 quarts supertech 0w-20 for $4.56
by sjstangman - 02/19/20 07:35 PM
1994 Buick Century 63K miles
by MuzzleFlash40 - 02/19/20 07:33 PM
Why is this plug so expensive?
by motor_oil_madman - 02/19/20 07:01 PM
Mayberryminitruc, DaiwaGuy, Gunboatmac, Mad_Max_Sam, 24Carat
70756 Registered Users
80 registered members (advocate, 2010Civic, ARB1977, askani79705, AndyB, alarmguy, 6 invisible), 1,448 guests, and 29 spiders.
Topics301,690
Posts5,200,581
Members70,756
Coolant filtration: fuel filter vs synthetic oil filter #5113354 05/23/19 09:52 AM
Z
zorobabel Offline OP
Z
I don't expect the filter to catch much in this 97 Maxima running Recochem red (but who knows what shops did to it for the first 112k miles); I blame wanting to do this on BITOG smile
I want to install it in the throttle body loop (5/16" hose) which is a bypass of the heater loop. A plugged filter should not be an issue, as it would just reduce flow to the TB; I have contemplated removing the TB out of the loop more than once (making the removal of the aluminum intake manifold collector less of a PITA).
Option 1. Use a larger metal fuel filter such as the Wix 33022. I would have to strap it to other hoses in the area.
Option 2. Use a synthetic oil filter mounted on a remote base with a 3/4-16 thread. I know about the 11/16-16 thread coolant filters (cellulose Wix 24069, 24070), but most of the discussion dates from way back, when synthetic media oil filters weren't common. I figure synthetic media should hold up better than cellulose media, the only unknown would be the glue. Disclaimer: I have a large stash of 3/4-16 oil filters.
I would mount this either on the transmission (M8 threads available) or on the strut tower (M6 threads available) with more vibration.
I'd appreciate your thoughts please.
1997 Maxima 210k, Castrol GTX Synblend 5W-30, PL14459
2004 Corolla 211k, Valvoline SynPower 5W-30, K&N HP-1003
Re: Coolant filtration: fuel filter vs synthetic oil filter [Re: zorobabel] #5113411 05/23/19 10:50 AM
I
Imp4 Offline
I
I think you shouldn't do this because it won't accomplish anything notable or worthwhile.
At best, it will scratch your itch to tinker.
At worst, you will unintentionally mess something up.
2001 Mitsubishi Galant 2.4 - 165k+
Grandma's creampuff...
Re: Coolant filtration: fuel filter vs synthetic oil filter [Re: zorobabel] #5113423 05/23/19 11:09 AM
Donald Offline
There are some vehicles where a coolant filter might be a good idea. Your vehicle is not one of them. Service coolant as per owners manual and worry about something important like how well Yankees are doing.
2015 Ford F-250 w/Powerstroke
Re: Coolant filtration: fuel filter vs synthetic oil filter [Re: zorobabel] #5113456 05/23/19 11:39 AM
G
Gimpy1 Offline
G
You want to install a filter not designed to handle coolant, on a 21 year old vehicle with 200k miles,where the benefit will be minimal at best? Why do you want to filter coolant? IMHO this is a perfect example of a solution looking for a problem. Don't add something else that will be a failure point, plus I don't think fuel filters are designed to handle the heat of pressurized coolant and you may get bits of glue or filter media in your cooling system which would contradict the reason why you added a filter system in the first place. If you're that worried about the cooling system, drop the filtration idea and completely flush the cooling system, replace the water pump, all the hoses, R&R the radiator and heater core, and replace the thermostat. This way you have everything new and clean. (yes the last 2 sentences are sarcasm)
Re: Coolant filtration: fuel filter vs synthetic oil filter [Re: zorobabel] #5113543 05/23/19 12:54 PM
W
widman Offline
W
If you really want to do something, I would not use a fuel filter, as the material might not be comparable. A P560382 filter head. link to filter head with a DBC4086 synthetic filter will take any contaminates down to 4 µm at 99% link to filter or the DBC4081 will take it to 50 µm at 99%. link to filter
Re: Coolant filtration: fuel filter vs synthetic oil filter [Re: zorobabel] #5113550 05/23/19 01:04 PM
R
Rhymingmechanic Offline
R
To me, the remote setup seems like overkill. A google image search for "inline coolant filter" pulls up dedicated options that go in radiator or heater hoses, as well as some old BITOG experiments with inline fuel filters.
The dedicated coolant filters seem to have metal screen or the porous metal used in air/water separators. Old BITOG results suggest that plastic fuel filters get soft and swell up. Metal ones hold up but the paper element clogs.
Re: Coolant filtration: fuel filter vs synthetic oil filter [Re: zorobabel] #5113612 05/23/19 02:06 PM
Dave9 Offline
If this were needed on new vehicles they would have them. It's needed that much less on your old, near end of life, low value vehicle. I'm not trying to be negative about the vehicle itself, Maximas were a decent sedan choice for '97 though Nissan has never had great auto trannys.
A little sediment in your coolant is not what's going to kill it eventually. Just change the coolant every so often.
If anything, now is the time to enjoy low cost ownership and only do the required maintenance to keep the operating costs lower. Save up the money, nothing lasts forever.
Re: Coolant filtration: fuel filter vs synthetic oil filter [Re: zorobabel] #5113679 05/23/19 02:56 PM
CT8 Offline
They make real coolant filters . Use the real thing.
2015 F150 2.7
2018 F350 6.2
Re: Coolant filtration: fuel filter vs synthetic oil filter [Re: widman] #5113719 05/23/19 03:33 PM
Z
Z
Thanks for sharing, that's a neat base. Nice to see synthetic coolant filters too. A slight correction: DBC4086 synthetic filter will take any contaminates down to 14 µm at 99%.
Re: Coolant filtration: fuel filter vs synthetic oil filter [Re: zorobabel] #5120069 05/30/19 08:04 AM
W
widman Offline
W
Sorry about the typo.
