Thoughts on Time v Mileage
by BISCUT - 08/23/19 10:04 AM
Shocks / Struts
by WyrTwister - 08/23/19 08:04 AM
Stihl HT 50 CE Pole Pruner
by ssamaroo01 - 08/23/19 08:01 AM
LQ4/LQ9 direct swap for LS1?
by cwilliamsws6 - 08/23/19 08:00 AM
Fearing the RockAuto worst
by Kira - 08/23/19 07:40 AM
Minimum octane for 2016 2.0 ecoboost?
by Corollaman - 08/23/19 07:06 AM
Weedwacker advice
by supton - 08/23/19 07:05 AM
Temps pre & post diff cover change
by kehyler - 08/23/19 06:51 AM
DIY: Mazda 2.5L Skyactiv Water Pump
by The Critic - 08/23/19 06:03 AM
vavoline syncpower 4T
by bonjo - 08/23/19 03:24 AM
Great Price but...
by Marco620 - 08/23/19 02:02 AM
CV Joint Leaking Grease
by 92saturnsl2 - 08/22/19 10:20 PM
Craftsman 6 pc. Screwdriver Set $12.14
by Warstud - 08/22/19 09:32 PM
Got My ATF Replaced.
by Mr_Luke - 08/22/19 09:20 PM
Wht do people with labor intensive jobs lay on their back?
by motor_oil_madman - 08/22/19 09:14 PM
Date code 5 Q Chevron location?
by Onetor - 08/22/19 08:06 PM
Confused, what oil to use?
by BelAir - 08/22/19 08:00 PM
2015 KIA optima turbo Coolant Flush
by Grambo - 08/22/19 07:52 PM
lubetech82, Lockguard, PTL, vdubw, NJ01MGM
69036 Registered Users
89 registered members (ArrestMeRedZ, Ag76, A_Harman, Anduril, atikovi, Ayrton70, 13 invisible), 2,047 guests, and 25 spiders.
Topics293,675
Posts5,044,832
Members69,036
Most Online3,532
Jul 30th, 2019
Need help finding regulator for 1992 Honda accord #5110419 05/20/19 05:11 PM
T
taztheman Offline OP
T
So a little backstory, my dad has owned a 1992 Honda Accord Dx model for 2 years. Ever since he first got it the driver window has always been hard to crank up and down (manual windows). About 2 months ago the window was down and he forced it up with the hand crank causing it to shatter. We have since gotten the window replaced, but I have not been able to get a window regulator for it. The window regulator track is bent which is not allowing the window to move. I can’t find a manual regulator anywhere that isn’t made in Japan. I’ve tried rockauto, etc to no avail. It is a 1992 4 door Honda Accord dx driver side window regulator. Does anyone know if a japense regulator will work even though the car was made in America (the first digit in the bin is 1). If not where to get a manual regulator that will work with an American made Honda.
Any help is greatly appreciated
Re: Need help finding regulator for 1992 Honda accord [Re: taztheman] #5110441 05/20/19 05:32 PM
J
JC1 Offline
J
Did you check eBay? www.car-part.com has a searchable feature.
Does the stealership carry it?
2015 Grand Caravan SXT Plus 5w-30 Valvoline White Bottle/Fram Ultra Filter
1997 Honda Civic CX 5w-30 Shell Conventional/Fram Ultra Filter
Re: Need help finding regulator for 1992 Honda accord [Re: taztheman] #5110472 05/20/19 06:12 PM
J
JMJNet Offline
J
Did you check with Honda forum? A lot of Honda owners probably have your challenge also and they should know to answer this type of question at the tip of their finger.
Who knows, it may also be in their FAQ.
  • 2017 Toyota Sienna
Re: Need help finding regulator for 1992 Honda accord [Re: taztheman] #5110479 05/20/19 06:22 PM
J
Jarlaxle Offline
J
Is the original NOT made in Japan?
1979 Coupe de Ville, 542 stroker, 15W-40 Super Tech, Delco
2011 Crown Vic P71, 5W-20 Super Tech, Super Tech
2011 Sportster 883, 20W-50 SYN3, HD black
Re: Need help finding regulator for 1992 Honda accord [Re: taztheman] #5110484 05/20/19 06:28 PM
N
Nukeman7 Offline
N
This regulator should work for you:
92 Accord Window Regulator
I believe the 1992 U.S. and Japanese manufactured Accords used identical regulators.
Re: Need help finding regulator for 1992 Honda accord [Re: taztheman] #5110499 05/20/19 06:44 PM
slacktide_bitog Offline
I don't think it makes a difference for the regulator whether your car was made in the US or Japan smile
Re: Need help finding regulator for 1992 Honda accord [Re: taztheman] #5110551 05/20/19 07:54 PM
A
ag_ghost Offline
A
I agree with the above; for future reference, enter the Accord's VIN here
https://estore.honda.com/
after clicking through Body/Air Conitioning, then Door WIndow
it's probably this part number
72250-SM4-901
e.g.,
https://estore.honda.com/honda/part...4-dx-4at&sn=&b=B++53&dl=#010
Online Honda parts supplies (hondapartsnow.com, hondapartsunlimited.com etc.) will confirm the part number with your VIN, but likely say the true OEM part is unobtanium...
So you may have to try something like a Dorman repro part (enter the part number above on eBay, for example).
I'm facing similar challenges with my '90 Accord.
Kevin
63 Galaxie 500, 390; dad bought it new...
99 Accord V6
15 CR-V
90 Accord EX
Re: Need help finding regulator for 1992 Honda accord [Re: ag_ghost] #5110643 05/20/19 09:27 PM
B
benjamming Offline
B
72250-SM4-901
e.g.,
If that is the correct p/n, then Bernardi shows it as available for $83.07 plus shipping. You can email them with your VIN & confirm stock. I'm surprised it's still available. Others such as Majestic Honda & Sterling McCall show it as discontinued. You can also try Vintage Parts.
Re: Need help finding regulator for 1992 Honda accord [Re: taztheman] #5110662 05/20/19 09:49 PM
B
benjamming Offline
B
NAPA lists a manual regulator p/n NOE 6653824, but for Japan built vehicle. Odd. It's not stock, but it's only ~$47 plus tax.
O'Reilly says you can special order but call your local store. Dorman part number 740-633 (car built in Japan, 4-door version) is $48 + tax. Cardone p/n 82-1524M for 4-door is $55 + tax. It doesn't specify made in Japan. You can probably have them order one & if it doesn't work, then just take it back & get refunded.
AAP lists it online but not available for shipping nor in stock.
AutoZone doesn't come close.
Re: Need help finding regulator for 1992 Honda accord [Re: taztheman] #5110806 05/21/19 02:21 AM
F
FT92 Offline
F
try a salvage yard., when I need parts I usually head to the local u pull it salvage yard, cant beat the prices..
