Repurposing Sears and other retail sites
by Kira. 07/21/19 07:34 AM
Amsoil XL 5W30 1.5LT
by ARB1977. 07/21/19 07:17 AM
HF: Bauer Grinder Teardown/Analysis
by RayCJ. 07/21/19 05:55 AM
P21S Windshield Wash Booster
by Duffyjr. 07/21/19 05:25 AM
Transmission Swap
by Ponchinizo. 07/20/19 11:41 PM
Ecogard S4477
by Steiny. 07/20/19 11:25 PM
Fuel Tanker Driver Here
by GoldDot40. 07/20/19 10:25 PM
Overfilled diff?
by HoosierJeeper. 07/20/19 10:02 PM
Brake Surge - Lexus
by MaximaGuy. 07/20/19 09:55 PM
Oil Rec for Street Driven & Track Usage
by randomhero439. 07/20/19 09:46 PM
Paint correction lighting setup for white paint
by Reddy45. 07/20/19 09:07 PM
Cannot pull credit report for wife
by Klutch9. 07/20/19 08:24 PM
Toyota 2AZ - FE!??
by miden851. 07/20/19 08:23 PM
What about the Chevy Trax?
by gregk24. 07/20/19 08:06 PM
Authentic 100% Synthetic 5W30/0W40 engine oil
by Denali376. 07/20/19 07:59 PM
Any Towing Reviews with New Tacoma V6 Manual 4x4?
by oilpsi2high. 07/20/19 07:39 PM
Synthetic 5W30 D1/Gen2 vs. Synthetic 10W30 ?
by ChrisD46. 07/20/19 07:00 PM
ECOGARD X4612 NEW FILTER CUT OPEN
by 53' Stude. 07/20/19 06:48 PM
grikor, Mikelima, mannydingo, Roadtripp, Denali376
68720 Registered Users
89 registered members (4WD, 2015_PSD, 97f150, 97K15004WD, 2003f7, 2009Edge, 6 invisible), 1,269 guests, and 25 spiders.
Topics292,180
Posts5,018,192
Members68,720
Most Online2,967
Mar 10th, 2019
Oil in the toolbox #5107687
05/17/19 12:58 PM
05/17/19 12:58 PM
USA
Floyd1 Offline OP
Floyd1  Offline OP
USA
Hello folks:
I now have a few trucks which have toolboxes on them. I usually keep a quart or two of oil in the toolbox just to have in case I ever need to add any or help someone out etc.
Where I live will begin to see temps in the 90’s everyday, so I’m sure the inside of the metal toolbox on the bed will easily reach over 100+F inside the toolbox while the truck is in the sun.
Will this lower the quality of the oil any? I know oils see temps much higher than this in the motor, but it would be flowing around, not sitting still in a plastic container.
Overall, I guess I’m asking if the constant fluctuation of temps, 50-60’s nights and 90+ days, will hurt the oil while it’s just sitting in the toolbox.
Am I overthinking? Is it really any different than a parked car with oil in the pan? The only difference being the oil is in a plastic bottle?
Thanks in advance
Re: Oil in the toolbox [Re: Floyd1] #5107689
05/17/19 01:05 PM
05/17/19 01:05 PM
Massachusetts
AuthorEditor Offline
Massachusetts
I almost never have less than a couple of quarts of oil in the trunk of my car, and that gets pretty hot on a summer day. I'm pretty sure that oil will be just fine as long as you use it up once in awhile. Make sure it is tightly capped.
Re: Oil in the toolbox [Re: Floyd1] #5107706
05/17/19 01:21 PM
05/17/19 01:21 PM
Cincinnati
Chris Meutsch Offline
Cincinnati
[quote=Floyd1]Hello folks:
Am I overthinking? YES Is it really any different than a parked car with oil in the pan? NO The only difference being the oil is in a plastic bottle? YES, PUT IT IN A ZIPLOC BAG.
[/quote
2005 Honda CR-V EX, 273k
Re: Oil in the toolbox [Re: Floyd1] #5107731
05/17/19 01:53 PM
05/17/19 01:53 PM
British Columbia, Canada
ecotourist Offline
ecotourist  Offline
That range of temperatures over any reasonable period is no issue but I would suggest you always use that oil for your next change. It's an easy enough thing to do and that way it won't sit there "forever". If nothing else, the container will stay in better shape.
2000 BMW 528i 5MT M Sport
2007 Honda Accord EX-L 4Door V6 6MT
Re: Oil in the toolbox [Re: Floyd1] #5107732
05/17/19 01:55 PM
05/17/19 01:55 PM
pa
FT92 Offline
FT92  Offline
pa
only problem I can see is the bottle leaking due to expansion in the heat , otherwise all should be good
Re: Oil in the toolbox [Re: Floyd1] #5107755
05/17/19 02:29 PM
05/17/19 02:29 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
I've got bottles of oil in an aluminum diamondplate TSC bed box that have been in there 20+ years. They have lasted just fine.
Re: Oil in the toolbox [Re: Floyd1] #5107764
05/17/19 02:45 PM
05/17/19 02:45 PM
Occupied Virginia
Bottom_Feeder Offline
Occupied Virginia
Originally Posted by Floyd1
Am I overthinking?
Yes. You're going to fit right in here.
Re: Oil in the toolbox [Re: Floyd1] #5107808
05/17/19 03:35 PM
05/17/19 03:35 PM
Katy, Republic of Texas
blupupher Offline
blupupher  Offline
As said, I would put them in plastic bags just in case (although the plastic bags would probably deteriorate before the bottles), and would rotate the oil in the box on the next oil changes if not used in a year or so.
That said, I carry a qt of oil under my hood by the firewall in my F150 for top off's (it uses 1 qt every 1500 miles or so). I have been refilling the same bottle for 3 years now and the bottle is still fine. It does feel a little softer than same bottles that are sitting on the shelf in my garage, but no leaking or cracking.
2018 Santa Fe: PP 10W-30/OEM/5k
2018 Soul: Mobil Super 5w-20/OEM/5k
2012 xB: M1 EP 0W-20/CQ Blue/5k
2002 F150: Magnatec 5W-20/Bosch D+/1yr
1994 VT1100: Peak 15W-40/Bosch D+/1yr
Re: Oil in the toolbox [Re: Floyd1] #5107818
05/17/19 03:45 PM
05/17/19 03:45 PM
California
DGXR Offline
DGXR  Offline
California
You're fine, just use up this oil at the next service and put some fresh bottles back in the tool box. If you do this rotation at every service it will never go bad.
I keep a jug of oil in my dirt bike gear bag and use that first when service is due. Replace the jug as needed. All good.
1995 Corvette coupe LT1 6-speed
2006 Tacoma 2.7 Base SR5 AC
1999 Yamaha YZ400FL
2003 Honda XR400R
Re: Oil in the toolbox [Re: Floyd1] #5107829
05/17/19 03:50 PM
05/17/19 03:50 PM
Suburban Washington DC
atikovi Offline
atikovi  Offline
I once left a small metal can of touchup paint on top of the dash in the Florida sun. The lid blew of and made a big mess on the dash and carpet. Don't think oil is that volatile.
Re: Oil in the toolbox [Re: Floyd1] #5107837
05/17/19 03:55 PM
05/17/19 03:55 PM
Apple Valley, California
Chris142 Offline
Chris142  Offline
your worried about 140F or so vs 230F+ on a running engine?
02 Wrangler traveler sae30
87 F250 Valvoline 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor Chevron sae30
Re: Oil in the toolbox [Re: Bottom_Feeder] #5107854
05/17/19 04:29 PM
05/17/19 04:29 PM
CO
JLTD Offline
JLTD  Offline
CO
Am I overthinking?
thumbsup Just use the oil for your next change and rotate stock. . .
I use the overseas manual to choose my oil viscosity.
Using AMSOIL
Hers: 2008 Jeep Liberty 149k, SS5w30/Amsoil
His: 2015 4Runner 55k, SS 5w20/Amsoil
Re: Oil in the toolbox [Re: atikovi] #5107943
05/17/19 07:01 PM
05/17/19 07:01 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Paint often contains thinners and solvents that will boil at relatively low temperatures.
Re: Oil in the toolbox [Re: atikovi] #5107985
05/17/19 08:08 PM
05/17/19 08:08 PM
ecotourist Offline
ecotourist  Offline
I used to carry gas line antifreeze (methyl hydrate) in a "single dose" plastic container in my glove compartment. I didn't think to take it out in the summer and later noticed that the originally flat bottom of the container was bulging. It didn't leak but there must have been some increased pressure.
Re: Oil in the toolbox [Re: Floyd1] #5108004
05/17/19 08:25 PM
05/17/19 08:25 PM
USA
Floyd1 Offline OP
Floyd1  Offline OP
USA
Thanks folks. This site makes me second guess everything, but that’s what keeps me coming back, am I right?
