Oil recommendation for 2014 2.5l Suburu Forester
by tomartomau - 08/23/19 11:32 PM
Castrol 5W50
by Snagglefoot - 08/23/19 11:29 PM
Camry Broke Down
by Nick1994 - 08/23/19 10:51 PM
Pumpkin Beer
by Capt - 08/23/19 09:26 PM
Possible bad Iridium plug
by Eric Smith - 08/23/19 08:57 PM
Is the 5.7gm engine still made brand new?
by motor_oil_madman - 08/23/19 08:19 PM
Motomaster OEPlus MOPH/MOCH Filters
by gamefoo21 - 08/23/19 07:29 PM
Man's best friend!
by Mad_Hatter - 08/23/19 06:53 PM
2007 Ford Fusion Cam Pics
by tig1 - 08/23/19 05:31 PM
Cloning a Lexus key
by Nayov - 08/23/19 04:23 PM
2011 GMC Acadia Shock/Strut Replacement
by panthermike - 08/23/19 03:49 PM
Confusion on oil to use on BMW 328i 2010
by goldenjava - 08/23/19 03:21 PM
ProSelect 27356 cut open
by Sayjac - 08/23/19 03:04 PM
Electrolux - Dryer reliability warning.
by pezzy669 - 08/23/19 02:37 PM
Microfiber Towels for different applications?
by Quattro Pete - 08/23/19 01:53 PM
Coated vs. painted rotors
by atikovi - 08/23/19 01:13 PM
New spark plugs, occasional misfire
by avacado11 - 08/23/19 12:34 PM
Boogyman, GeoffPD, CabanaBanana, tblack, goldenjava
69048 Registered Users
24 registered members (2002 Maxima SE, 4WD, Bellavita, Anduril, Bailes1992, 4 invisible), 725 guests, and 19 spiders.
Topics293,713
Posts5,045,454
Members69,048
Most Online3,532
Jul 30th, 2019
Home Air Conditioning / Furnace set up... #5104702 05/13/19 09:49 PM
G
gregk24 Offline OP
G
I will start off by saying am a bit naive when it comes to HVAC, so forgive me. I purchased our first home, a 1959 ranch, back in August 2017. We purchased it from a family that we know, so I do have a good deal of info / history of the home and items that were replaced over the years. The home was built without A/C which was common back in the 50's, so A/C was retrofitted some years later.
I am just curious, is this a normal set up? It appears that the furnace is on the bottom, with the A/C unit on top...I believe. I am wanting to at least know the basics of how our HVAC is set up. It appears both the furnace and the "indoor" a/c unit are 16 years old, while the "outdoor" A/C unit is around 6-7 years old.
2012 Honda Accord EX-L K24z3
58,xxx miles
PPPP 0w20 / Fram Ultra
2014 VW Jetta SE 1.8T ea888
48,xxx miles
Castrol Edge 0w40 / OEM filter
Re: Home Air Conditioning / Furnace set up... [Re: gregk24] #5104715 05/13/19 10:13 PM
M
MParr Offline
M
I’ve never seen anything like that. Most homes built in the 60s had The A/C and gas furnace as one unit on the outside. I have no idea what the building code is in FL. But, I’ll bet you won’t be able to go back with that setup, if you have to replace the furnace.
2019 VW Tiguan SE Now: Factory fill & OEM filter
2017 Ford Escape SE 2.0T Now: Motorcraft 5W30 SynBlend & NAPA Gold 1348
Re: Home Air Conditioning / Furnace set up... [Re: gregk24] #5104717 05/13/19 10:15 PM
G
Gebo Offline
G
That is the way mine is set up. Fan on bottom. Heat exchanger in middle. AC/HP on top.
Is the outdoor unit just AC? Or is it a heat pump? I don't what is normal in FL. In VA most of us use HP's.
'98 LEX LS400 295K
'02 4Runner 235K
'05 Lex LS430 85K
'07 Lex GX470 65K
SuperTech Oil
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
(Subject to Change as the Wind Blows)
Re: Home Air Conditioning / Furnace set up... [Re: gregk24] #5104729 05/13/19 10:35 PM
CDX825 Offline
Nothing out of the norm there.
AC evaporator coils always sit on the furnace or in the plenum above the furnace.
1984 Ford F250 6.9 Diesel C6 2WD Rotella T 15W40 NTZ Bypass Filter
1992 Mazda B2600 4x4 Pennzoil Platinum 5W30
1998 Ford Ranger 4x4 Pennzoil Platinum 5W30
Re: Home Air Conditioning / Furnace set up... [Re: gregk24] #5104744 05/13/19 11:04 PM
Z
zrxkawboy Offline
Z
Very common setup.
"Think of all the Ford owners who will someday want an automobile." John Dodge
Re: Home Air Conditioning / Furnace set up... [Re: gregk24] #5104746 05/13/19 11:10 PM
dishdude Offline
Is it me or does that flue pipe look a bit sloppy?
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI M1 Euro 0w-40 Wix WL10024
2019 Tiguan
Re: Home Air Conditioning / Furnace set up... [Re: dishdude] #5104748 05/13/19 11:12 PM
G
gregk24 Offline OP
G
As I have been poking around, I am noticing it is sloppy! I think I will have someone inspect it before the cold comes back and heat needs to be used. It doesn't make a good seal currently, and the flue pipe (which gets VERY hot) is sitting right next to some foam and other things that I think could be flammable.
58,xxx miles
48,xxx miles
Re: Home Air Conditioning / Furnace set up... [Re: gregk24] #5104760 05/13/19 11:40 PM
W
WhyMe Offline
W
i have the exact same furnace but mine is mounted horizontally . our was put in about 2004 or so. it seems to be a pretty common heater. its been pretty reliable ,but its not consider efficient these days
Re: Home Air Conditioning / Furnace set up... [Re: CDX825] #5104761 05/13/19 11:40 PM
Skippy722 Offline
Both mine and my parents have the furnace unit on top and the AC on bottom. Both are downdraft style units though.
2016 Chrysler 300S v6
2018 Dodge Grand Caravan GT
Slight Mopar obsession
Re: Home Air Conditioning / Furnace set up... [Re: gregk24] #5104774 05/14/19 12:37 AM
double vanos Offline
Last winter I was checking out how the furnace in my old house was doing and I (like gregk24 ) noticed that the flue was hot enough to cook pork chops. Concerning to say the least so I called in an a/c & heating man to have a look see. He found that the furnace was over fueling and cut back the gas and opened up the air to get it to a normal ratio. That stopped the super heated vent pipe and increased the heaters performance. What he did tell me was that, although the furnace had little wear and tear, it was old enough to be obsolete by about 3 or 4 generations, being only about 80% efficient on a good day. Before he adjusted the fuel the attic was warmer than the house. Now the attic is cool and the house gets warmer than before. Gas bill went down too. Maybe Greg’s furnace is doing what mine was.
Sabine Schmitz is the Queen of the 'Ring; Svetlana Kapanina is the Queen of the SKIES...
Re: Home Air Conditioning / Furnace set up... [Re: gregk24] #5104826 05/14/19 06:06 AM
dnewton3 Offline
Global Moderator
Global Moderator
That is totally normal for an "upflow" configuration; this is the most typical installation for most homes.
There are also horizontal left/right and also downflow choices. Some units are multi-poise, others are purpose built.
Not the cleanest installation I've ever seen, but not the worst, either.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: Home Air Conditioning / Furnace set up... [Re: gregk24] #5104833 05/14/19 06:19 AM
B
BMWTurboDzl Offline
B
Typical gas furnace set up.
The furnace contains the blower motor which pushes air through the system.
The interior portion of the AC contains the evaporator coil. This is where liquid refrigerant converts into a gas as it absorbs heat from the air being moved by the blower motor.
The exterior portion of the AC system contains the condenser. This is where gaseous refrigerant releases the heat it picked up from evaporator coil and is compressed, via the compressor, back into a liquid state to repeat the process.
435i
Re: Home Air Conditioning / Furnace set up... [Re: gregk24] #5104935 05/14/19 08:44 AM
P
pandus13 Offline
P
OP,
Couple notes:
-keep gas burner sensors clean (ash + dust)
-keep motor cage dust free (dust bunnies)
-choose a non-restrictive air filter and replace it when dirty (1-6 months, depending on your area)
-every couple years, clean the outside AC fins/"radiator"
16 Golf SportWagen
13 Mazda5
08 Yaris
04 Elantra
95 accent
95 mystique
97 concorde
Re: Home Air Conditioning / Furnace set up... [Re: gregk24] #5104946 05/14/19 08:56 AM
E
EricG Offline
E
As noted above, it's a typical upflow system, see below for a simple explanation!
https://www.alpinehomeair.com/kitbuilder/default.cfm
11 F150 4x4 5.0
11 Cadillac SRX
03 Century
l
Re: Home Air Conditioning / Furnace set up... [Re: gregk24] #5105187 05/14/19 02:04 PM
F
Fitter30 Offline
F
Normal setup except for the flue pipe normally not run all the way to the furnace but still it's ok. The flue pipe is called b vent normal clearance is 1" and should be stamped on pipe just under the manufacturer name. Model number on the furnace is under the top loovered cover on either side and might have a born on date listed and the serial. You can Google the manufacturers and how the read their serial numbers for their age. Furnace is 80% efficience.
