Patman
Staff member
Originally Posted by Dupree
with all due respect, if no one notices a small spread on hths or it "doesn't matter" why are we even spending time on this forum? If the minute nuances about oil and learning more and trying to find the best whether its best performing for our specific parameters and things we want to accomplish, or to find the cheapest oil that will function to our standards... Then why are we even on here? Turn off the computer buy the cheapest oil on sale and go drink a beer. It matters to us because its a hobby maybe it doesn't matter significantly. But the fact is I still posted looking if someone had that spec whether a 2.9 or 3.2 will make a significant difference isn't the answer I seek.
Just because we can't notice a difference doesn't mean it's not making a difference though. For instance, let's say me running a 3.5 HTHS oil in my Corvette allows the engine to hit 400,000 miles before it needs rebuilding, but using a 3.0 HTHS oil causes it to need rebuilding at 300,000 miles. So even though I don't notice the difference in day to day operation, it is making a difference in the long run. It's just the same as how some oils might keep an engine cleaner for longer compared to others, you won't notice that by the seat of your pants, but many years later you'll notice it if you pull off a valve cover and look inside (and that cleaner engine will run better, get better MPG, make more power, burn less oil, etc.) So in other words, oil does matter.
