I know how everyone likes repair pictures, so here's a couple from today's job. 107k on the car, no OCI info but it looks relatively well maintainrd. The car had all the symptoms: correlation codes, extended crank, poor power etc. Here's what I found when I got her all torn down:
The old chain was stretched about 1/8 of an inch and the tensioner was maxed out. I didn't get a picture of the new tensioner, but it only ratcheted about 2 notches when the pin was pulled. It got new chains, guides, tensioner, cam bridge, and spool valve. The cam bridge had failed as well, there is a small metal screen that blows out and can get lodged in other oil passages destroying the cams. Luckily, I found the screen and removed it.
And people love European cars so much...
