I have a CV490-27532 that I just did a head gasket on. When reassembling, I can't get the exhaust valve closed. The hydraulic lifter is not allowing it. I let it sit over night to see if it would bleed off but no luck. The service manual says these are unserviceable. I've never dealt with one of these. I'd like to take a look at it. Can I just pull it out of the hole from the top? Maybe it's dirty?
Thanks
Thanks
