Deer 1....My Avalon 0
by ZZman - 05/28/20 03:21 PM
Auto Dealers Supplies?
by cknight49090 - 05/28/20 03:09 PM
interesting video reg vs premium
by raaizin - 05/28/20 02:55 PM
Discount Tire Direct FLASH SALE
by Mr Nice - 05/28/20 02:42 PM
2021 Acura TLX Sports
by buster - 05/28/20 01:36 PM
Honda GC vs GS engines?
by Avery4 - 05/28/20 01:10 PM
Advanced auto parts
by Fitter30 - 05/28/20 12:52 PM
Is there a best time to switch to synthetic oil?
by Jgelack - 05/28/20 12:37 PM
Alignment good then bad
by Barkleymut - 05/28/20 11:56 AM
What's in the Box?
by BeerCan - 05/28/20 11:31 AM
High Gloss product for Silver car?
by tc1446 - 05/28/20 11:15 AM
Home HVAC advice?
by Ed_Flecko - 05/28/20 10:43 AM
Briggs decompression.
by BSeward - 05/28/20 10:34 AM
1970 Cub Cadet Model 73 with Cizek Mower
by Phishin - 05/28/20 10:19 AM
Need Jacks-Returned recalled HF last week.
by 1978elcamino - 05/28/20 10:01 AM
WSS-M2C200-D vs -D2 vs D3
by mossietheno1 - 05/28/20 09:41 AM
Three things you never sell...
by DriveHard - 05/28/20 09:34 AM
Motorex Supergliss 100K
by Taildragger - 05/28/20 07:30 AM
Dewalt titanium drill bit set
by Donald - 05/28/20 07:29 AM
lr08, BlackMagicVarian, Mustache, mountaingoat, Alegrianyc
71546 Registered Users
112 registered members (2whlgeezer, 928, 4WD, 86cutlass307, 87sammy, 69Torino, 6 invisible), 2,425 guests, and 45 spiders.
Topics305,982
Posts5,284,095
Members71,546
Tire leak with new wheels. What would YOU do? #5086116 04/25/19 04:20 PM
L
Lolvoguy Online Shocked OP
OP Online Shocked
L
Some of you may recall that on the Lexus below, I installed a brand spankin' new set of Lexus F Sport wheels last summer.
All has been going well with them. Considering the car only has about 50 k miles the wheels REALLY make the car look MUCH newer than it is.
My problem is with one of my rear tires. I seem to have a SLIGHT leak in it which is causing a 5 PSI leak over a one month period.
I've closely followed all the other tires and they all seem to be holding PSI's relatively consistent.
I don't think it's the wheels that are are fault, but maybe the bead? or maybe the TPMS? or the tire has a nail in it? Not sure really
Considering the leak is so small, I almost doubt I'd be able to find it with soapy water in a spray bottle.
Should I have this tire taken in to have the leak repaired?
I could just keep topping it off monthly and in doing so prevent any scratches etc. caused by the tire shop.
I'd also save the money since we hardly drive this car at all (about 3k miles per year).
What are your thoughts?
06 Lexus IS350- Wife
88 BMW 325is- Mistress
Say "no" to Turbo!
Re: Tire leak with new wheels. What would YOU do? [Re: Lolvoguy] #5086120 04/25/19 04:26 PM
A
Audios Offline
A
Spray it down with soapy water and trace the leak. Take the valve cap off and check that also, sometimes the valve cores leak.
2002 VW Golf TDI-T5 10/30
2007 Mercedes GL320 CDI-T6 5/40
2005 BMW M3 BMW-Twin Power 10/60
2003 BMW M5-M1 15/50
1998 BMW M3/4/5-M1 10/40
Re: Tire leak with new wheels. What would YOU do? [Re: Lolvoguy] #5086121 04/25/19 04:26 PM
F
FordBroncoVWJeta Offline
F
I bet you would find it if you took it off the car and sprayed it with some soapy water or put it in a tank with some water. There is probably a small nail somewhere or a small bead leak. You will find it IF you put in a little time.
2017 Volkswagen Jetta 1.4T - 2015 Honda CRV 2.4 - 2012 Volkswagen Jetta 2.0 - 2007 Chevy Trailblazer 4.2 - 2003 Ford Taurus 3.0 Vulcan
Re: Tire leak with new wheels. What would YOU do? [Re: Lolvoguy] #5086123 04/25/19 04:29 PM
T
Traction Offline
T
I would be looking for a hole. Screws, and nails start off as tiny leaks, then the hardware keeps getting driven in deeper and leak more. Spray it down with soapy water, and it might be obvious where the problem is. Then decide what to do.
Certified Tire Service Instructor since 2009
50 Chevy Fire Truck
13 Tahoe Pursuit
97 C5 Corvette
00 BMW M Roadster
02 Camry
12 Camry
81 Camaro
55 Chevy C4
Re: Tire leak with new wheels. What would YOU do? [Re: Traction] #5086135 04/25/19 04:43 PM
MrMoody Offline
Yes, what they said, and add that a rear tire leaking almost always has something in it: the front tire rolls over it and kicks it up.
2018 Hyundai Kona 1.6T DCT
2006 Pontiac (Holden) GTO AT
2001 Pontiac Grand Prix GT 3.8 NA (beater)
2005 Toyota Matrix FWD (ultra beater)
"Fob" and "Noack" are not acronyms.
Re: Tire leak with new wheels. What would YOU do? [Re: Lolvoguy] #5086149 04/25/19 05:00 PM
das_peikko Offline
There was a recent thread where somebody discovered a barcode sticker inside the tire right where the sealing bead is; maybe that's your problem?
Re: Tire leak with new wheels. What would YOU do? [Re: Lolvoguy] #5086180 04/25/19 05:26 PM
B
benjy Offline
B
cast wheels can have a bit of porous metal. the cure for my new reproduction 64 knockoffs was a coat of shellac in them on the inside, it worked!
Re: Tire leak with new wheels. What would YOU do? [Re: Lolvoguy] #5086237 04/25/19 06:17 PM
CT8 Online Content
Online Content
Pull the wheel off of the car fill it with max air pressure and dunk the tire in a tank and watch for bubbles.
2015 F150 2.7
2018 F350 6.2
Re: Tire leak with new wheels. What would YOU do? [Re: MrMoody] #5086238 04/25/19 06:18 PM
T
Traction Offline
T
I have fixed hundreds of flats, and more often than not it is the right rear tire. Most of the debris is on the right side of the road, and the front tire stands it up just in time. You run over stuff all of the time and nothing happens. Just try to not hit a bungee cord, they make a mess.
50 Chevy Fire Truck
13 Tahoe Pursuit
97 C5 Corvette
00 BMW M Roadster
02 Camry
12 Camry
81 Camaro
55 Chevy C4
Re: Tire leak with new wheels. What would YOU do? [Re: CT8] #5086267 04/25/19 06:34 PM
A
atikovi Offline
A
Most people don't have tanks but they do have bathtubs.
Re: Tire leak with new wheels. What would YOU do? [Re: atikovi] #5086296 04/25/19 06:50 PM
Cressida Offline
Agree that most people do not have a tank large enough for a tire.
I think my wife will not be happy if she sees me lugging a 16" mounted tire through the house headed toward the bathroom. Similar to when you try and put your valve covers in the dishwasher.
Re: Tire leak with new wheels. What would YOU do? [Re: Lolvoguy] #5086312 04/25/19 06:58 PM
E
eljefino Offline
E
Who mounted them? Road hazard coverage generally includes bead leaks. And if not they may still warranty their work for free somehow.
Re: Tire leak with new wheels. What would YOU do? [Re: Lolvoguy] #5086323 04/25/19 07:06 PM
E
Elkins45 Offline
E
I tubed the rear tires of my mower but one of them failed. Doing the work involved a horrible wrestling match with screwdrivers and crowbars, so when the tube failed I bought two new tires. I’ve only mounted one, and won’t mount the second one until the other tube fails. I just about knocked myself out when a pry bar slipped and whacked me in the head.
When I mounted the new one I couldn’t get the bead sealed. I had to resort to the lighter fluid explosion method to get it seated and I thought it was going to melt itself because the difference between too little fluid and too much fluid is surprisingly small.
In retrospect I would gladly have paid someone to do the work. I have one of those Harbor Freight manual tire mounters, but a mower wheel won’t go over the center post because it just has a 1” hole for a keyed shaft. Mounting tires isn’t for the weak!
Re: Tire leak with new wheels. What would YOU do? [Re: Lolvoguy] #5086401 04/25/19 08:12 PM
M
mk378 Offline
M
Find the leak first. The best way is to remove the wheel and submerge it. There are some rim leaks that will only leak when the car is parked with the bad spot down, so the tire is flexed from the weight. Those are hard to find.
Re: Tire leak with new wheels. What would YOU do? [Re: atikovi] #5086451 04/25/19 08:56 PM
dishdude Offline
Maybe a trashcan? No way I'm putting a tire in my bathtub.
2018 Challenger SRT 392 PUP 0w-40 Wix 57899XP
2018 GTI M1 Euro 0w-40 Wix WL10024
2019 Tiguan Castrol Edge Pro 0w-20
