*Remove the Air Box & Air Intake Tube.
*Remove the 2 13mm headed bolts retaining the Radiator to the header panel.
*Lean the Radiator back.
*Remove Condenser Shroud/Baffle.
*Unhook both Trans Cooler lines.
*Remove the 10mm headed bolt from the Condenser Line stay bracket.
*Remove the 13mm headed nut holding the suction & liquid line to the condenser.
*Unclip the condenser from the radiator & lift the condenser up between the radiator & header panel support bar.
It should take you @ 1 hour the first time you do it this way! (From raising the hood to drawing a vacuum on the system), Then you will have it down to 30 after a couple more times!
I for one......Love these, It pays 4.5 hours NOT including Recovery, Evac, & Recharge. While it's sucking down.....I pull another job in & get started on that!
Of coarse this doesn't matter if your getting paid by the hour or are on Salary, If you work in a busy shop.....Maybe it's time to negotiate a fair Flat Rate?
If you work in a slow shop, Maybe it's time to seek employment elsewhere.
If your struggling with repairs more often than not.....You either need training, Pursue a different career path, Or a change of scenery(work elsewhere).
In closing.....Lay off the brand bashing, Your a professional right? Act like it!
***I don't have the experience, tools or training to work on European cars, So I DON'T work on them!!! I don't like to repair Nissan's because the lack of service/repair information available in Mitchell & AllData. Some Non-Ford based Mazda's can be the same way!
