Freedom 95 doesn't keep house worm long
by laoshanren - 10/22/19 11:36 PM
2006 Altima 2.5 oil leak
by LeakySeals - 10/22/19 10:34 PM
fishing licenses on boats
by motor_oil_madman - 10/22/19 10:16 PM
Tokyo Motor Show 2019
by PimTac - 10/22/19 10:14 PM
More Quick Chargers
by Snagglefoot - 10/22/19 09:48 PM
'08 Chrysler Sebring Test Drive
by Fifth87 - 10/22/19 08:42 PM
Testing old coolant
by ARB1977 - 10/22/19 08:20 PM
Pennzoil Maximum Power 0W30
by HoosierJeeper - 10/22/19 07:44 PM
Bought a unknown air rifle and need help.
by jakewells - 10/22/19 07:26 PM
What happens to used cars that don't sell?
by WhyMe - 10/22/19 07:11 PM
No spark
by Eric Smith - 10/22/19 06:57 PM
So you need a new engine?
by Skippy722 - 10/22/19 06:40 PM
Super Hot Fish at local fish monger restaurant
by Cujet - 10/22/19 06:39 PM
Mobil 1 5w30 SN+ D1G2 VOA
by donnyj08 - 10/22/19 06:07 PM
Shell Nitro+ Gasoline in older cars
by Building3 - 10/22/19 05:43 PM
flyyamata, laoshanren, Vincenze, Alex_CB300R_ABS, TSOC
69652 Registered Users
32 registered members (bubbatime, burla, ArrestMeRedZ, carlprop, AC1DD, 3 invisible), 818 guests, and 25 spiders.
Topics296,361
Posts5,096,325
Members69,652
Most Online3,532
Jul 30th, 2019
4" grinder . Flap vs solid #5083908 04/23/19 04:12 PM
W
WhyMe Online Content OP
OP Online Content
W
been a while since i have bought a grinding wheel for my 4" hand held. So i noticed that there are flap wheels now. reading about them they seem to be better than the old style. So is this true? i use mine mainly for sharpening my lawnmower blade .
Re: 4" grinder . Flap vs solid [Re: WhyMe] #5083914 04/23/19 04:18 PM
das_peikko Offline
If you're going to be using them to sharpen mower blades, you'll want the flap disc most definitely.
Re: 4" grinder . Flap vs solid [Re: WhyMe] #5083921 04/23/19 04:24 PM
B
Blkstanger Offline
B
I prefer the flapper discs.
99 Jeep WJ 4.7 200,000mi. Maxlife 10w30, Fram Ultra.
15 Ford Escape S 2.5
Re: 4" grinder . Flap vs solid [Re: WhyMe] #5083933 04/23/19 04:31 PM
justintendo Offline
stick with a good stone for fine work like sharpening. the flap wheels work well for surface prep like finish removal or smoothing metal/removing scratches.
13 escape 2.0 awd mobil 1 10w30ep
08 fusion 2.3 mtx mobil 1 5w30ep/redline mt90
96 f150 4.9 2wd mtx mobil 1 10w30hm/redline ps fluid
99 kaw zrx 1100 redline 10w40
many husqvarnas 5w40 t6 rotella
Re: 4" grinder . Flap vs solid [Re: WhyMe] #5083987 04/23/19 05:24 PM
M
maxdustington Offline
M
Flap wheel: More expensive, less durable, much better finish in the right hands.
97 GMC RCLB K2500LD L30/4L60
Re: 4" grinder . Flap vs solid [Re: WhyMe] #5083991 04/23/19 05:31 PM
T
tig1 Offline
T
There are uses for both.
2007 Ford Fusion 248,000 miles
M1 5-20HM
2017 Ford Fusion 79K
M1 0-20EP
M1 ATF and Valvoline LV
M1 10-30 in all OPE
MC filters
Re: 4" grinder . Flap vs solid [Re: WhyMe] #5084002 04/23/19 05:48 PM
A
andyd Offline
A
I sharpen mower blades on the bench grinder if they're chewed up. Sharpening is a less is more thing grin2
Thick oil is better grin2
Re: 4" grinder . Flap vs solid [Re: WhyMe] #5084051 04/23/19 06:44 PM
double vanos Offline
I just used a good file to sharpen my mower blades.
Sabine Schmitz is the Queen of the 'Ring; Svetlana Kapanina is the Queen of the SKIES...
Re: 4" grinder . Flap vs solid [Re: WhyMe] #5084068 04/23/19 06:56 PM
tom slick Offline
I prefer a flap wheel for sharpening mower blades and most other grinding tasks. If you need something flat with crisp edges then a hard grinding disc works better.
You get what you pay for...
So keep in mind how much you paid for this advice.
Re: 4" grinder . Flap vs solid [Re: WhyMe] #5084080 04/23/19 07:04 PM
T
Trav Offline
T
Flap
Re: 4" grinder . Flap vs solid [Re: WhyMe] #5084112 04/23/19 07:33 PM
J
JLawrence08648 Offline
J
Wow! I can't believe the number of flap disk recommendations for sharpening mower blades. I use a grinding disk on my power hand grinder for sharpening blades. I only use the flap disk for removing rust from equipment. For removing rust, I use a wire brush on a grinder then switch grinders to the flap disk.
Re: 4" grinder . Flap vs solid [Re: WhyMe] #5084128 04/23/19 07:45 PM
R
Rand Offline
R
I have always used a metal or fast metal wheel on the angle grinder for sharpening mower blades.. usually they are pretty far gone from many hours of nasty field mowing, hitting anthills etc.
How is the flap wheel better?
Re: 4" grinder . Flap vs solid [Re: WhyMe] #5084138 04/23/19 07:59 PM
spasm3 Offline
I use a angle grinder with grinding wheel not a flapper for mower blades.
13 elantra 78k 5w30 synpwr
17 mazda cx-5 16400 miles m1 0w40
Re: 4" grinder . Flap vs solid [Re: WhyMe] #5084188 04/23/19 09:09 PM
tom slick Offline
Flap discs are more aggressive and load up less yet leave a smoother finish. As a bonus they are significantly quieter.
Re: 4" grinder . Flap vs solid [Re: WhyMe] #5084190 04/23/19 09:12 PM
Dinoburner Offline
Tried both and 4in stone is faster esp on bushhog blades. Removing the 22in blade on the mower and draining the oil at the same time works here. Also balancing blades is important.
77 Chev stepside 454 Casteroil syn
95 GMC 4wd mobil syn
2016 Equinox LTZ V6 dealer
Kubota L5030 T6
