10K Mile Oil Change - 1.8L TSI Jetta
by SandCastle - 09/21/19 08:08 AM
Pennzoil Platinum 10w30 HTHS
by donnyj08 - 09/21/19 07:56 AM
Mortality stats
by CourierDriver - 09/21/19 07:38 AM
Is it time for a brake fluid flush?
by A_A_G - 09/21/19 03:22 AM
Take that!
by Mad_Hatter - 09/21/19 03:18 AM
02 Honda Accord V6 Aluminum Radiator
by David1 - 09/21/19 01:55 AM
Difinitive Answer for SCA, Silicates, and Diesels
by ErikLeifson - 09/20/19 11:11 PM
Quart bottle cap
by maverickfhs - 09/20/19 11:11 PM
Dexron vi
by charmer37 - 09/20/19 10:22 PM
Deposit Shield
by TheLawnRanger - 09/20/19 10:00 PM
Atlanta Airport - Excellent History
by ctechbob - 09/20/19 09:56 PM
Angry at Walmart service center
by Jetsfan421 - 09/20/19 09:52 PM
Fuel System Cleaners
by ZeeOSix - 09/20/19 09:22 PM
Milwaukee 1/2 impact
by wensteph - 09/20/19 09:10 PM
Windows 7 Use After Support Ends
by ZeeOSix - 09/20/19 08:29 PM
Walmart Poulan chainsaws 50% off
by bubbatime - 09/20/19 08:10 PM
Vintage "Ultra Lube" Grease (show & tell)
by GaryPoe - 09/20/19 08:09 PM
Impact driver for auto work?
by Klutch9 - 09/20/19 07:27 PM
2000 Honda CR-V Ex transmission fluid?
by taztheman - 09/20/19 05:36 PM
Pennzoil Launches Four New Motor Oils
by jayjr1105 - 09/20/19 05:25 PM
TungGT, ErikLeifson, Kinnes25, Bamajoe, Aleksandar
69347 Registered Users
75 registered members (ArrestMeRedZ, alarmguy, 69GTX, AnthemBassMan, askani79705, 12 invisible), 1,705 guests, and 27 spiders.
Topics294,850
Posts5,067,960
Members69,347
Most Online3,532
Jul 30th, 2019
Page 1 of 3 1 2 3
Why would 10w burn more than 5w? #5081649 04/21/19 11:57 AM
D1dad Offline OP
I posted awhile back about my 09 Nissan 2.5 using oil and always has. I have always ran 5w30, all variety but mostly synthetic. At the advice of some members I opted to use 10-30, (M1HM). I’m a hair less than 500 miles on this oil and the car has burnt a half quart. The 5-30 usually used, give or take 3/4 to a quart every 1-1500k. I’m stumped?
Re: Why would 10w burn more than 5w? [Re: D1dad] #5081680 04/21/19 12:29 PM
JohnnyJohnson Offline
It doesn't matter what oil weight you use your rings never seated.
2004 Corolla 135530
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 76414
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: Why would 10w burn more than 5w? [Re: D1dad] #5081682 04/21/19 12:30 PM
T
Triple_Se7en Offline
T
Quote
What brand of 5w30 did you use?
Have you any prior experience with M-1 in this engine?
19 Hyundai SantaFe 2.4GDI Castrol Edge 5w30 / NAPA Mann-Hummel filter / 6oz Liqui-Moly Treatment
04 Colorado 3.5 Castrol Edge 0W40 Euro & K&N filter
03 Malibu 3.1 QS / Valv Syn 5w30 mix Fram EG filter
Re: Why would 10w burn more than 5w? [Re: JohnnyJohnson] #5081685 04/21/19 12:32 PM
O
OVERKILL Offline
O
This does sound likely. If it has consumed since day 1, there's nothing an oil is going to do to stop it, as there is likely something wrong with the engine, like say ring seating, as noted.
2016 Grand Cherokee SRT - Ravenol SSL 0w-40, FRAM Ultra
Re: Why would 10w burn more than 5w? [Re: D1dad] #5081703 04/21/19 12:54 PM
N
NormanBuntz Offline
N
Prior consumption of 3/4 to a quart every 1,000 or 1,500 miles would be considered acceptable by many car makers. That said, if you switched brands and viscosity, let the new oil settle in for at least one full OCI. Depending on the result, you may want to go back to your old brand.
Firesign Theater: "Heavy on the 30 weight, Mom."
2013 Honda Accord LX, 61K, 2nd owner
2007 Honda Ridgeline RTS, 92K, 1st owner
2007 Infiniti M35, 114K, 1st owner
Re: Why would 10w burn more than 5w? [Re: D1dad] #5081708 04/21/19 12:58 PM
W
Whimsey Offline
W
Is this the first oil change to Mobil 1? My experience over the years is going to Mobil 1 after using another oil brand I've experienced "some" oil usage. With the second oil change with Mobil 1 the oil usage stopped. Since you've been using oil all along I don't think the Mobil1 will stop it but at worst it'll improve from what you are experiencing with the first Mobil 1 oil change with the second Mobil 1 oil change.
Whimsey
Re: Why would 10w burn more than 5w? [Re: D1dad] #5081713 04/21/19 01:02 PM
PimTac Offline
If it has been doing this since day one with no possible intervention by Nissan then I would use a less expensive oil from here on out.
2017 Mazda CX5
Havoline Pro DS 0w20
Roki OEM filter.
Re: Why would 10w burn more than 5w? [Re: NormanBuntz] #5081714 04/21/19 01:03 PM
Originally Posted by NormanBuntz
Prior consumption of 3/4 to a quart every 1,000 or 1,500 miles would be considered acceptable by many car makers. .
Because they support their wallets not their customers or the products they build.
2004 Corolla 135530
2006 Duramax 76414
Re: Why would 10w burn more than 5w? [Re: Whimsey] #5081727 04/21/19 01:15 PM
4WD Offline
These discussions are foreign to me … used M1 for decades and no consumption in anything
Re: Why would 10w burn more than 5w? [Re: D1dad] #5081730 04/21/19 01:22 PM
A
andyd Offline
A
I drove my first 528e from 150K miles to 350 Kmiles with an oil leak that used a qt every 1500 miles. That is when I discovered Supertech dino. grin2
Thick oil is better grin2
Re: Why would 10w burn more than 5w? [Re: PimTac] #5081798 04/21/19 02:41 PM
demarpaint Offline
Me too. No oil is fixing improperly seated rings.
God Bless Our Troops
Re: Why would 10w burn more than 5w? [Re: D1dad] #5081834 04/21/19 03:10 PM
G
Gebo Offline
G
I agree with some (NormanBuntz and Whimsey) about giving it an OCI or two to settle down.
'98 LEX LS400 295K
'02 4Runner 240K
'05 Lex LS430 85K
'07 Lex GX470 65K
Shell Gas and Truck
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Why would 10w burn more than 5w? [Re: D1dad] #5081852 04/21/19 03:28 PM
DONWATERS Offline
I have experienced oil comsumption and RMS leaks in several cars after using M1 high mileage. These are cars with high mileage. What used to be a wettish area below the RMS became a line of oil. I have a bunch of it and as I use it up I am switching to plain old shell clean engine dino oil from HD for $10 for 5 quarts or other brand synthetic stuff on sale.
Re: Why would 10w burn more than 5w? [Re: D1dad] #5081899 04/21/19 04:23 PM
K
Kamele0N Offline
K
At least here in EU 5w oils are in 99.9% synthetic (grp. III and more)....and 10w are most often semisyn (XHVI...)
We dont know 5w conventional oils...unless they are imported from over the pond (B&S....)
Maybe thats your case here...
Re: Why would 10w burn more than 5w? [Re: D1dad] #5081961 04/21/19 05:49 PM
caprice_2nv Offline
The first time I tried high mileage oil in my Caprice (m1 5w30 because it was the start of winter) it seemed to use more the first thousand miles. The last 2k miles it seemed to go back to normal. First time I've ever really noticed this phenomenon.
84 Olds Cutlass - 350 Olds
83 Chevy Caprice - 305 Sbc
79 Honda CX500
Page 1 of 3 1 2 3
