Originally Posted by burla
First, it would have to be a spun microglass filter, anyone who thinks micron ratings hold up with paper filters I have some great swamp land to sell you that will make you a million dollars, and you will be the one to buy it, and give me a cash tip for doing so. Then you want to look at Flow, entry holes and cheese grater design really allows for good flow. Then, you might want a thick loose media that will flow great and hold contamination. The only one I know that does all of that is Royal Purple.
You might want to do a bit more research before claiming the "only one" capable of all that is the RP.
So if you consider all of that, pick a spun microglass that suits you better if you are looking for other features over what RP has to offer. Wix XP tighter thinner media maybe give a better micron rating at first ...
How can any filter rated at 50% @ 20u give a "better micron rating at first" ... ??
