Pennzoil GF-6 & Low Viscosity Q&A
Click here to participate in the Pennzoil Q&A
New wheels and tires on our VW Passat
by SLO_Town. 06/25/19 11:28 AM
Absorber drying chamois
by Redright9. 06/25/19 10:36 AM
Mobil Delvac Rebate
by GMguy84. 06/25/19 10:29 AM
Sister wants an Audi q5
by 1978elcamino. 06/25/19 10:21 AM
Annual Father/Son Varmint Hunting Trip
by 2015_PSD. 06/25/19 09:53 AM
2019 Subaru Impreza anyone?
by sw99. 06/25/19 09:46 AM
Unable to Register
by ABursell. 06/25/19 09:27 AM
01 Tahoe rotors
by mjk. 06/25/19 09:04 AM
Anyone Using DualLiner Pickup Truck Bed Liner?
by LoneRanger. 06/25/19 08:29 AM
Hard tonneau?
by buck91. 06/25/19 08:20 AM
What's your DIY disaster?
by newbe46. 06/25/19 08:10 AM
Synchromesh: Valvoline Vs. Pennzoil
by IndyFan. 06/25/19 07:27 AM
World’s most valuable Ford Fusion
by LotI. 06/25/19 06:45 AM
Sprinter Gen 2 oil
by Ammofirst. 06/25/19 06:39 AM
Filter Cross over to car chart anywhere
by 97K15004WD. 06/25/19 05:47 AM
Lubricant for medical oxygen concentrators ?
by KiwiAz. 06/25/19 01:12 AM
Polaris Lab/Oil Analyzers Fuel Dilution
by Talent_Keyhole. 06/24/19 11:55 PM
Ecotec filter failure - w/ pics
by san123chez. 06/24/19 11:37 PM
Blue_moon, jim_russ, johnmichael, TIMPEHL, MrBluesky14
68482 Registered Users
107 registered members (2015_PSD, 2011335d, 1978elcamino, AandPDan, ad244, 53' Stude, 9 invisible), 2,184 guests, and 27 spiders.
Topics290,949
Posts4,995,630
Members68,482
Most Online2,967
Mar 10th, 2019
Page 1 of 4 1 2 3 4
Tire Pressure #5066312
04/06/19 05:47 PM
04/06/19 05:47 PM
MIchigan
Warstud Offline OP
Warstud  Offline OP
MIchigan
I know your suppose to go by the placard but this the second time now that a co-worker has told me they fill it to the max pressure. Does any here fill it to the max for normal driving?
Re: Tire Pressure [Re: Warstud] #5066325
04/06/19 06:02 PM
04/06/19 06:02 PM
MN
oil_film_movies Offline
MN
Re: Tire Pressure [Re: Warstud] #5066330
04/06/19 06:05 PM
04/06/19 06:05 PM
San Antonio, TX
das_peikko Offline
das_peikko  Offline
San Antonio, TX
My car's placard says 33 PSI. The tire manufacturer says 44 PSI at max load. From my experience, 40 PSI is perfect!
I use to run 35 PSI all the time, but 40 PSI sure tightens the car up! smile
Re: Tire Pressure [Re: Warstud] #5066333
04/06/19 06:08 PM
04/06/19 06:08 PM
Georgia
RDY4WAR Offline
RDY4WAR  Offline
Georgia
It was discussed very recently in great detail.
My placard says 30 psi. Max tire pressure is 44 psi. I run 40 psi. The ride is much better, and I haven't observed any abnormal wear.
"He who is without oil, shall throw the first rod." - Compressions 9:1
Re: Tire Pressure [Re: RDY4WAR] #5066345
04/06/19 06:24 PM
04/06/19 06:24 PM
Glendale, Arizona
billt460 Offline
billt460  Offline
Glendale, Arizona
That's what I run as well. 40 to 42 PSI.
Re: Tire Pressure [Re: Warstud] #5066354
04/06/19 06:37 PM
04/06/19 06:37 PM
Phoenix, AZ
Nick1994 Offline
Nick1994  Offline
Phoenix, AZ
I run a little over too. Gives me some buffer room if I forget to check it for a month or two. I think my Sonata wants 33 and I always put in 37.
2015 Hyundai Sonata 2.4L 97k STP Synthetic HM 10w30 & OEM
2000 Toyota Camry 2.2L 234k Mobil Super HM 10w40 & Fram Ultra
1996 Jeep Cherokee 4.0L 149k Mobil 1 HM 10w40 & Fram Ultra
Re: Tire Pressure [Re: Warstud] #5066359
04/06/19 06:41 PM
04/06/19 06:41 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
I run the placcard pressure, that's what the OEM tested and arrived at. The tire manufacturer has no idea what vehicle the tire is going on, they simply state the pressure at which the maximum weight rating of the tire is achieved, which is likely wholly irrelevant to the vast majority of vehicles the tire is a proper fit for.
2016 Grand Cherokee SRT - Ravenol SSL 0w-40, FRAM Ultra
Re: Tire Pressure [Re: Warstud] #5066362
04/06/19 06:42 PM
04/06/19 06:42 PM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
Guess I am an anomaly. My car calls for 35 front, 42 rear. I run 33 front, 35 rear. The lower the pressure, the larger the contact patch, the more grip you have*.
*up to a point.
Mighty Mouse Tech
BMW Diagnostic and Alignment Tech
2010 Civic Si Motul 0W40, Redline MTL
2013 BMW 135i M Sport Edition Motul 0W40, Redline MTL
Re: Tire Pressure [Re: OVERKILL] #5066364
04/06/19 06:44 PM
04/06/19 06:44 PM
Ajax,Ontario, Canada
Pelican Offline
Pelican  Offline
Dead Right !
Re: Tire Pressure [Re: Warstud] #5066367
04/06/19 06:50 PM
04/06/19 06:50 PM
Marshfield , MA
andyd Offline
andyd  Offline
Marshfield , MA
Door post says 35 on Camrys. I run 40 to keep TPSM light off. It is more of nag ware than nanny ware. grin2
Thick oil is better grin2
Re: Tire Pressure [Re: Warstud] #5066373
04/06/19 07:01 PM
04/06/19 07:01 PM
St. Charles County, Missouri
csandste Offline
csandste  Offline
Early December oil change: getting colder, set to 38
Late March oil change: getting warmer, set to 35
2017 Kia Soul Plus-- Super Tech Synthetic 5w30 59000 miles
Re: Tire Pressure [Re: OVERKILL] #5066392
04/06/19 07:25 PM
04/06/19 07:25 PM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
Same. The only one that gave any latitude about pressures was the Audi (and other German makes seem to do that) depending upon expected payload and/or speeds. Actually, in the winter, I add a few pounds to the G37 in the garage. It's supposed to be 33 psi cold. The garage is 10 C minimum in winter. I set it to 33 psi at 10 C and then go outside when it's -30 C, I'll have a TPMS warning in under one kilometre of driving. So, I set it at something like 36 or 37 psi for the bad part of the year (eight months I guess. wink ).
Plain, simple Garak.
Re: Tire Pressure [Re: Garak] #5066408
04/06/19 07:47 PM
04/06/19 07:47 PM
Ontario, Canada
OVERKILL Offline
OVERKILL  Offline
Ontario, Canada
Yes, my BMW was like that, had a variety of pressures depending on anticipated operating speed and load. None of those pressures approached sidewall though LOL
Re: Tire Pressure [Re: Garak] #5066411
04/06/19 07:49 PM
04/06/19 07:49 PM
Western Canada
geeman789 Offline
geeman789  Offline
Western Canada
... The garage is 10 C minimum in winter. I set it to 33 psi at 10 C and then go outside when it's -30 C, I'll have a TPMS warning in under one kilometre of driving. So, I set it at something like 36 or 37 psi for the bad part of the year (eight months I guess. wink ).
Pressure drop is roughly 1 psi per 1 * C ... with a 40*C differential, you should be up at 41 psi garage pressure . At 36 psi garage, you are likely around 28 or 29 psi ambient. TPMS typically triggers at 25 % below recommended pressure, so about 26 psi.
2011 SUBARU Impreza 5-door manual / 2016 HONDA Pilot / 2011 MAZDA 2 auto
Re: Tire Pressure [Re: Warstud] #5066426
04/06/19 08:05 PM
04/06/19 08:05 PM
Maricopa Arizona
dave1251 Offline
dave1251  Offline
Maricopa Arizona
35 on the placard I run it 40-42 PSI.
don't use.
Page 1 of 4 1 2 3 4
