Hi all,
I have just joined the forum. It is biggest knowledge base about oils I have found so far!
I am going to change ATF in my 2001 RAV4 with 173000 km on it and I did some research and now I am even more confused when I was at the beginning.
My car calls for T-IV and I found that some oil makers state that Low Viscosity fluid is good replacement. The best example is Valvoline Maxlife but also Castrol Transmax Synthetic says it is "Suitable for use" in T-IV specs transmissions. Funny thing is that at the same time Toyota says that T-IV and WS (which is low viscosity) is not interchangeable. I have found some theads about it already but it does not explained the case clearly.
I went through a lot of specs and found out that Maxlife is low viscosity fluid, while T-IV is high viscosity fluid so how it can be suitable for use and be for T-IV and WS at the same time?
Is there anyone who changed ATF fluid from recomended T-IV to low viscosity like Maxlife?
I have also found information that using thick OEM fluid in old transmission can cause more problems than replacing it with thinner low viscosity one? Is it true?
Thanks for any suggestions
Tom
Tom
