My 09 rabbit. Has this issue where you'll turn the a/c on the switch lights up but the a/c doesn't get cold the cooling fans do not come on. Then out of no where it'll randomly work and when it does it's flawless cooling fans come on when sitting and the air out of the vents is cold. Pressures were around 40/125 at idle when it was roughly 60-65 outside. There is no codes in the car for the HVAC or anything else actually.....could this be the solenoid on the compressor I've read about? What do y'all recommend?
