2015 Subaru Crosstrek. The main radiator fan does not work. If I idle the car the temp goes up, but the fan does not turn on. It normally turns on around 203 degrees. I let it run up to 215 to see if it turned on and it didn't.
The A/C light is lit on the control knob but the compressor is not running. The sub fan does not work, either. The High and Low side are both hot to the touch when the A/C is on. Only hot air comes out of the vents. Everything worked fine yesterday.
A OBD scan shows no activity from both the main fan relay and the sub fan relay. The both show OFF. Could the main fan relay be the problem? And if so, is that why the compressor is not turning on. In other words, is there something that tells the compressor not to turn on if the main fan does not turn on?
Thanks.
Thanks.
