Keep in mind that the 2015 CRV had a DI engine that is prone to fuel dilution. This tendency is worse in cold weather/short trip driving conditions. So whatever oil you use, watch for increasing levels on the dipstick and change oil more frequently the the Maintenance Minder suggests.
I have this CRV and UOAs of 0w-20 have shown >5% fuel and 100C viscosity in the low-mid 6s cSt after a starting point of 8.8 or so. If warranty isn't a concern you might consider a xx w-30 to preserve viscosity. In any event, any SN/SN Plus full synthetic would work fine but imho frequent oil changes are much more important than oil brand.
To make frequent changes easier, take advantage of Honda's recommendation to change the oil filter at every other oil change and invest in a oil extractor. Makes a filterless oil change a snap.
And for those that continue to bash CVTs, please point me to a single example in any forum of a Honda CVT failure.
Hi Danh, previous owner used to change oil between MM 10-15%. In my case, changing oil at what point of MM (e.g. 20%, 30% etc) you think will help preventing fuel dilution?
It's hard to know the optimal point, but fwiw I have never let mine go below 60%. This may seem too ofen, but my UOAs come back without excessive wear metals (I.e. 1.25-1.5 ppm of iron/1,000 miles), so maybe that strategy is working.
"mightymousetech" used to post here and was an Acura technician at a Canadian dealership. His opinion was that the Honda/Acura Maintenance Minder didn't penalize oil life enough for short trips. Based on what I've seen the MM logic and resulting OCIs didn't seem to change when Honda adopted DI, so he may have a point.
I don't mind changing the oil at 60% but I would also like to get a UOA of my present oil. Do you know which lab would be good for that in Canada?
Do you think using TGMO 0W-20 OR
IDEMITSU ZEPRO 0W-20 may help in terms of reducing metals wearing?
Sorry for asking you a lot of questions. I have very little knowledge about automobile and fuel related things. But reading through this forum I'm learning
Don't know about labs in Canada, but Polaris/Oil Analyzers, Inc in the U.S. does a good job. Look for a lab that measures fuel dilution by gas chromotography, like Polaris.
I really don't think the brand of Oil matters that much. Idemitsu is a fine choice, but so are Mobil1, Pennzoil Platinum, et al..
