Forging oil change receipts? There's a lot of talk around here about using non-warranty conforming oils in newer vehicles, for a wide range of reasons some of which are perfectly valid.
Let's say you have a friend, your friend owns/works at a shop and would/has the ability to "manipulate" the receipt given to you. Like this:
Come in for oil change, let's say Honda 1.5T. Requires 0w20, but you have them put 5w30 Amsoil in it to help combat fuel dilution. But the receipt provided to you is changed to show a 0w20 service. You retain for your records, rinse and repeat.
2 years in, your rod bearings are shot. You provide documentation of 5k oil changes of the 0w20 variety, as per spec. Bam, new engine. Now, this is less about failure rates and more about (some) people preferring to use a different and arguably better oil in a car covered by a factory warranty.
Is there really anything that difficult about doing this, besides the obvious logistics? I could EASILY do this if I wanted to, not that I would. It just got me thinking.
