M1 HM 10w-30 vs M1 FS 0w-40
by RDY4WAR. 03/20/19 10:04 PM
Need Recommendations For A New SUV
by Dwight_Frye. 03/20/19 08:50 PM
GE dishwasher clicking
by silverrat. 03/20/19 08:20 PM
Every 6 months or one year OCI
by asker123. 03/20/19 07:36 PM
Valu Home Ctr. Peak Oil $9.94/5 qt jugs
by Nickdfresh. 03/20/19 07:32 PM
Chemical fire in texas
by Fitter30. 03/20/19 07:09 PM
PZ 37 CUT OPEN
by 53' Stude. 03/20/19 06:42 PM
Lube Intervals
by NibbanaBanana. 03/20/19 06:41 PM
When to send in oil for testing?
by SnowDrifter. 03/20/19 06:12 PM
ATF vs CHF
by GG16v. 03/20/19 05:40 PM
Landline Answering Machines
by das_peikko. 03/20/19 05:10 PM
Mobil oil on “clearance” at Target
by WiskyBadger. 03/20/19 04:04 PM
Master Mechanic Motor Oil @ True Value
by CG_BrianM. 03/20/19 01:35 PM
Some cars haven't changed much in 30 years...
by addyguy. 03/20/19 01:16 PM
Super Knock - Engineering Explained
by StevieC. 03/20/19 01:11 PM
Mobil Super Synthetic Clearance at Meijer
by Tjbouwhu. 03/20/19 12:53 PM
FYI: Costco is now stocking the 'good' Techron
by mbz321. 03/20/19 12:32 PM
Auto maintenance advice from a locksmith?
by Variant_S. 03/20/19 12:18 PM
DarkFrontier, Zuraxus, Burks21, GG16v, fleetwood62
67572 Registered Users
65 registered members (bbhero, ABerns, aquariuscsm, Anduril, ammolab, 7 invisible), 1,282 guests, and 58 spiders.
Topics286,168
Posts4,903,498
Members67,572
Most Online2,967
Mar 10th, 2019
air versus electric starters #1033330
11/22/07 10:41 PM
11/22/07 10:41 PM
Calif.
huffmuds9320 Offline OP
Calif.
I noticed the unique air sound when the bus starts up on the older ones. The older buses that have air start are 2 stroke engines like the Detroit Diesel 6v92ta. Newer buses (ie 4 stroke Cummins ISM)I guess use electric starters like cars. So what the advantages/disadvantages or air vs. electric starters? Thanks.
Re: air versus electric starters [Re: huffmuds9320] #1033375
11/23/07 12:23 AM
11/23/07 12:23 AM
KY
-Clayton- Offline
-Clayton-  Offline
KY
Well if your air tanks leak you can't start your engine.
But I think they sound awesome.
http://www.youtube.com/watch?v=E1RLUxp3Gpo
1985 F250 Ex-Cab 6.9 C6
2002 Dodge Caravan
Re: air versus electric starters [Re: -Clayton-] #1033710
11/23/07 08:45 PM
11/23/07 08:45 PM
kansastan
onion Offline
onion  Offline
kansastan
I haven't seen air starters on any relatively new equipment- only on old junk. Same goes for hydraulic starters. Clayton has pretty much spelled out the main drawback of air starters- and this becomes a major issue as equipment becomes old and leaky. There are LOTS of trucks & equipment out there that won't hold air overnight (though the air starter usually has its own isolated tank). I suppose one advantage of an air starter is that the air leaks HAVE to be fixed (to a point) for the equipment to remain useable.
The obvious advantage of electric starters is that just about any semi-literate can use jumper cables. Start dealing with gladhand couplers, air hoses, etc. and the number of operators who can successfully start the equipment drops exponentially.
The invisible and the imaginary look exactly the same.
Re: air versus electric starters [Re: onion] #1033791
11/23/07 11:05 PM
11/23/07 11:05 PM
NY, NY
NYEngineer Offline
NYEngineer  Offline
NY, NY
I'm responsible for being sure four 2000 kW Cat gensets will start and run at any time. One of the bosses decided we should have air starters to back up the TWO per engine 50MT starters. I made up a list of pros and cons. Basically, I told them the same thing. Without air and in a blackout, where would I get compressed air from?? With my current arrangement, I have two pairs of 1300 amp 8D batteries in parallel per engine. I have a cart with two 8D's, a charger and cables. Then I keep two starters and a battery charger in stock. PLUS my best friend owns a battery store. I have 24 hour access to batteries. That was the end of the air starter discussion.
Re: air versus electric starters [Re: NYEngineer] #1034028
11/24/07 01:26 PM
11/24/07 01:26 PM
Denver, NC
BillWilson Offline
BillWilson  Offline
Denver, NC
When I worked for a Class I railroad we purchased jet snow blowers. The jet engines used were military surplus J-34-34 and J-35 Jet engines orginally equipped with electric start/charge systems. Most of our track equipment had hydraulics installed, so it was natural to set the engines up with hydraulic motors to spin the jet engines up to 17% to 18% RPM to light them off.
We never used air starters on the diesel engines powering track equipment, but would use two 4Ds or 8Ds for the 24V systems. Electric starter on diesels in sub 0 temps is a good way to go. I have seen air starters in Russian Aircraft Radial engines! They do sound different during start-up!
Bill
Re: air versus electric starters [Re: BillWilson] #1034431
11/25/07 11:15 AM
11/25/07 11:15 AM
NY, NY
NYEngineer Offline
NYEngineer  Offline
NY, NY
I worked at a location once where they had three Cat D399's. One was the prime engine. It started on batteries. Once it was up to speed and making 480 volts, the other two had 480 volt AC starters. Darndest thing I ever saw, never saw it again.
Re: air versus electric starters [Re: NYEngineer] #1051599
12/24/07 05:17 AM
12/24/07 05:17 AM
Birdsboro Pa.
Ignatz Offline
Ignatz  Offline
Birdsboro Pa.
I heard air starters at the local US post office maintaince building last year. I think he said they were more economical cause they have to shut the engine off everytime they get out of their truck. That big Fairbanks Morse engine that I started a thread on below, is started with air. But I remember going thru a room with about a million batteries hooked up together, so they probably use the batteries as back-up. Also when I started in the petroleun industry in the 70's, the Exxon tanker fleet had air starters. We were always told that the air starters were safer because of not throwing sparks in case gas vapors were present. Don't know how true that was, but that was the reason we were given. I want to here that big Fairbanks Morse start up with air!
Re: air versus electric starters [Re: NYEngineer] #4945614
12/07/18 03:14 AM
12/07/18 03:14 AM
SF bay area, San leandro, Ca
Dualie Offline
Dualie  Offline
High pressure cylinders obviously. A 6 pack of 300CF cylinders charged to 3000Psi would do it
Re: air versus electric starters [Re: huffmuds9320] #4945647
12/07/18 06:38 AM
12/07/18 06:38 AM
'Stralia
Shannow Offline
Shannow  Offline
'Stralia
Our black start stuff has hand cranked diesel compressors as the back-up backup backup…
When it needs to start, then manual intervention that doesn't need a ute and a friend with batteries
Because sometimes the simple things in life...
...simply don't know any better
Re: air versus electric starters [Re: huffmuds9320] #5019817
02/22/19 08:48 AM
02/22/19 08:48 AM
missouri
ragtoplvr Offline
ragtoplvr  Offline
missouri
With air starters you do not need a big battery bank, just a small AGM will do you. When you have compressed air available, they can be good. They do not have the cold weather performance decline of battery systems. Jump starter cable is an air hose.
Modern electric starters are very good now.
Rod
Re: air versus electric starters [Re: huffmuds9320] #5027923
03/01/19 03:47 PM
03/01/19 03:47 PM
Canyon County Idaho
CT8 Offline
CT8  Offline
Canyon County Idaho
I remember Viking freight services had air starters on their trucks.
2015 Ford F150 2.7
2018 Ford F350 6.2
Re: air versus electric starters [Re: huffmuds9320] #5035295
03/07/19 08:42 PM
03/07/19 08:42 PM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
I know with the fleet of Freightshaker tractors at our plant coupled to tanker trailers, they've got so many air leaks, they'd never be able to shut'em down.
I haven't noticed in a few years, but the outfit that provides the bus service for our school system had a bunch of older rear engine school buses that had air starters in them. More than once they had to send the mechanic to air one up because it wouldn't restart.
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
