R red7404 Joined Jan 24, 2018 Messages 469 Location KS Mar 3, 2019 #1 what size should brass screen be for a Faraday Cage? Last edited by a moderator: Mar 3, 2019
spackard Joined Mar 24, 2011 Messages 2,700 Location CA Mar 3, 2019 #2 ISTR below 1/2 wavelength of the max freq you want it to work at.
buck91 Joined Apr 17, 2012 Messages 3,552 Location West Michigan Mar 3, 2019 #3 The prepping community has a LOT of discussion about this. Generally speaking, a metal box/can which fully encloses the idea you are trying to protect will be most effective. Don't forget to seal the joints/seams (solder or metallic tape).
L Linctex Joined Dec 31, 2016 Messages 10,144 Location Waco, TX Mar 3, 2019 #4 Old microwave ovens with the cord cut off are fantastic faraday cages, and super cheap when free
D danez_yoda Joined Jul 18, 2009 Messages 1,678 Location texas Mar 3, 2019 #5 Originally Posted by red7404 what size should brass screen be for a Faraday Cage? Doesn't matter. The alien mind controller beams will just switch to IR or Ultrasonic. There is no hiding possible.
2 2009Edge Joined Jun 10, 2009 Messages 312 Location Burleson,Texas Mar 3, 2019 #6 I made one out of heavy duty HVAC aluminum tape. Works GOOD. With a sleeve around my key fob my car will not start or open any doors.
