what stocks to buy?
by daves66nova - 02/24/20 08:55 PM
I thought Windows 7 would be insecure now?
by atikovi - 02/24/20 08:48 PM
When to replace struts
by ram_man - 02/24/20 08:40 PM
Fluid Film + Cayenne Pepper
by pitzel - 02/24/20 05:22 PM
Ford Focus RS Oil Advice!
by fastsvo - 02/24/20 04:23 PM
Cleanest wheels on same axle or same side of car?
by atikovi - 02/24/20 04:13 PM
Mixing 2 stroke oils
by Hirev - 02/24/20 03:57 PM
Insa Turbo Ecosaver Plus
by faramir9 - 02/24/20 03:45 PM
Repair Rusted Rocker Panels Without Welding
by Fitz98 - 02/24/20 03:33 PM
Stalwart tools
by P10crew - 02/24/20 03:32 PM
VOA Eneos Racing Street 0w-50
by zip15 - 02/24/20 03:09 PM
What is your favorite Candy Bar?
by ZZman - 02/24/20 02:27 PM
Help me understand
by 1978elcamino - 02/24/20 02:25 PM
2019 VW Passat Trip Mileage
by Boomer - 02/24/20 01:13 PM
Changed my ATF, difference is crazy!
by cwilliamsws6 - 02/24/20 12:36 PM
Specs on Conventional Oils 4 Comparing
by Perseus - 02/24/20 12:32 PM
Ford Edge owners chime in
by grampi - 02/24/20 11:49 AM
Pepboys Clearance oil SCORE!!
by Artem - 02/24/20 11:45 AM
EarlT500, Newbie111, Boris_Be, NHR, zip15
70798 Registered Users
81 registered members (01VFR, antonmnster, apollo18, b1amgm47, 11 invisible), 2,100 guests, and 20 spiders.
Topics301,893
Posts5,204,789
Members70,798
Allen key size problem #5029624 03/02/19 08:40 PM
V
vavavroom Offline OP
V
I need to loosen M2 hex head screw. None of my Allen bits fits. 1.27mm is too small, 1.5mm is too big, I really don't feel like sanding a 1.5mm bit down to fit. I am not aware of any intermediate size.
Re: Allen key size problem [Re: vavavroom] #5029636 03/02/19 08:50 PM
Chris142 Offline
Have you tried an sae hex key?
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Allen key size problem [Re: vavavroom] #5029638 03/02/19 08:54 PM
L
Langanobob Offline
L
Or try a Torx bit.
Re: Allen key size problem [Re: vavavroom] #5029661 03/02/19 09:33 PM
spasm3 Online Happy
Online Happy
If sae does not fit , hammer a robertson bit in.
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: Allen key size problem [Re: vavavroom] #5029739 03/03/19 12:16 AM
U
user52165 Offline
U
7/128 = 1.43mm Not sure that SAE is made.
This is where a high quality item made to tight tolerances is needed. I suspect yours is not, or the head, is buggered up. Probably 1.5. The other posts are good also.
Bondhus ball types are all I use.
Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy. It's inherent virtue is the equal sharing of misery.
Winston Churchill.
Re: Allen key size problem [Re: user52165] #5029753 03/03/19 12:49 AM
CR94 Offline
Originally Posted by user52165
...or the head, is buggered up. Probably 1.5. The other posts are good also. ...
Exactly. Check for burrs at the entrance of the hole in the screw, or at the tip of your hex key.
2011 Toyota Prius now at 109K
Re: Allen key size problem [Re: vavavroom] #5029767 03/03/19 01:17 AM
J
jhellwig Offline
J
If you are trying a ball end use a regular one. Ball ends don’t have as much grip area.
Sparks fly from my fingers.
1995 Chevy K2500 Suburban lt 5.7
2014 Toyota Sienna
1983 Chevy K5 350
Re: Allen key size problem [Re: vavavroom] #5029780 03/03/19 01:56 AM
gaijinnv Offline
M2 spec is 1.3mm. Many available: 1.3mm at Ace Hardware
HTH
USN NAVSECGRU 1970-1974
Re: Allen key size problem [Re: vavavroom] #5029871 03/03/19 07:27 AM
I
Imp4 Online Content
Online Content
I
An M2 SHCS should accept a 1.5mm he Allen key per DIN 912 & ISO 4762.
Attached PDF document
2001 Mitsubishi Galant 2.4 - 165k+
Grandma's creampuff...
Re: Allen key size problem [Re: Imp4] #5029987 03/03/19 09:31 AM
gaijinnv Offline
For a socket head screw you are correct, but OP does not have a socket head screw. Applicable standard is ISO 7380 which specifies 1.3mm for M2.
[Linked Image]
HTH
Re: Allen key size problem [Re: gaijinnv] #5030230 03/03/19 01:02 PM
I
Imp4 Online Content
Online Content
I
HTH
'ISO 7380- Hexagon socket button head screws' is button head screws just like you have illustrated.
OP states:
He does not specify socket head or button head...
I guess we'll need OP to clarify exactly what he has/needs...
cheers
Re: Allen key size problem [Re: vavavroom] #5030852 03/03/19 11:44 PM
R
red7404 Offline
R
IMHO. this is where you buy the cheapest tools you can find. and mod them to your harts content
Re: Allen key size problem [Re: Imp4] #5031137 03/04/19 09:28 AM
gaijinnv Offline
OP states:
cheers
I completely agree cheers
Re: Allen key size problem [Re: vavavroom] #5031379 03/04/19 01:09 PM
L
lyle Offline
L
Lordy, oh lordy, he says he has a HEX HEAD SCREW. No wonder his Allen bits don't fit, he needs a box end or open end wrench.
Now if he had a hex socket screw that would be different, but he needs to specify head type.
Re: Allen key size problem [Re: vavavroom] #5031657 03/04/19 05:29 PM
E
EdwardC Offline
E
We should probably check if his name is even Allen.
