Just found out about this fluid. Anyone know anymore than what AMSOIL's web page has to say? It sounds like you can put it where DIII goes. I wonder if it is any better than their ATF fluid.
Prove it, please. The Schaeffer's web site site says:quote:
You get the same Allison operation from Schaeffer's #239S Super Lube for $50 per 5-gallon pail, and it is actually Allison C-4 approved
quote:
Super Lube Supreme meets and exceeds the following specifications:....Caterpillar T0-4, Allison C-4
Schaeffer does not claim to have a TES 295 fluid. They recommend either their ATF or TO-4 fluids, as suitable for the particular transmission model, both Allison C-4 rated.quote:
Originally posted by MolaKule:
There is a huge difference in the language here:
"Approved by Allison" and "Recommended by Amsoil as replacement for TranSynd and for use in all TES 295 applications."
To be fair, I am curious if Schaeffer's went through the test-stand qualifaction as well?
