Originally Posted By: Trav
Originally Posted By: Branson304
Run the factory fill to 5,000 and change it. Have fun with your perfectly running engine for many years & hundreds of thousands of miles to come while saving money & time.
Changing oil early & at short intervals = useless.
You cant say that with any sort of certainty unless you can explain why Toyota, Honda and other car companies in Germany and maybe other countries still specify a 1K (600 mi) initial service interval that includes new oil and filter.
Granted their OCI after that are pretty long but they could just as easily spec a 5K initial service. IMO it just makes common sense to get any sort of machining junk out ASAP, engine factories are far from clean or sterile and machining metals does leave junk behind its the nature of the process nothing to do with cleanliness.
Newly machined parts do wear together causing particles to wear off even
if they were assembled spotlessly clean, its unavoidable. Many say "well the filter will catch it before it sees the bearings" okay but what about parts pre filter like the pump? For my money its worth the cost of a OC or two to prevent possible scoring of the new pump if nothing else.
