need brake job but ...
by Bluebonnet. 04/25/19 05:12 PM
UOA on BMW 0w-30 on BMW F10 M5 with S63 TVDI V8
by AirBull. 04/25/19 05:08 PM
What to drink with trail mix?
by das_peikko. 04/25/19 04:55 PM
And This Folks, Is How You Buy Guns
by billt460. 04/25/19 04:43 PM
Tire leak with new wheels. What would YOU do?
by Lolvoguy. 04/25/19 04:20 PM
Red battery light came on, Ford E150.
by laserred96gt. 04/25/19 03:34 PM
2019 NFL Draft
by JustN89. 04/25/19 03:10 PM
Crabgrass!!!!
by gregk24. 04/25/19 03:06 PM
Drain and fill 08 Kia Rio.
by Jetsfan421. 04/25/19 02:59 PM
Cut Open - Mazda OEM @ 7,000kms
by mcwilly. 04/25/19 02:50 PM
Fender bender...headache!
by gregk24. 04/25/19 02:44 PM
Cerwin Vega 10" Subwoofers - $14.37 Each
by Greg L. 04/25/19 01:53 PM
Blain's Farm & Fleet synthetic oil $2.19/qt.
by BrewCityR. 04/25/19 01:24 PM
F1 - 2019 Azerbaijan Grand Prix
by gofast182. 04/25/19 12:00 PM
Installing an additional fuel filter?
by Ed_Flecko. 04/25/19 11:46 AM
Honda self propel only spining left wheel
by Tundragod. 04/25/19 11:38 AM
Cabin Filter Pics (15k miles)
by DoubleWasp. 04/25/19 11:30 AM
LiquiMoly Jectron Fuel Injection Cleaner
by Ddub. 04/25/19 11:12 AM
servicing a 2018 GM 6speed transmission
by gotnogunk. 04/25/19 10:23 AM
Wood9913, Lydia, jdar805866, PreludeDenarius, Ayodejidj
67902 Registered Users
112 registered members (Anduril, 240_Ed, AirBull, ad_infinitum, Amenhotep, 01rangerxl, 11 invisible), 2,153 guests, and 20 spiders.
Topics288,045
Posts4,939,805
Members67,902
Most Online2,967
Mar 10th, 2019
2015 duramax, UOA schaeffer's 15 40 #5008147
02/11/19 05:06 PM
02/11/19 05:06 PM
Ohio
wjm Offline OP
wjm  Offline OP
Ohio
First sample on this truck after 1st run on schaeffer's. Miles from the whole year is the only reason I changed it.
Re: 2015 duramax, UOA schaeffer's 15 40 [Re: wjm] #5008263
02/11/19 07:24 PM
02/11/19 07:24 PM
pa
benjy Online content
benjy  Online Content
pa
not readable!
Re: 2015 duramax, UOA schaeffer's 15 40 [Re: wjm] #5008311
02/11/19 08:22 PM
02/11/19 08:22 PM
A Highway Near You
PiperOne Offline
PiperOne  Offline
A Highway Near You
Even tried saving the image and then zooming in...pixelates before number are large enough to read. Is it possible to upload something other than a screen shot of your phone maybe?
HDEO in Diesel Engines. No spark plugs here.
Re: 2015 duramax, UOA schaeffer's 15 40 [Re: wjm] #5008372
02/11/19 09:37 PM
02/11/19 09:37 PM
Ohio
wjm Offline OP
wjm  Offline OP
Ohio
Hopefully you can open this
Attached PDF document
021119_2133.pdf (78 downloads)
Re: 2015 duramax, UOA schaeffer's 15 40 [Re: wjm] #5008566
02/12/19 07:59 AM
02/12/19 07:59 AM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
I do not see the miles on unit or miles on oil? What is the goal here? To extend the oil changes?
2015 Ford F250 w/Powerstroke
Re: 2015 duramax, UOA schaeffer's 15 40 [Re: wjm] #5008631
02/12/19 09:46 AM
02/12/19 09:46 AM
DFW
JustN89 Offline
JustN89  Offline
DFW
Hope this helps.
Re: 2015 duramax, UOA schaeffer's 15 40 [Re: Donald] #5008667
02/12/19 10:38 AM
02/12/19 10:38 AM
Ohio
wjm Offline OP
wjm  Offline OP
Ohio
There was 4550 miles on the oil. Just wondering if there is really much difference of protection from this versus a dino oil if only going to put around 5k miles a year? Don't care about the cost just the best product
Re: 2015 duramax, UOA schaeffer's 15 40 [Re: wjm] #5008694
02/12/19 11:08 AM
02/12/19 11:08 AM
DFW
JustN89 Offline
JustN89  Offline
DFW
Depends on what your definition of best is, but I seriously doubt your engine would notice a difference between this or any other conventional 15W-40 over a 5k mile OCI.
Re: 2015 duramax, UOA schaeffer's 15 40 [Re: wjm] #5008716
02/12/19 11:28 AM
02/12/19 11:28 AM
US
JLTD Offline
JLTD  Offline
US
Looks like 2 years would be easy...
I use the overseas owner's manual to choose my oil.
Using AMSOIL
Hers: 2008 Jeep Liberty 146k, SS 5w30/Amsoil
His: 2015 4Runner 53k, OE 5w30/Wix
Re: 2015 duramax, UOA schaeffer's 15 40 [Re: JustN89] #5008749
02/12/19 11:56 AM
02/12/19 11:56 AM
Ohio
wjm Offline OP
wjm  Offline OP
Ohio
Ok thanks kinda what I was thinking. Is it something to go by 12 months or actually go by the drain intervals? I figured a year was long enough
Re: 2015 duramax, UOA schaeffer's 15 40 [Re: wjm] #5008884
02/12/19 01:48 PM
02/12/19 01:48 PM
Alaska
m37charlie Offline
m37charlie  Offline
Alaska
If your low annual mileage is very short in town driving ( for which an emissions controlled diesel is unsuitable anyways) I would change every year. But in that case you have bigger problems i.e. the DPF.
If it is infrequent longer trips I would recommend extending OCI to at least 10k miles/2yr or longer. Oil does not degrade just sitting in the crankcase.
05 Unimog U500/Unicat camper/Delvac 1 SHC ACEA E4/E5
09 BMW X5 35d/Delvac1 LE 5W30
88 Toyota OJ50LV OM314 motor D1 SHC
52 Dodge M37/Hercules diesel
Re: 2015 duramax, UOA schaeffer's 15 40 [Re: m37charlie] #5009195
02/12/19 06:40 PM
02/12/19 06:40 PM
Ohio
wjm Offline OP
wjm  Offline OP
Ohio
Ok thanks, 90% is pulling my fithwheel camper weighs around 11k dry. Unless I'm not reading it correctly, I thought schaeffer's had a lot of moly and higher zinc? From this sample it doesn't look much different than a sample I saw of Mobil delvec 1300 for a dino oil. Any insight on that?
Re: 2015 duramax, UOA schaeffer's 15 40 [Re: wjm] #5009540
02/13/19 06:49 AM
02/13/19 06:49 AM
Indianapolis, IN
dnewton3 Offline
Global Moderator
dnewton3  Offline
Global Moderator
Indianapolis, IN
I can assure you with total, absolute certainty that the Dmax engine could not possible care less what's in the crankcase, as long as it's a properly spec'd lube. Brand and grade mean absolutely zilch to this engine series. None. Zip. Nada.
If you intend to stick to one or two year OCIs, based on the miles you drive, there is no reason to use anything but a conventional 10w-30 or 15w-40. Either grade will provide excellent wear control and save you a ton of cash. I routinely ran 3 year OCIs out to 12k miles, on dino 10w-30 and had nothing but great results, even when hauling my RV out to the Rockies and back, multiple times. Honestly you can follow the IOLM in a Dmax and just use dino oil. Unless you suspect a contamination issue, UOAs are pretty much worthless on a Dmax; they've never showed an issue in a healthy engine, and the only proof they provide is that these engines are completely and utterly immune to brand/grade oil choices. It would be impossible for me to overstate this fact; 6.6L Dmax engines are some of the best wearing light-duty diesel engines out there, and they simply do not show any preference whatsoever to any brand/grade of oil, regardless of what your emotions thinks are important.
Probably the best thing going for your generation of Dmax is that there exists a fuel injection nozzle downstream of the cylinders, in the exhaust, for the DPF purpose. This means no fuel dilution that's otherwise common in other compliant diesel engines. (this is presuming you're stock). No need to worry about cylinder's washing down with excess fuel. I wish all the other diesel engines had this strategy; worth the extra expense in OEM design if you ask me.
If you intend to GREATLY increase the miles you drive annually, or spread the duration out over many years, then the syn might make sense. This would be smart only if you monitor with UOAs.
I have over 550 Dmax 6.6L UOAs in my database. I do statistical process quality control for a living. I would know if these engines had an oil preference. Trust me; they don't.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: 2015 duramax, UOA schaeffer's 15 40 [Re: wjm] #5009709
02/13/19 10:09 AM
02/13/19 10:09 AM
Savannah
wensteph Offline
wensteph  Offline
Savannah
I've got a 2019 L5P and I am in agreement with dnewton3's opinion on Duramax oil needs. I'm currently on the single dealer change which is Delvac, probably dino, and will test that at 5K on the oil. Next change will be Super Tech and after that Rotella T5 and then a Schaeffer's. The only reason I'm doing this will be to add to the L5P database. The new engine shares only a name and displacement with prior generation Duramax's. Hopefully it's as easy on oil. It probably is.
Re: 2015 duramax, UOA schaeffer's 15 40 [Re: dnewton3] #5009917
02/13/19 01:24 PM
02/13/19 01:24 PM
Idaho
BoiseRob Offline
BoiseRob  Offline
Idaho
Dave, the 15w40 he's running is Schaeffer's basic syn-blend oil. They don't make a straight conventional unless you use #151 Moly Bond X-200 which only has a CI-4 rating with a TBN of 12...
2007 Chevrolet Silverado 2500HD LBZ Duramax
2016 Jeep Grand Cherokee Ecodiesel
