Fat Wallet Forum
by LazyDog. 02/21/19 10:09 AM
Orange washer fluid?
by atikovi. 02/21/19 10:01 AM
Recommended laptop carrying case
by paulri. 02/21/19 09:47 AM
Collagen and Gelatin for protein supplement
by Lolvoguy. 02/21/19 09:36 AM
Credit Increase- CC's
by Zee09. 02/21/19 08:24 AM
High iron and silicon
by landyman. 02/21/19 08:21 AM
13 Titan Vibration in 4th gear.
by Anthony. 02/21/19 07:36 AM
DEF Consumption
by wings&wheels. 02/21/19 07:06 AM
Which Natural Gas Water Heater to Get?
by LoneRanger. 02/21/19 06:58 AM
2016 Crosstrek Windshield Washer reservoir
by Donald. 02/21/19 06:43 AM
Whistling wipers!
by mclasser. 02/21/19 06:39 AM
Going by HTHS
by JLTD. 02/21/19 02:59 AM
Quick Struts vs Replacing the struts by themselves
by das_peikko. 02/20/19 11:50 PM
Walmart Oil clearance # 2
by GMguy84. 02/20/19 11:14 PM
ST Syn in a TGDI?
by BTLew81. 02/20/19 09:52 PM
The Virus That Kills Drug-Resistant Superbugs
by StevieC. 02/20/19 09:50 PM
AtomicNumber53, waynea, txan, pman9003, alienyouth33
67298 Registered Users
106 registered members (240_Ed, aquariuscsm, Bambam, aleneros, atikovi, 14 invisible), 1,666 guests, and 52 spiders.
Topics284,603
Posts4,873,213
Members67,298
Most Online2,548
Feb 16th, 2019
Restrictor Ramblings #5006572
02/10/19 08:57 AM
02/10/19 08:57 AM
Midwest, Illinois
beanoil Offline OP
beanoil  Offline OP
Midwest, Illinois
I got this idea from a thread on an import board. The discussion was in regards to restricting oil to turbos.Might be old news to most of you, just sharing an idea.
In my mind the restrictor should be on the output of the head, after the filter. YMMV, some folks restrict the input. I do not know if it's critical either way, just that the majority of bypass systems restrict the out flow of the filter. This could still work even if the filter has a built in restrictor and you wanted to throttle it back more.
You'll have to figure out flow rate on your own, but I found it pretty easy to use a measuring cup, and count seconds to calculate quarts per minute/gallons an hour.
Thread the end of the fitting internally and add a hex head plug with red loctite on it to seal.
Just drill the size hole you want in the hex head.
1/32 drill bit is .0312
3/64 drill bit is .0468
1/16 drill bit is .0625
Restrictor in fitting.
beanoil: Tough under heat, real dirty afterwards.
Re: Restrictor Ramblings [Re: beanoil] #5006577
02/10/19 09:00 AM
02/10/19 09:00 AM
Virginia Beach
Astro14 Offline
Astro14  Offline
Virginia Beach
Why would you want to restrict oil going to the turbo?
32 Packard 15W40
02 Volvo V70 T5 0W40 M1
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: Restrictor Ramblings [Re: beanoil] #5006580
02/10/19 09:02 AM
02/10/19 09:02 AM
Midwest, Illinois
beanoil Offline OP
beanoil  Offline OP
Midwest, Illinois
In that thread, some import guys had switched turbos and needed less oiling for their selection. Different bearings and seals.
Re: Restrictor Ramblings [Re: beanoil] #5006589
02/10/19 09:11 AM
02/10/19 09:11 AM
Virginia Beach
Astro14 Offline
Astro14  Offline
Virginia Beach
It's a new concept to me...
I've owned several turbo cars, and never considered restricting the oil flow to the turbo(s).
But then, my turbos have all remained stock. Even with a mild tune, I've not needed a different turbo...
Hard to believe there is such a thing as "too much oil" to the turbo.
32 Packard 15W40
05 MB S600 0W40 M1
Re: Restrictor Ramblings [Re: beanoil] #5006658
02/10/19 10:10 AM
02/10/19 10:10 AM
The Motor City
Kestas Online content
Kestas  Online Content
The Motor City
I still don't understand the downside of too much oil going to the turbo bearings.
Re: Restrictor Ramblings [Re: beanoil] #5006787
02/10/19 12:17 PM
02/10/19 12:17 PM
5600 feet elevation, Arizona
double vanos Offline
Back in the Mazdaspeed 3 days a smoking turbo was an issue when you straight piped the exhaust system- no back pressure the theory went caused oil to get past the turbo seals and she’d smoke her a** off at idle. I ran both my Mazdaspeed 3s totally stock and never had a smoking turbo. No oil consumption either. Restricting the oil to the turbo was supposed to alleviate this.
Sabine Schmitz is the Queen of the 'Ring; Svetlana Kapanina is the Queen of the SKIES...
Re: Restrictor Ramblings [Re: beanoil] #5006820
02/10/19 12:46 PM
02/10/19 12:46 PM
Midwest, Illinois
beanoil Offline OP
beanoil  Offline OP
Midwest, Illinois
I only got the idea from a turbo thread.
The restrictor idea seems solid to me, and would enable a generic filter head to be used with a bypass filter.
Heads for specific bypass filters have a restrictor built in, but oil pressure and viscosity can effect flow, and someone may want to slow that down.
Re: Restrictor Ramblings [Re: beanoil] #5006879
02/10/19 01:36 PM
02/10/19 01:36 PM
New England
555 Offline
555  Offline
New England
Would you be kind enough to let us know what engine/vehicle/turbo you are modifying? At least for curiousity's sake since a lot of BITOG members like turbos.
Thanks
84 XJ6 M1
92 Mustang 5.0 Redline
99 Tahoe 2 door Castrol Edge
99 MX5 Miata Anniversary Edition M1
04 Subaru STi Motul
Re: Restrictor Ramblings [Re: beanoil] #5006988
02/10/19 02:51 PM
02/10/19 02:51 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
This is common practice.
It keeps the seals from having to hold back a Tsunami of oil.
A lot of factory installs have restrictors, you just don't realize it.
Re: Restrictor Ramblings [Re: double vanos] #5007721
02/11/19 08:50 AM
02/11/19 08:50 AM
Houston,TX
Purpfox Offline
Purpfox  Offline
Houston,TX
Same here, restricting the feed to the speed3. also kept the charge pipes much cleaner. (FMIC) turbo mainly need flow more so than pressure.
Certified Analyst ( by no means an expert Much to learn )
Moderated by  ekpolk
