Changed oil, Ravenol FullSynth Turbo VST 5W-40
by NotEnoughSpeed. 07/17/19 08:30 PM
Blending TCW3 in diesel
by 32319. 07/17/19 08:27 PM
Leaking Batteries
by ecotourist. 07/17/19 08:22 PM
Shake down tow complete!
by ls1mike. 07/17/19 08:22 PM
Looking for cheap int'l air tix
by daves66nova. 07/17/19 08:05 PM
Not *new* per se, but $3.98 for 5 quarts of M1
by mrdctaylor. 07/17/19 07:45 PM
Winter tires for 2019 Ram
by NissanHauler. 07/17/19 06:16 PM
Is the car hobby/enthusiast a dying breed?
by Redright9. 07/17/19 05:48 PM
Mobil One design change M1C-154A
by piesled. 07/17/19 05:26 PM
crazy granny gear spotted
by Number_35. 07/17/19 04:32 PM
Grease gun suggestions
by rideon. 07/17/19 04:16 PM
17 Imprezza 2.0
by JHogan. 07/17/19 03:42 PM
new boat, considering twin f 150 yamis
by 1978elcamino. 07/17/19 03:20 PM
Preventative repair - 2009 Ford Flex water pump
by KGMtech. 07/17/19 02:56 PM
Bought out phone lease for a song
by 14Accent. 07/17/19 02:54 PM
Do you have a fave RTV sealant you use?
by ZZman. 07/17/19 01:36 PM
Scanner
by tiger862. 07/17/19 12:36 PM
patman3d, Oillogger, Rob707, rageyourdreams, Beemer25
68692 Registered Users
125 registered members (2015_PSD, 4WD, 07hemi, 01rangerxl, 15 invisible), 1,889 guests, and 24 spiders.
Topics292,007
Posts5,015,095
Members68,692
Most Online2,967
Mar 10th, 2019
I think I used the wrong fluid.... #4990149
01/25/19 07:00 AM
01/25/19 07:00 AM
Everett, WA
jagtuner28 Offline OP
Everett, WA
Hello everyone, I am creating a new thread so as to better decipher whether I should do my extremely laborious transmission fluid replacement all over again or whether I should just wing it and call it good so to speak. So, to start with, I have a suped up 2017 Jetta 1.4TSI that I recently did two separate transmission drain and fill services on and on the second fluid replacement I replaced the filter. What is making me question all of this now is that I just realized that the filter I had to get (which was different from the one I initially ordered) was different and I had to get a replacement Rein filter from Carquest on the same day I did the 2nd service. It did not occur to me that the dramatically different filter design could indicate that my fluid choice may be wrong as well since the pan gasket was identical and now, after 4,000 miles, the car seems to drive perfectly fine in every way even though I think I used the wrong fluid.
After some research, I figured out that the 2017 Jetta is supposedly available with either a 09G or 09G (Gen. 2) transmission with each having different fluids and filters. The original design held a little more fluid (7.4 vs. 6.4qts) and used VW fluid spec. G 055 025 A2 whereas the Gen 2. design transmission uses a Dexron VI-ish fluid specified as G 055 040 A2. As it turns out, I now believe I have the Gen 2. transmission but used Gen 1. fluids. Like I said, the car seems to shift and drive perfectly but the difference in spec. is making me question my inclination to just leave it be so that is why I created this post to see what you guys think. The fluids I used for the (2x) drain and fills with the new filter was Amsoil Signature Series ATF (meets 025 A2 spec) along with a bottle of ATP AT-202 transmission additive (similar to Lubegard Red from what I can tell). If I were to redo the service I would probably use the Amsoil Signature Series Fuel Efficient ATF (meets Dex. VI reqs) and then use Lubegard Platinum to convert it into the 040 A2 fluid. However, my instinct tells me that I might be okay since Amsoil and ATP fluids are so [censored] good anyways that maybe I should just let this one slide... What do you guys think?
Re: I think I used the wrong fluid.... [Re: jagtuner28] #4990164
01/25/19 07:27 AM
01/25/19 07:27 AM
Champlain/Hudson Valley
Kira Offline
Kira  Offline
FIRST STEP: Learn which transmission you have. You may have the correct fluid in your unit.
Re: I think I used the wrong fluid.... [Re: jagtuner28] #4990174
01/25/19 07:40 AM
01/25/19 07:40 AM
Tn.
CourierDriver Offline
Tn.
smirk2 idk
Look into Forks Over Knives Official Plant-Based Group if you want to change your way of eating.
Today, the average American consumes almost 152 pounds of sugar in one year.
Re: I think I used the wrong fluid.... [Re: Kira] #4990185
01/25/19 07:54 AM
01/25/19 07:54 AM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
Yes find out what you have. Otherwise you're just flapping about with no data.
At least you have that Amsoil that's so [censored] good smirk2
1994 BMW 530i, 242K
1996 Honda Accord, 277K
1999 Toyota Sienna, 418K
2000 Toyota ECHO, 281K
Re: I think I used the wrong fluid.... [Re: jagtuner28] #4990212
01/25/19 08:43 AM
01/25/19 08:43 AM
Upstate NY
Donald Offline
Donald  Offline
Upstate NY
A dealer should give you a build sheet or similar that based on VIN tells you every component in he car. I have gotten it from Ford and Chrysler. I assume VW has a similar function available to the service manager.
2015 Ford F250 w/Powerstroke
Re: I think I used the wrong fluid.... [Re: Donald] #4990215
01/25/19 08:45 AM
01/25/19 08:45 AM
NY
demarpaint Offline
demarpaint  Offline
NY
+1
God Bless Our Troops
Re: I think I used the wrong fluid.... [Re: jagtuner28] #4990221
01/25/19 08:54 AM
01/25/19 08:54 AM
KS
FordBroncoVWJeta Online content
FordBroncoVWJeta  Online Content
KS
How exactly did you sup up that Jetta?
2017 Volkswagen Jetta 1.4T - 2015 Honda CRV 2.4 - 2012 Volkswagen Jetta 2.0 - 2007 Chevy Trailblazer 4.2 - 2003 Ford Taurus 3.0 Vulcan
Re: I think I used the wrong fluid.... [Re: jagtuner28] #4990230
01/25/19 09:10 AM
01/25/19 09:10 AM
WY
sloinker Offline
sloinker  Offline
WY
How many miles can a '17 Jetta have that would require a tranny fluid change, twice?
Re: I think I used the wrong fluid.... [Re: kschachn] #4990241
01/25/19 09:30 AM
01/25/19 09:30 AM
Duvall WA - Pacific NW USA
Pablo Offline
Pablo  Offline
Uncalled for and not helpful in the least. Please, aren't you above this?
Amsoil says:
Quote
Automatic Transmission Fluid
For Automatic Transmission: 09G....SL015
No recommendations available
Capacities: 6 speed 09G Total Fill 6.4 quarts
DIRECT JOBBER - PABLO - for all your Amsoil needs
http://oilslubesandfilters.shopamsoil.com/
Re: I think I used the wrong fluid.... [Re: Pablo] #4990247
01/25/19 09:38 AM
01/25/19 09:38 AM
Upper Midwest
kschachn Offline
kschachn  Offline
Upper Midwest
I just found it interesting that a brand is more important than a specification, and it does so because it is so [censored] good.
1994 BMW 530i, 242K
Re: I think I used the wrong fluid.... [Re: Kira] #4990276
01/25/19 10:00 AM
01/25/19 10:00 AM
Ohio
hallstevenson Online content
hallstevenson  Online Content
Ohio
"Like"
Re: I think I used the wrong fluid.... [Re: Kira] #4990426
01/25/19 01:18 PM
01/25/19 01:18 PM
Southwest Michigan
lewdwig Offline
lewdwig  Offline
Southwest Michigan
+1
2001 Subaru Forester L
2003 Buick Park Avenue
2015 Ford Escape
Google search:
(search terms here) site:bobistheoilguy.com
Re: I think I used the wrong fluid.... [Re: jagtuner28] #4990458
01/25/19 01:58 PM
01/25/19 01:58 PM
Connecticut
69GTX Online content
69GTX  Online Content
Connecticut
2nd step, find out what (if any) alterations were made in that transmission in 2017 to require the shift from the 7.4 cSt viscosity fluid to the Dex VI 5.8 cSt fluid. It could just be a factor of longevity between OCI's or the lack of shearing with the Dex VI. If the trans wasn't really altered in any significant way, then the fluid change wasn't a "critical" change...and you're probably fine. A lot of car mfg's are trying to combine their fleets to get one common fluid...and Dex VI is still the latest and greatest thing. It does seem to work fine in many automatic transmissions that previously used a Dex III viscosity.
If you have a new car warranty to maintain that's another issue.
2001 Lincoln Cont 4.6L DOHC/ 50K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: I think I used the wrong fluid.... [Re: sloinker] #4990468
01/25/19 02:12 PM
01/25/19 02:12 PM
VW Fanboy Island
maxdustington Online content
maxdustington  Online Content
VW Fanboy Island
This..is...BITOGGGGGGGGGGGGG!
Good job OP on swapping that trans fluid early, and tuning a new car!
03 Jetta AWP/09A 210k kms
Edge 0W40 + Mann 719/30
Re: I think I used the wrong fluid.... [Re: maxdustington] #4990526
01/25/19 03:07 PM
01/25/19 03:07 PM
Illinois
Jetsfan421 Offline
Jetsfan421  Offline
Illinois
Find a good fluid and change it early and regularly. That is the key to a long life for automatics. That and a little LG red never hurt anything.
