Hello everyone, I am creating a new thread so as to better decipher whether I should do my extremely laborious transmission fluid replacement all over again or whether I should just wing it and call it good so to speak. So, to start with, I have a suped up 2017 Jetta 1.4TSI that I recently did two separate transmission drain and fill services on and on the second fluid replacement I replaced the filter. What is making me question all of this now is that I just realized that the filter I had to get (which was different from the one I initially ordered) was different and I had to get a replacement Rein filter from Carquest on the same day I did the 2nd service. It did not occur to me that the dramatically different filter design could indicate that my fluid choice may be wrong as well since the pan gasket was identical and now, after 4,000 miles, the car seems to drive perfectly fine in every way even though I think I used the wrong fluid.
After some research, I figured out that the 2017 Jetta is supposedly available with either a 09G or 09G (Gen. 2) transmission with each having different fluids and filters. The original design held a little more fluid (7.4 vs. 6.4qts) and used VW fluid spec. G 055 025 A2 whereas the Gen 2. design transmission uses a Dexron VI-ish fluid specified as G 055 040 A2. As it turns out, I now believe I have the Gen 2. transmission but used Gen 1. fluids. Like I said, the car seems to shift and drive perfectly but the difference in spec. is making me question my inclination to just leave it be so that is why I created this post to see what you guys think. The fluids I used for the (2x) drain and fills with the new filter was Amsoil Signature Series ATF (meets 025 A2 spec) along with a bottle of ATP AT-202 transmission additive (similar to Lubegard Red from what I can tell). If I were to redo the service I would probably use the Amsoil Signature Series Fuel Efficient ATF (meets Dex. VI reqs) and then use Lubegard Platinum to convert it into the 040 A2 fluid. However, my instinct tells me that I might be okay since Amsoil and ATP fluids are so [censored] good anyways that maybe I should just let this one slide... What do you guys think?
