Originally Posted by Impatient
Bumping the thread to acknowledge some interesting twists this has taken with the premium fuel recommendation. OA has agreed to retest the sample, though I doubt this will "fix" the problem. I will look into the premium fuel aspect; after all, I've been running premium in the Subaru, at mfgr's recommendation. So what if this costs an extra $400/yr.🤬. I am hoping the lead is an anomaly. There are several ways to keep the oil more robust. Castrol-, Mobil-, or Pennzoil-Euro might also help a tad with starting viscosity, although it is debatable if I should deviate from Ford recommended spec. They don't allow for anything thicker than 5w30 in the manual (for the EB). I suppose I could argue that the Pennzoil 5w30 is just as good/better, but I had hoped to keep this rig for 120k+ miles, ie my goal is far beyond getting to the 60k warranty expiration. Maybe 5w30 is just not good enough.
Impatient, maybe try QSUD 5w30 I believe it conforms to the Ford spec, it is also Dexos1 gen2 sn plus. Viscosity @100c is 11.64, VI 170, with higher than normal Moly. This paired with a premium grade gas may help with the fuel dilution and hopefully bring down the lead level somewhat also. Try a 5k run with this combo and another UOA. You seem intent on using a 5w30, so this is why I didn't recommend a 40 weight. Stay the course a little longer and just maybe things will look up.. Fingers are crossed, good luck.
