I have one of the six zones on my lawn sprinkler system that is not working. Three of the solenoid valves are next to each other over 100 feet from the controller box. They share a common ground wire.
I have 25 volts at the controller box. If I disconnect the wires at the solenoid, I get 25 volts on two of the lines and the solenoid valve works, but only 6 volts on the last solenoid on the common ground line. It doesn't work What would cause this and how do I trouble shoot it?
