I just bought a 2019 Sorento EX V6.
Been reading a lot about GDI engines, best oils to use, OCI's, etc.
Based on what I have read, I have decided on a 5,000 mile OCI.
I will use full synthetic 0W-30-weight oil, as that is what is indicated on the cap on the engine.
My question is this: What is the total amount of oil that is needed for an oil change? I believe from reading the owner's manual spec page that 6.87 quarts is correct, but I wanted to check with the experts here on these forums also.
Also, the book says to change the trans fluid at 60,000 miles, but I have read about a lot of people doing it at 30,000 miles instead. What do you think?
