Originally Posted by spasm3
... But i'm surprised you put another internal hex bolt in there. Could you not get an external bolt head plug to fit? I'd not want go through that again. ... My newish mazda had an internal hex drain plug. I changed that out the second oil change for a standard external bolt head.
Does it matter that much to you? Surely you'll admit Gebo's new internal-hex plug is prettier!
My first encounter with internal-hex plugs was changing the WS ATF in the Prius. No problems. I couldn't use a torque wrench, but that didn't matter. The transmission drain of the Mazda required an unusual size deep socket, more of an inconvenience.
