Oil from Power Driven Diesel
by boltgun308 - 09/16/19 08:57 AM
Engine tick on startup
by Broo - 09/16/19 08:44 AM
Price of Gasoline
by Snagglefoot - 09/16/19 08:34 AM
Quick 2004 F150 alternator ???
by doitmyself - 09/16/19 08:20 AM
Problem: REPLYING to Posts
by MasterSolenoid - 09/16/19 07:53 AM
Redline MT85 OR MT90
by dja4260 - 09/16/19 07:38 AM
Where to buy new trim pieces?
by cwilliamsws6 - 09/16/19 07:35 AM
Quarter panel damage
by MaximaGuy - 09/16/19 06:43 AM
Maintaining Your Jaguar E-Type
by ctechbob - 09/16/19 02:14 AM
Orschelen - 8.99$ 5 Qt RGT after MIR
by GumbyJarvis - 09/16/19 01:23 AM
Inexpensive insulation for attic
by daves66nova - 09/15/19 11:45 PM
Spark arrestor clogged solid
by motor_oil_madman - 09/15/19 11:08 PM
Briggs and Stratton auto chock plastic carburators
by WilliamBeeth - 09/15/19 11:03 PM
Lexol removing paint from leather seat?
by A_User55555 - 09/15/19 10:49 PM
calculate stereo runtime
by dogememe - 09/15/19 10:11 PM
Utility trailer tires....
by kenwin30 - 09/15/19 10:03 PM
How do you and your S.O handle multiple cars?
by addyguy - 09/15/19 09:59 PM
RIP Ric Ocasek
by spasm3 - 09/15/19 09:51 PM
Attack on plant and wells in Saudi Arabia
by addyguy - 09/15/19 09:09 PM
dnauhei, Jenworman, David_Mason, TurboVR6Junkie, Todd_S
69292 Registered Users
93 registered members (330indy, 2015_PSD, 53' Stude, 2011335d, 2004tdigls, 10 invisible), 1,885 guests, and 20 spiders.
Topics294,635
Posts5,063,507
Members69,292
Most Online3,532
Jul 30th, 2019
Page 2 of 2 1 2
Re: Maintenance Additive for Poor/Non-Top Tier Fuel? [Re: Gixxer46] #4894392 10/12/18 02:12 AM
M
MichaelCT Offline OP
M
Originally Posted by Gixxer46
You spray it through the throttle body so it will clean manifold along the way.
I compared it to Seafoam and found Seafoam didn’t do much in my manifold.
We don’t get amsoil power foam in Canada.
Seafoam didn't clean my manifold too (there were some other cleaning effects, just not the manifold for sure), after two uses and reading on the forum, seems like it's out dated compared to the others.
Seafoam and CRC costs way more than Amsoil, Redline, and Techron where I am located so I will be trying Amsoil Power Foam next time around (the later three has official distributors and prices are comparable to U.S. retail prices, Seafoam and CRC costs twice as much).
Re: Maintenance Additive for Poor/Non-Top Tier Fuel? [Re: Gixxer46] #4894512 10/12/18 08:56 AM
StevieC Offline
I know it sucks... I have to buy it south of the border when I'm visiting my brother or friends and have it shipped there while I'm there. Good news is my PC membership works on both sides of the border! thumbsup
'18 Caravan - 42k KM - AMSOIL SS 0w20, Fram Ultra, TC-W3 500:1
'06 Santa Fe - 535k KM (Retired)
There is no such thing as "lifetime" fluids! mad
Re: Maintenance Additive for Poor/Non-Top Tier Fuel? [Re: JustN89] #4894546 10/12/18 09:42 AM
W
wag123 Offline
W
Originally Posted by JustN89
I've used Chevron Techron and Redline SI-1 and have no complaints. Recently, I've started adding a 1:500 mix of TC-W3 to my fuel in lieu of other additives in hopes to achieve similar effects at a cheaper price. So far, so good with the TC-W3.
+1 on the TC-W3.
In addition, if you want to make non top-tier gas into top-tier gas, just add a smaller amount of Techron to each tankfull of fuel, 1 oz of Techron concentrate per 5 gal of gas (the same as the recommended TC-W3 dose) should do the trick, and you can certainly use both. If you are going to use TC-W3, you don't need to buy the expensive synthetic, the cheap dino TC-W3 oil works just as well (maybe better). TC-W3 also helps to lubricate the fuel pump, fuel injectors, and intake valve stems.
Re: Maintenance Additive for Poor/Non-Top Tier Fuel? [Re: wag123] #4902314 10/21/18 07:17 PM
M
M
+1 on the TC-W3.
Okay I started using Quicksilver TC-W3 at 1:500 ratio and it seems I am having a little bit hesitation most likely due to reduced octane? The local gas is kinda low on octane and I wonder if the added TC-W3 brought it down to a level where the sensors would retard timing.
Are you guys using it in premium gas only cars or regular gas cars? I did see that the very original post started in corvettes which I recall runs on regular gas?
Anyway I will reduce the concentration back down a little but I wonder if TC-W3 works well with premium gas only cars.
Re: Maintenance Additive for Poor/Non-Top Tier Fuel? [Re: MichaelCT] #4902579 10/22/18 01:57 AM
W
wag123 Offline
W
The TC-W3 is not going to affect the octane at ANY concentration. The vehicles I am using it in are running 87 octane regular E10 gas.
Page 2 of 2 1 2
