Pennzoil GF-6 & Low Viscosity Q&A
Click here to participate in the Pennzoil Q&A
Where automatic grade logic is a total fail.
by pezzy669. 06/26/19 10:53 PM
Help please! Possible chemical etch windshield
by NeedAdviceASAP. 06/26/19 10:40 PM
Insect / Ant Killer
by Warstud. 06/26/19 07:55 PM
120k Transmission - Flush or Drain
by Soflonole27. 06/26/19 07:53 PM
VOA - HCF-2, Eneos Import CVT Model H, Eneos ECO CVT
by Stucker21trt. 06/26/19 06:48 PM
2012 Mazda3 iTouring
by Kira. 06/26/19 06:46 PM
Blazer Chalet
by dishdude. 06/26/19 06:27 PM
So confused about Hemi oil
by TN Tracker. 06/26/19 06:20 PM
Gabby Chaves’ mobile oil change business
by Pat in Speedway. 06/26/19 06:03 PM
PUP 5w-30 - 2016 GS F - 5,051 miles
by Tiir. 06/26/19 05:41 PM
I-CAR Gold Class Car Wash...
by Vern_in_IL. 06/26/19 05:36 PM
Kia manual allows 5w20 and 5w30 but not 0w20?
by Whammo. 06/26/19 05:31 PM
Buy A Car...Get Freebies
by GrtArtiste. 06/26/19 05:09 PM
by Stucker21trt. 06/26/19 04:31 PM
Radar Dimax AS-8 Diamond in rough
by spiderbypass. 06/26/19 04:06 PM
icy hot additive for oils
by 1978elcamino. 06/26/19 03:33 PM
Why does diesel stink so much less than gas?
by atikovi. 06/26/19 02:29 PM
Chrisemme1, NeedAdviceASAP, Yuleeboy, Soflonole27, Bungalowbill
68504 Registered Users
30 registered members (ctechbob, carlprop, 928, Deontologist, BlakeB, 2105stgvh, 3 invisible), 850 guests, and 23 spiders.
Topics291,017
Posts4,997,186
Members68,504
Most Online2,967
Mar 10th, 2019
[cut open] Allison 29539579 spin-on filter for 1000 series trans in Duramax #4889368
10/06/18 04:05 PM
10/06/18 04:05 PM
Naperville, IL
wwillson Offline OP
Administrator
wwillson  Offline OP
Administrator
Naperville, IL
This filter is from my 2018 Duramax. This is the original spin-on filter with a total of 8,000 miles. There is a small amount of metal flakes in the filter and only enough clutch friction material to discolor the media. I see no reason to change this filter more often than 25,000 miles. The magnet that mounts between the filter and trans body had a small amount of dark material stuck to it - probably a couple grams.
Re: [cut open] Allison 29539579 spin-on filter for 1000 series trans in Duramax [Re: wwillson] #4889384
10/06/18 04:25 PM
10/06/18 04:25 PM
Tri State Conservative
Zee09 Offline
Zee09  Offline
Yeah looks like a long term filter.
"If I walked on water, they'd say I couldn't swim."
Re: [cut open] Allison 29539579 spin-on filter for 1000 series trans in Duramax [Re: wwillson] #4889462
10/06/18 06:49 PM
10/06/18 06:49 PM
Fort Lauderdale, FL
DoubleWasp Offline
DoubleWasp  Offline
Fort Lauderdale, FL
My understanding is that most transmission spin-on filters by the OEM are still rock catchers. Better rock catchers than the pan filters, but still around 60-80 microns. That's why I replaced mine with an XG7317.
Re: [cut open] Allison 29539579 spin-on filter for 1000 series trans in Duramax [Re: wwillson] #4889558
10/06/18 09:10 PM
10/06/18 09:10 PM
Cloquet Mn.
bobbobtar Offline
bobbobtar  Offline
Cloquet Mn.
When I had a 2009 Chevy Duramax with the Allison 1000 transmission I would change the trans. filer every oil change about 10,000 miles cheap insurance.
2017 Toyota Highlander
2018 John Deere 2032R
2014 CanAm Spyder
1981 Chevy Malibu 355cu 425hp
Re: [cut open] Allison 29539579 spin-on filter for 1000 series trans in Duramax [Re: wwillson] #4889632
10/06/18 11:34 PM
10/06/18 11:34 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Originally Posted by wwillson
I see no reason to change this filter more often than 25,000 50,000-75,000 miles. The magnet that mounts between the filter and trans body had a small amount of dark material stuck to it - probably a couple milligrams grams
There, I fixed all of that for you.
Re: [cut open] Allison 29539579 spin-on filter for 1000 series trans in Duramax [Re: wwillson] #4893078
10/10/18 03:22 PM
10/10/18 03:22 PM
Southeast
BlakeB Online content
BlakeB  Online Content
Southeast
I changed the spin-on trans filter on my Dads 2016 LML at 31k with 2073 hours. The magnet had some fuzz on it, but nothing excessive. I haven’t cut the filter open yet, but if I do I’ll post pics.
I checked on Allison’s site and this is what the fluid and filter calculator gave me:
Re: [cut open] Allison 29539579 spin-on filter for 1000 series trans in Duramax [Re: wwillson] #4893366
10/10/18 08:28 PM
10/10/18 08:28 PM
Naperville, IL
wwillson Offline OP
Administrator
wwillson  Offline OP
Administrator
Naperville, IL
Re: [cut open] Allison 29539579 spin-on filter for 1000 series trans in Duramax [Re: wwillson] #4893373
10/10/18 08:33 PM
10/10/18 08:33 PM
Southeast
Southeast
How many hours on your L5P?
Re: [cut open] Allison 29539579 spin-on filter for 1000 series trans in Duramax [Re: wwillson] #4893378
10/10/18 08:35 PM
10/10/18 08:35 PM
Naperville, IL
wwillson Offline OP
Administrator
wwillson  Offline OP
Administrator
Naperville, IL
190 hrs
Re: [cut open] Allison 29539579 spin-on filter for 1000 series trans in Duramax [Re: DoubleWasp] #4900743
10/19/18 10:33 PM
10/19/18 10:33 PM
Maricopa Arizona
dave1251 Offline
dave1251  Offline
Maricopa Arizona
And yet what is percentage of failed transmissions? Not very high.
don't use.
