Cancelling a Leased Solar Panel System
by The Critic - 08/26/19 12:32 AM
Mounting Used Tires
by Nick1994 - 08/25/19 11:49 PM
I am not a robot popup?
by irv - 08/25/19 11:24 PM
2019 Lexus RX350 review
by mclasser - 08/25/19 11:08 PM
Which Anti-Freeze for a 2007 Nissan Maxima?
by mtgrs737 - 08/25/19 11:03 PM
My oil test.
by OilUzer - 08/25/19 10:00 PM
2018 Kia Forte - low compression on 2 cyliners
by mrdctaylor - 08/25/19 09:10 PM
What can this stuff be used in?
by leeaspell - 08/25/19 07:38 PM
Recycled motor oil end users
by Electromotive - 08/25/19 07:20 PM
GE Caulk Is Useless
by Warstud - 08/25/19 06:53 PM
2005 Ford Ranger extended cab FX4
by Kira - 08/25/19 06:46 PM
Pennzoil Start/Stop Protection 0W-20
by The Critic - 08/25/19 06:35 PM
Daughter just bought 2015 Kia Forte5
by cb450sc - 08/25/19 06:32 PM
So terrible you can't help but be impressed
by cwilliamsws6 - 08/25/19 06:09 PM
Bent wheel...
by NoNameJoe - 08/25/19 06:06 PM
Mobil 1 OW-40 euro $22.99 at Meijer.
by driver123 - 08/25/19 05:59 PM
Toilet flange problem
by dja4260 - 08/25/19 05:52 PM
DrySumpMidget31, Matildasky, DenF, venom7107, Ryan_lml
69062 Registered Users
23 registered members (dishdude, 4WD, clinebarger, aleneros, Duke, Char Baby, 2 invisible), 654 guests, and 20 spiders.
Topics293,808
Posts5,047,092
Members69,062
Most Online3,532
Jul 30th, 2019
[cut open] Allison 29539579 spin-on filter for 1000 series trans in Duramax #4889368 10/06/18 04:05 PM
wwillson Offline OP
Administrator
Administrator
This filter is from my 2018 Duramax. This is the original spin-on filter with a total of 8,000 miles. There is a small amount of metal flakes in the filter and only enough clutch friction material to discolor the media. I see no reason to change this filter more often than 25,000 miles. The magnet that mounts between the filter and trans body had a small amount of dark material stuck to it - probably a couple grams.
Re: [cut open] Allison 29539579 spin-on filter for 1000 series trans in Duramax [Re: wwillson] #4889384 10/06/18 04:25 PM
Zee09 Offline
Yeah looks like a long term filter.
"If I walked on water, they'd say I couldn't swim."
Re: [cut open] Allison 29539579 spin-on filter for 1000 series trans in Duramax [Re: wwillson] #4889462 10/06/18 06:49 PM
DoubleWasp Offline
My understanding is that most transmission spin-on filters by the OEM are still rock catchers. Better rock catchers than the pan filters, but still around 60-80 microns. That's why I replaced mine with an XG7317.
Re: [cut open] Allison 29539579 spin-on filter for 1000 series trans in Duramax [Re: wwillson] #4889558 10/06/18 09:10 PM
B
bobbobtar Offline
B
When I had a 2009 Chevy Duramax with the Allison 1000 transmission I would change the trans. filer every oil change about 10,000 miles cheap insurance.
2017 Toyota Highlander
2018 John Deere 2032R
2014 CanAm Spyder
1981 Chevy Malibu 355cu 425hp
Re: [cut open] Allison 29539579 spin-on filter for 1000 series trans in Duramax [Re: wwillson] #4889632 10/06/18 11:34 PM
L
Linctex Offline
L
Originally Posted by wwillson
I see no reason to change this filter more often than 25,000 50,000-75,000 miles. The magnet that mounts between the filter and trans body had a small amount of dark material stuck to it - probably a couple milligrams grams
There, I fixed all of that for you.
Re: [cut open] Allison 29539579 spin-on filter for 1000 series trans in Duramax [Re: wwillson] #4893078 10/10/18 03:22 PM
B
BlakeB Offline
B
I changed the spin-on trans filter on my Dads 2016 LML at 31k with 2073 hours. The magnet had some fuzz on it, but nothing excessive. I haven’t cut the filter open yet, but if I do I’ll post pics.
I checked on Allison’s site and this is what the fluid and filter calculator gave me:
Re: [cut open] Allison 29539579 spin-on filter for 1000 series trans in Duramax [Re: wwillson] #4893366 10/10/18 08:28 PM
wwillson Offline OP
Administrator
Administrator
Re: [cut open] Allison 29539579 spin-on filter for 1000 series trans in Duramax [Re: wwillson] #4893373 10/10/18 08:33 PM
B
BlakeB Offline
B
How many hours on your L5P?
Re: [cut open] Allison 29539579 spin-on filter for 1000 series trans in Duramax [Re: wwillson] #4893378 10/10/18 08:35 PM
wwillson Offline OP
Administrator
Administrator
190 hrs
Re: [cut open] Allison 29539579 spin-on filter for 1000 series trans in Duramax [Re: DoubleWasp] #4900743 10/19/18 10:33 PM
dave1251 Offline
And yet what is percentage of failed transmissions? Not very high.
don't use.
