Auto insurance rate cut
by Wolf359 - 04/08/20 02:18 PM
Do you "correct" your service technician or not?
by SevenBizzos - 04/08/20 02:07 PM
How to keep glasses from fogging up?
by Chris142 - 04/08/20 01:58 PM
1.6 EB ,RL 5w20,18175 miles OCI,TAN>TBN
by ovidiu - 04/08/20 01:02 PM
cut ADBV in Mobil1 oil filter
by RavenTai - 04/08/20 12:55 PM
Oil shopping USA vs France
by M119 - 04/08/20 11:50 AM
Blackstone labs... open??
by researcher - 04/08/20 11:41 AM
Hyundai 2.4 Engine Issues
by Hallj49803 - 04/08/20 11:36 AM
Do old style centrifugal filters do anything?
by atikovi - 04/08/20 11:34 AM
NAPA oil deals
by Oildudeny - 04/08/20 11:17 AM
Oil weight spec thinning over time?
by MontePrix28 - 04/08/20 10:12 AM
High Performance Lubricants PDS
by High Performance Lubricants - 04/08/20 10:11 AM
13 Hyundai Sonata 24 vs 12 Jetta 2.0 TDI
by Hallj49803 - 04/08/20 10:09 AM
Mustang 4.6L spark plug change
by kstanf150 - 04/08/20 10:03 AM
Cutting Cable-Roku?
by PontiacHO - 04/08/20 09:59 AM
Mor gas price fun.
by Chris142 - 04/08/20 09:42 AM
Instagram
by Al - 04/08/20 09:03 AM
Super Moon Photos
by Snagglefoot - 04/08/20 07:30 AM
LMVLS1, Jotorobi, jhoffy22, EcoBoosted, mmich187
71126 Registered Users
87 registered members (53' Stude, 77GrandPrix, A310, 07titan, 94astro, 2004tdigls, 9 invisible), 2,215 guests, and 16 spiders.
Topics303,773
Posts5,241,651
Members71,126
Page 2 of 2 1 2
Re: Coolant change time or mileage [Re: kschachn] #4883370 09/29/18 10:48 PM
O
Onetor Offline
O
Originally Posted by kschachn
Originally Posted by Onetor
Don't forget that coolant also lubricates the Water Pump etc. So the additives need to be replenished, etc. I agree about the heat being detrimental!
Which parts are lubricated by the coolant? The water pump bearings are actually protected from the coolant by seals. Once the seal deteriorates and is breached by the coolant the bearings will destruct in short order.
I stand corrected. Ty
N = R* x fp x ne x fl x fi x fc x L
Re: Coolant change time or mileage [Re: motor_oil_madman] #4884647 10/01/18 03:01 PM
StevieC Offline
I do radiator spill/fill's at 1/2 the allowable intervals that way the coolant in the system is always fresh all the time and there is no need for flush/fill. I have driven all my vehicles to their junk points with original water pumps and radiators.
'18 Caravan - 50k KM - AMSOIL SS 0w20, Fram Ultra, TC-W3 500:1
'06 Santa Fe - 535k KM (Retired)
There is no such thing as "lifetime" fluids! mad
Re: Coolant change time or mileage [Re: motor_oil_madman] #4891612 10/09/18 07:01 AM
M
mcrn Offline
M
I just went 6 yrs on my nissan with 75k miles....makes me feel bad I waited a yr too long,
2012 Nissan Rogue
Re: Coolant change time or mileage [Re: motor_oil_madman] #4908908 10/29/18 04:39 AM
demarpaint Offline
I go by time for the coolant. I'd never hit the mileage stated in the owners manual vs. the time in use for the coolant.
God Bless Our Troops
Re: Coolant change time or mileage [Re: motor_oil_madman] #5007523 02/11/19 12:05 AM
K
KevinP Offline
K
There are two concerns, coolant degradation as it acidifies with age, and inhibitor package depletion.
You can check how the glycol is aging with a pH meter (strips won't give you enough resolution). You should make sure your pH meter is calibrated against pH buffer standards because the probes quickly drift out of calibration, especially when they are not stored correctly. The pH should be around 8.0 in a healthy glycol solution for automotive use. And yes.... it ages quicker with heat. The degradation is a chemical reaction and ethylene glycol primarily degrades into glycolic acid (some oxalic, some formic) and all chemical reactions proceed quicker with energy input. Thus ethylene degrades into the acids quicker at higher temps than it would at lower.
I've also seen studies that show inhibitor degradation over time. The azoles, in particular, drop with time. I'm not sure of the mechanism whether it is bonded to copper/brass as the inhibiting layer or if it is lost in the non-sealed system. Either way, you could just start at a higher level. The assumption is that it will be run at 50/50 so run it at 65/35 so you have more to start with.
It is so cheap to dump it on a regular basis that I err on the side of caution.
Re: Coolant change time or mileage [Re: motor_oil_madman] #5130985 06/11/19 01:50 AM
T
tiger862 Offline
T
Thermostat and coolant every 5 years. Gives system a good drain and when bleeding the system out less chance of thermostat getting stuck.
Tiger862
2018 Grand Caravan
Page 2 of 2 1 2
