Fuchs Titan GT1 Evo 0w20 LL014FE
by kr_bitog - 02/20/20 05:46 AM
Tungsten Ravenol
by V10 - 02/20/20 01:37 AM
Can an SSD make this much difference?
by 14Accent - 02/20/20 01:14 AM
The Big Oil Change - Sinclair Oil 1960's
by StevieC - 02/19/20 10:47 PM
A new topper for my truck
by HM12460 - 02/19/20 10:12 PM
AAP/Carquest platinum pads/rotors
by parshisa - 02/19/20 10:03 PM
Apple watch - high data usage
by Quattro Pete - 02/19/20 09:46 PM
Gas in the 80's vs Today
by alcyon - 02/19/20 09:34 PM
1993 Hilux 3.0 diesel
by Mayberryminitruc - 02/19/20 08:58 PM
WrightGrip 2.0 wrench set
by spasm3 - 02/19/20 08:57 PM
Don't forget about your clutch fluid
by Number_35 - 02/19/20 08:40 PM
Financial Advice
by cpayne5 - 02/19/20 08:28 PM
2003 Accord 6 Cylinder EX No start
by Gito - 02/19/20 08:03 PM
Oil Advice For 1990s Era Yamaha ATVs
by DockHoliday - 02/19/20 07:42 PM
2 quarts supertech 0w-20 for $4.56
by sjstangman - 02/19/20 07:35 PM
1994 Buick Century 63K miles
by MuzzleFlash40 - 02/19/20 07:33 PM
Why is this plug so expensive?
by motor_oil_madman - 02/19/20 07:01 PM
Mice and rat deterrent
by whizbyu - 02/19/20 06:45 PM
Gen Outlets Not Working
by coopns - 02/19/20 06:24 PM
Mayberryminitruc, DaiwaGuy, Gunboatmac, Mad_Max_Sam, 24Carat
70756 Registered Users
66 registered members (2002 Maxima SE, Astro14, 65convertible, Avery4, airbusdrvr, asleepz, 7 invisible), 1,114 guests, and 18 spiders.
Topics301,689
Posts5,200,532
Members70,756
How to extract oil? #4884379 10/01/18 08:39 AM
Spetz Offline OP
Hi everyone,
I ordered a UOA kit that has a tube and a syringe to get the oil from the dipstick,
My questions are:
1. Does the oil need to be hot, engine running, engine just switched off, or cold is fine?
2. If the tube does not go down the dipstick what is another way I can get to the oil without draining it?
Can I remove the oil filter and extract some oil from there?
Or can I remove the oil cap and try to get some from the head?
3. The kit came with a 30cc syringe and a 100ml or so canister. Is 30cc enough for the lab or must I fill the canister?
2003 Mitsubishi Diamante 6G74. 165k miles.
Penrite HPR10 10W50, 12K km OCI
UOA:
https://www.bobistheoilguy.com/foru...ante-shu-5w40-1-2-can-mos2-7-8k-mile-oci
Re: How to extract oil? [Re: Spetz] #4884383 10/01/18 08:48 AM
JohnnyJohnson Offline
I would say it would be best to have just turned to engine off so things haven't settled out and are suspended in the oil.
2004 Corolla 138781
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 77060
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: How to extract oil? [Re: Spetz] #4884390 10/01/18 08:59 AM
B
BMWTurboDzl Offline
B
Engine warm not hot nor cold. Maybe sample an 30 mins or so after you've driven it. The idea is that any solids will remain uniformly distributed in the oil and not have settled at the bottom of the pan.
You could reach out to Blackstone Labs. They may have suggestions on how to sample.
435i
Re: How to extract oil? [Re: Spetz] #4884432 10/01/18 10:08 AM
StevieC Offline
When I do sampling and not complete changes at the time of a UOA collection, I like to make sure the vehicle has been run somewhere like shopping etc. I return home, let the vehicle cool a little and then I send the tube on my collection pump down the dipstick tube. I have found that lubricating the outside of the tube with clean engine oil makes it go down the tube much easier. I always dump the first bit of extracted oil back into the engine via the oil cap in case there was residuals in the tube/pump from the last extraction. Then on the second extraction I pump this into my bottle to be sent to the lab.
'18 Caravan - 50k KM - AMSOIL SS 0w20, Fram Ultra, TC-W3 500:1
'06 Santa Fe - 535k KM (Retired)
There is no such thing as "lifetime" fluids! mad
Re: How to extract oil? [Re: Spetz] #4884445 10/01/18 10:22 AM
A
ARCOgraphite Offline
A
Sounds like the plan! /\ /\ /\
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#8 60864mi-Subaru Idemitsu 0W20 + SOA Filter
Re: How to extract oil? [Re: Spetz] #4884704 10/01/18 03:33 PM
Danh Offline
Just one more small suggestion: Mark the extraction tubing at a point where it equals the length of the dipstick. This will ensure you extract oil from a good midpoint and don’t reach the bottom of the sump where crud could have settled and accumulated.
Re: How to extract oil? [Re: Spetz] #4884847 10/01/18 05:57 PM
I
Ihatetochangeoil Offline
I
Answer per Blackstone: https://www.blackstone-labs.com/gas-sampling.php Answer per me: I take my samples from a hot, running engine; but I have bypass filters with a sampling petcock; it's pretty easy and mess free. I wear leather TIG welding gloves in case of accidental contact with hot engine parts. To sample from my son's car, (no petcock), I remove the oil filler cap (with the hot motor idling) and carefully insert the sampling tube into a "puddle" of oil in a low area cast into the cylinder head; it may take several "draws" and a few minutes to get enough oil for the sample bottle.
2. If the tube does not go down the dipstick what is another way I can get to the oil without draining it? Answer per me: You can also loosen the oil filter a little and catch some oil, I've done this with a clean spare glass beaker and then poured it into the sampling bottle, but I would NOT attempt this on a running engine!!! I let the engine run long enough to reach equilibrium temperature; chock, jack and support the car, then shut the engine down and immediately get my sample. Job 1 is to be very cautious, be safe, don't get burned. A splash in the face with hot oil is not funny; I wear safety glasses, a full face polycarbonate grinding shield and a leather welding jacket. Never been burned and don't plan on it. Who does?
3. The kit came with a 30cc syringe and a 100ml or so canister. Is 30cc enough for the lab or must I fill the canister? Answer: Blackstone says they need 3 oz; which works out to about 90 ml. https://www.conversion-metric.org/volume/ounce-to-milliliter
Re: How to extract oil? [Re: Spetz] #4884880 10/01/18 06:29 PM
4WD Offline
For large industrial engines the sump is a no-no and samples are taken from the cooler loop (sample valve) …
Re: How to extract oil? [Re: Spetz] #4927464 11/18/18 07:49 AM
J
jorton Offline
J
Do you think I can get a sample from the dipstick tube on a CVT? I think the tube makes a right angled turn at the attachment to the transmission.
"If everything seems under control, you're just not going fast enough."
- Mario Andretti
