Cavitation around the water pump has always been something I knew was "a thing", but i'd never seen it affect anyone's engine i'd ever worked on. Well now I can say I have seen its effects for real, and it was in my own engine as it so happens.
The engine is a 2012 5.7L Hemi in the Charger in my signature. The coolant was apparently the factory fill, and that is the main culprit to why the cavitation started to occur I believe.
There were no other symptoms to indicate an issue was occurring. I just happened to find this when replacing the water pump and other coolant system parts as part of the engine's maintenance services.
