Barrett Jackson 2019 Pics
by Nick1994. 01/19/19 05:41 PM
What do y'all do with old car parts?
by qdeezie. 01/19/19 05:11 PM
Diagnosing catalytic converters.
by Tlhfirelion. 01/19/19 04:20 PM
Oil recommendations for GM Vortec 8100
by Dudemanmaximus. 01/19/19 04:14 PM
Leaf Spring Questions- Lots of Questions
by George7941. 01/19/19 04:02 PM
Am I being out of line?
by Chris142. 01/19/19 04:00 PM
Some good modern rock songs
by 53' Stude. 01/19/19 03:51 PM
06 Pathfinder O2 sensor voltage sensor 1
by Bluestream. 01/19/19 03:50 PM
Honda Blue Coolants
by redhat. 01/19/19 03:49 PM
Let's talk about some of the other NHL teams
by 53' Stude. 01/19/19 03:45 PM
coolants for 1965 imperial
by ted s. 01/19/19 03:35 PM
Where to get real Dexron III ?
by das_peikko. 01/19/19 02:40 PM
Dexcool + Prestone AMAM Mix
by George7941. 01/19/19 02:31 PM
Questions about Maverik gas
by MRtv. 01/19/19 01:25 PM
Anyone Taking Superfoods ?
by Warstud. 01/19/19 12:55 PM
Permatex High Tack (80062)
by TheLawnRanger. 01/19/19 12:29 PM
A little warm down in Oz.
by Snagglefoot. 01/19/19 12:03 PM
Supertech 6607 - 7300 miles - 2017 Legacy
by MrWideTires. 01/19/19 10:21 AM
One Of The Best F-16 Performances
by billt460. 01/19/19 09:52 AM
ejmiller, _THOR_, Captmorgan2112, TreadMonster, Snachlift500
66978 Registered Users
118 registered members (53' Stude, 4WD, 2K2AcuraTL, 2004tdigls, 69GTX, 17 invisible), 1,995 guests, and 36 spiders.
Topics296,849
Posts4,960,080
Members66,978
Most Online2,688
Jan 19th, 2019
Page 2 of 4 1 2 3 4
Re: Liqui Moly Oil Additive [Re: 1JZ_E46] #4875525
09/21/18 11:58 PM
09/21/18 11:58 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
Originally Posted by 1JZ_E46
LM MoS2 will settle out of suspension as it’s not in a true liquid soluble form. I looked into it but decided against it after hearing advice from people far smarter and more knowledgeable on the subject.
I have heard this as well.
Where does it go to?!?!?
Trapped in all the little pockets where sludge usually forms?
Or does it get stuck in the pleats of the oil filter and stay there?
Re: Liqui Moly Oil Additive [Re: dawgn86] #4875527
09/22/18 12:06 AM
09/22/18 12:06 AM
'Stralia
Shannow Online content
Shannow  Online Content
'Stralia
Yes,
the little jars that I mixed for my freezer tests I left sit for a few months.
The oil drained out, and the molly stayed in the bottom, and couldn't be flushed out with detergent and hot water. Had to be scraped out, just like sludge
The Dunning Kruger effect is real.
The Galileo Fallacy is real.
Roll them into one neat package and crackmeup crackmeup crackmeup
Re: Liqui Moly Oil Additive [Re: Shannow] #4875532
09/22/18 12:20 AM
09/22/18 12:20 AM
WA
OilUzer Offline
OilUzer  Offline
WA
Originally Posted by Shannow
Yes,
Does this also happen with oils with high amount of moly? I mean much higher than normal normal like tgmo 0Wx20 and my new favorite redline?
Re: Liqui Moly Oil Additive [Re: dawgn86] #4875542
09/22/18 01:06 AM
09/22/18 01:06 AM
'Stralia
'Stralia
I don't think so.
The MoS2 is a mineral form, like graphite, not oil soluble like MoDTC.
(e.g. Zinc oxide versus ZDDP when you get it on your fingers)
Re: Liqui Moly Oil Additive [Re: dawgn86] #4875546
09/22/18 01:49 AM
09/22/18 01:49 AM
California
CleverUserName Offline
California
I can say that I have added LM 2009 it to oil (LM 4200) before. 200 ML of additive equaled ~ 230 ppm of MoS2 in my oil analysis. LM 4200 does not contain any MoS2 so it all came from the can of 2009.
It did not settle out and I collected the sample from an oil extractor about half-way through the suction time
Re: Liqui Moly Oil Additive [Re: dawgn86] #4875633
09/22/18 06:56 AM
09/22/18 06:56 AM
Canada
Gixxer46 Offline
Gixxer46  Offline
Canada
Never used it but redline 5w-20 or 30 gets rid of hemi tick
2013 Ram 1500 with a 4.7.
I use 0W-20 year round. I alternate between RP and Amsoil Signature series.
Re: Liqui Moly Oil Additive [Re: dawgn86] #4875774
09/22/18 09:49 AM
09/22/18 09:49 AM
Central Wisconsin
dwendt44 Offline
dwendt44  Offline
Central Wisconsin
How fast does it settle out?
If it takes weeks to settle to the bottom of the oil, I would think it
would stay suspended in the oil in a car/truck engine that is used or run
daily or several times a week.(me).
My 2¢
There's no such thing as:
Too big of a battery,
Too large of a gas tank,
or too loud of a horn,
or too bright headlights.
Re: Liqui Moly Oil Additive [Re: dawgn86] #4875800
09/22/18 10:31 AM
09/22/18 10:31 AM
Fredericksburg, VA
JAG Offline
JAG  Offline
Fredericksburg, VA
Insoluble MoS2 is inferior to soluble MoDTC (common) or MoDTP (uncommon). Paying for the former is folly. I wouldn’t even use it if it was free. If you want the good stuff, use an additive that has it or an oil that has a lot of it. This thread should be in the additive forum.
Re: Liqui Moly Oil Additive [Re: dawgn86] #4875809
09/22/18 10:48 AM
09/22/18 10:48 AM
PimTac Offline
PimTac  Offline
Didn’t BITOG member Trav discuss a experience with LM moly additive? It wasn’t positive.
Correct me if I am wrong.
Cannot see signatures any longer so it doesn’t matter.
Re: Liqui Moly Oil Additive [Re: dawgn86] #4875846
09/22/18 11:51 AM
09/22/18 11:51 AM
Fredericksburg, VA
JAG Offline
JAG  Offline
Fredericksburg, VA
You are correct, PimTac
Re: Liqui Moly Oil Additive [Re: Shannow] #4875851
09/22/18 11:59 AM
09/22/18 11:59 AM
Florida
hatt Online content
hatt  Online Content
Florida
Yes,
It mixes up pretty easy after sitting in the can.
2013 F150 5.0, PUP 10W-30, Wix 57502
2010 Camry 2.5, GTX 5W-20, Fram Ultra XG9972
Re: Liqui Moly Oil Additive [Re: dawgn86] #4875983
09/22/18 03:15 PM
09/22/18 03:15 PM
Central US
bobdoo Offline
bobdoo  Offline
Central US
I use Mos2 in a CX-5 driven short trips, one a week, or less. My UOA showed high levels of moly suspended in the old oil. I posted the UOA here a while back.
Re: Liqui Moly Oil Additive [Re: dawgn86] #4876306
09/22/18 09:10 PM
09/22/18 09:10 PM
WA
OilUzer Offline
OilUzer  Offline
WA
Do you guys know what is in Rislone oil treatment/additive?
STP oil treatment says it has zddp on the bottle ... but Rislone doesn't specify and I wonder if it has moly or not. It is very popular with good reviews. Just curious what's in it crzy
I do like Red Line numbers ... Very solid oil!
Re: Liqui Moly Oil Additive [Re: dawgn86] #4876329
09/22/18 09:49 PM
09/22/18 09:49 PM
Maricopa, Arizona
dave1251 Offline
dave1251  Offline
Maricopa, Arizona
You can try Castrol magatec of you like. The theory being there is quite a bit of ester and it should work to deaden the sound. The other theory is the oil is too thick upon startup thus once the oil thins the tick goes away.
don't use.
Re: Liqui Moly Oil Additive [Re: dawgn86] #4878771
09/25/18 12:13 PM
09/25/18 12:13 PM
Georgia
RDY4WAR Offline
RDY4WAR  Offline
Georgia
I live in Augusta, GA and just picked up 2 bottles of Lubro-Moly MoS2 at my local Napa a few weeks ago. I'm not sure if it helps. The oil turned a dull gray color though.
"He who is without oil, shall throw the first rod." - Compressions 9:1
Page 2 of 4 1 2 3 4
