Hey all
...this is my first post to a forum I've been reading for years now. One thing I learned about on bitog was the CAFE requirements...
In December I'll be getting a 19' Crosstrek with a 6 SPEED. Calls for 0w20...like most anything these days. I for one don't care to much for 20w oils as I do believe they favor mpg's over protection.
REDLINE'S RESPONSE - Thank you for contacting Red Line Oil, in your Crosstrek a 0W20 is recommended in the engine, likely primarily for the CAFÃ improvement and that would be our recommendation once the rings have seated. Using the lower viscosity oil wouldn't expect to cause harm or be detrimental to the engine, Subaru no doubt having done extensive evaluation. If you preferred a higher viscosity the 0W30 or 5W30 could be used.
I'm thinking REDLINE'S 0w30 would be a perfect match for my 4 season climate...Thoughts???
Also Am I choosing an overkill oil for a vehicle like this? Would a group 3 synthetic like Pennzoil UP be just as good?
