Just wondering, for a 2012 Camry 2.5 (2AR-FE), how long you all would run Mobil Super Synthetic 0w20. (The car has just 36,000 miles on it.)
Toyota says 10k miles on 'any' 0w20 but the "Maintenance Required" light comes on every 5k miles for an "inspection" and tire rotation.
Since I'm away at school, I have to get it changed someplace and the best-reviewed place I found uses Mobil Super 0w20 and Toyota filters (crush washers too), but recommends changing at 5k miles, "could stretch to 7500 at the most". I feel like that's pretty early, though Mobil Super's warranty is just 7500 miles, I believe. This place will do it for $48, most other reputable shops/dealers charge $60-90.
The car is driven in midwest weather, so extremes on both ends of the temperature spectrum. It gets a mix of city driving (but not many very short trips of less than 5-10 minutes), urban freeway driving trips of 15-25 minutes or so, and some interstate driving. I'd say it gets driven pretty normally, not overly gently or very aggressively either, though it does see some faster driving and higher engine speeds when merging. Basically, it spends most of its time at 2-2.5k rpm, but I'm not afraid to accelerate either. Probably 1000 miles a month or so, and about as variable trip-wise as possible.
So, would you run the Mobil Super Synthetic for 7500-8k miles? Or push it to the full 10k miles?
