Bleh, mother’s gas furnace fan burned up
by Rmay635703 - 01/17/20 11:23 PM
Rotella gas truck vs Valvoline modern engine
by MoPowa - 01/17/20 09:25 PM
Afton Specification Handbook -- September 2019
by Gokhan - 01/17/20 09:04 PM
Old Retired Navy Commander
by KeithS_NW_Ohio - 01/17/20 08:58 PM
Mobil 1 EP vs Mobil 1 EP Truck & SUV
by jrommelt - 01/17/20 08:29 PM
Stick with Maxlife or go back to DW-1?
by jayjr1105 - 01/17/20 07:58 PM
Thread locker
by zzyzzx - 01/17/20 07:56 PM
A preppers tale
by Bluestream - 01/17/20 07:50 PM
19 Ram Rebel oil choices
by Schwifty - 01/17/20 07:35 PM
Is it impossible to get a loan for an older vehicle?
by FordBroncoVWJeta - 01/17/20 07:22 PM
Fridge and freezer oil test
by jkhawaii - 01/17/20 06:59 PM
Not on sale but theeeeeeyyyyy're here!
by jayjr1105 - 01/17/20 06:47 PM
Valvoline Daily Protection 5w30 - $13.52 at Walmart
by RonRonnster - 01/17/20 06:39 PM
Gotta love Friday
by 53' Stude - 01/17/20 06:11 PM
It was 1911
by CourierDriver - 01/17/20 06:10 PM
Desulfating a Battery
by 5AcresAndAFool - 01/17/20 05:41 PM
weird deal alert: potassium permanganate
by GON - 01/17/20 04:42 PM
Kirkland Signature 0W-20 any good?
by CB22 - 01/17/20 04:31 PM
CPA1989, myisland, BuellRacer, devharryc, UncleNorby
70460 Registered Users
75 registered members (Astro14, 5AcresAndAFool, 2003f7, 2010Civic, 10 invisible), 1,492 guests, and 30 spiders.
Topics300,265
Posts5,171,946
Members70,460
Most Online3,728
Jan 11th, 2020
Gas water heater replacement #4861770 09/06/18 07:21 PM
K
kwijibo Offline OP
K
Looking to replace a 20 year old gas water heater built by Rheem. No problems with it at the moment but would like to replace it as a preventative measure before there is a sudden need. My son can get a small price break on a AO Smith or Bradford White. Any thoughts on either one? It seems to be all over the place when checking on the web no matter what the brand.
Re: Gas water heater replacement [Re: kwijibo] #4861775 09/06/18 07:29 PM
StevieC Offline
I have a Bradford White. Happy with it. It's been in place 5 years, it replaced a 10 year old GSW that was here when I bought the house.
I had a look at the rod and it was doing a good job sacrificing itself so I bought another to put in when this one is gone. I pre-filter my incoming water from sediment and chlorine before it hits the water heater. This will greatly extend the life and isn't expensive for replacement filters.
'18 Caravan - 48k KM - AMSOIL SS 0w20, Fram Ultra, TC-W3 500:1
'06 Santa Fe - 535k KM (Retired)
There is no such thing as "lifetime" fluids! mad
Re: Gas water heater replacement [Re: kwijibo] #4861786 09/06/18 07:41 PM
T
twouvakind Offline
T
Have you considered tankless? Our Takagi Jr. has long since paid for itself.
Just put the friggin' Maxlife in and be done with it!
Re: Gas water heater replacement [Re: kwijibo] #4861817 09/06/18 08:02 PM
G
Gebo Offline
G
I have AO Smith and my plumber told me they had switched to Bradford White. I'd get a Bradford Smith for that reason only.
'98 LEX LS400 305K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 70K
Shell Gas and Truck 5W-30
PP HM 10W-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Gas water heater replacement [Re: twouvakind] #4861823 09/06/18 08:08 PM
W
Wolf359 Offline
W
There's lots of problems with tankless. Usually the problem is that after 5-10 years, no one has the parts anymore and no one knows how to fix them. You also typically need a 3/4 gas line when most places around here just have 1/2 inch lines. And if you look at the fuel costs, gas hot water tanks don't actually use that gas, will take too long to recover you money over a tank unless you're getting a good rebate from your utility.
Re: Gas water heater replacement [Re: kwijibo] #4861826 09/06/18 08:10 PM
K
kwijibo Offline OP
K
I thought about tank less at one time but when I talked to a local plumber he said he would not install one. Expense to consumer is high, yearly maintenance on the unit, cold ground water in MN. etc...He has some good points, but he may just not want to install them.
Re: Gas water heater replacement [Re: Wolf359] #4861832 09/06/18 08:17 PM
Shannow Offline
Our old house we replaced the tank with tankless...gas line upgrade wasn't that hard (on THAT house, not on our current)...and it's far from "instant", taking many tens of seconds to get hot at the end, and thus that volume of wasted water.
New house, replaced tank with the biggest tank that fit in that spot. (then put up with all the armchair critics telling me what I SHOULD have done...but I'm happy with my choice)
Re: Gas water heater replacement [Re: kwijibo] #4861845 09/06/18 08:35 PM
I
irad Offline
I
You could replace the anode rod. Get a magnesium rod not Aluminum. $13 at supplyhouse .9 inch diameter. This will extend the life of the water heater.
Re: Gas water heater replacement [Re: kwijibo] #4861855 09/06/18 08:46 PM
J
JTK Offline
J
I've seen various flavors of store bought US Craftmaster water heaters go 20yrs+ and professionally installed AO Smith's rust through in 6-8yrs. You really never know with these things. I guess if you're not installing it yourself anyway, go with what your pro recommends.
Aside from swapping the anodes with something good, the best thing you can do to flush them is yank out the horrible nylon needle valve the heaters come with and replace it with a 3/4" ball valve.
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
Re: Gas water heater replacement [Re: kwijibo] #4861926 09/06/18 10:37 PM
W
Wolf359 Offline
W
Oh yeah, I normally get this 4 pack, but if you just need one, maybe getting it on Amazon might be cheaper.
https://www.comfortgurus.com/water-heater-parts/7434-rhe-sp11526c-4-pk.html
Also if you look at the energy guide of a 40 gallon tank vs tankless, they're basically the same. Plus if you change the anode rod, you can get them to last 20 years or more on a hot water tank. Most tankless systems only have a 5-10 year warranty and that's only for parts, not labor. Good luck finding a plumber who knows how to service them. A hot water tank is pretty simple, either the thermocouple goes, the temperature control/probe, dip tube, or the burner assemble, all somewhat easy to replace and simple for most plumbers. You can easily also get a 12 year hot water tank, they basically have an extra anode rod, but they also cover labor for a longer period than a 6 year one.
Re: Gas water heater replacement [Re: kwijibo] #4861934 09/06/18 10:47 PM
R
rubberchicken Offline
R
I have had 2 Bosch Tankless water heaters- my house runs on propane. The first Bosch unit was a 250sx , and it was a real pos. Non stop headaches, but I was too cheap to replace it. It had to be reset twice a day, endless calls to Bosch for tech support and was never able to get it working perfectly, but it "mostly" worked, so I suffered along with it for 10 years. Eventually I spoke to somebody at a big tankless dealer and mentioned what I currently had, and he immediately mentioned 2-3 problems with it and pronounced it a POS without any prompting from me. After a long conversation he said "the newer Bosch units are far superior, the factory has far better QA" yada yada, so I replaced it with a Bosch Integra 500. A big selling point for me is that it was a plug and play install. He had the 2 other popular brands as well and could easily have sold me those. The guy I spoke with really knew his stuff.
Well, he was 100% correct- the Bosch 250sx was a lemon model- my Integra 500 worked the very first time, no adjustment needed, and has been flawless in the 2 years since I installed it. Pros: endless hot water, smaller space requirement, significant energy savings. Cons: higher price, higher install cost. I did my own installation which was typical plumbing work, but I had to cut a 4 " hole in brick for the exhaust which was a daunting task until I found you can rent equipment to do that job.
Re: Gas water heater replacement [Re: kwijibo] #4861954 09/07/18 12:04 AM
Carmudgeon Offline
Last time I replaced a water heater, I did the rounds at some plumbing forums and ended up with a Bradford-White.
Their FVIR system was simpler, and didn't rely on a glass vial that breaks and renders the unit useless if it's tripped. Also standard brass drain valve, not the plastic junk found on store bought units. Made in Michigan, not hecho en Mexico, if that kind of thing matters to you.
All stuff that added up on paper, and the unit has been fine, in however many years (5+?) it's been in service.
B-W only sells through distributors to installers though, but I'm sure a plumbing house would be happy to sell to anyone for self-install. Not sure how that would affect warranty coverage, though.
Water quality is a big factor in how long they last. With good water, I've seen them last 20 years or more, even with neglected maintenance (sediment drain and anode replacement).
Re: Gas water heater replacement [Re: kwijibo] #4862041 09/07/18 05:49 AM
skyactiv Offline
I'd get a Bradford White myself which is made in Indiana I think.
Rheem is made in Mexico and is constructed cheap.
Years ago, a GF I was dating basement flooded. The flood broke the glass tube, shutting the air inlet and we couldn't relight the water heater. No one had the part locally.
I ended up sticking a socket in it to wedge it open and it worked. She had it fixed properly but it took a few weeks.
Sold: 13' VW GTI 3 door 6 speed manual
Me: 18' Elantra Sport 6 speed manual
Re: Gas water heater replacement [Re: kwijibo] #4862087 09/07/18 06:59 AM
Spector Offline
Had a NAvien tankless installed last year, primarily because my direct vent replacement was going to cost about the same as a tankless. Anyway, there is a cost savings however, if you pay someone to do the annual descaling you have lost any savings. I purchased a small sump pump and hoses and did it myself so in the future only the cost of vinegar. Yes the temp of the water intake has a bearing but it does on a tank too. I love it as to hot water and not running out, and would do it again, they have come a long way since the early models and will last beyond a typical hot water tank heater but you do need to descale them every year or so, again not a big job. Navien does not require a 3/4 inch line I believe. However, if you have a no direct vent now, regular heater the cost of a tankless will be much more. In my case there was less than a $500 difference. As mentioned by someone, the break even on a tankless is way too many years in the future and from that perspective not worth it. For lots of hot water, more space in the garage and if the cost is close to another replacement than it is an option.
Re: Gas water heater replacement [Re: kwijibo] #4862095 09/07/18 07:05 AM
G
Greggy_D Offline
G
We're on our second Bradford White Power vent. The first lasted 15 years and was replaced last year.
On my model, you have to remove the water supply lines to get to the anode rods. Just insane IMHO.
Greggy D.
