The gas will be fine. Rusty brake hardware and critters in your air filters are what you should worry about. As said previously, fuel systems are pretty well sealed against vapors getting in or out.
I'd keep the gas in there at about half full. If it spoils and it's full, then you have a full tank to deal with. If you have air space, you can perk up the remnants with some fresh high-test. Furthermore I'd use regular gas pre-storage as it's fresher due to distribution demand. If I get a little knock retard when I get the car back, hey, at least it runs, and the fuel hasn't turned to jelly.
