Post your latest oil change
2015 Altima 97,600 miles, Hertz rental purchase, 7K mile OCI
Out: 0w20 Valvoline HM Synthetic, K&N Pro Series filter
In: 0w20 SuperTech HM Synthetic, Purolater Synthetic filter (bigger Honda size I had sitting around)
Used the correct copper washer as the Toyota style fiber washer showed (minimal) sign of leakage; shoulda torqued it!
CVT fluid looks good; will service next time.
ST sure smoothed out that Nissan engine...
2011 Camry 55K miles, 2300 mile OCI, 15 months
Out: Valvoline 0w20 Synthetic, Toyota filter
In: Valvoline 0w20 Synthetic, Fram Synthetic filter
Replaced original battery
This is a neighbor's car; I service it for her.
Edna just turned 90 and is a great lady; used to do public relations for Chicago's Mayor Daly.
I think Toyota sez 10K or 1 year, right?
I would go 5k in this car. It may take 2 years but I would be fine with that. Yes, I know short trips galore, but I say at this point every 5k or 2 years is fine.
2005 Toyota Matrix - OCI 4.5 months and 6k miles
Out: Valvoline conventional 5w30 and Valvoline filter
In: Valvoline Conv. 5w30 and Valvo filter
Cost: Free received a coupon in the mail from the place I've been taking it to along with a tire rotation. Checked level afterwards and it was perfect. Guy worked on it for 45 mins and did a multi-point inspection.
Yes sir! But I went to a new Getgo cafe for coffee since I woke up early and a custard filled Krispy Kreme donut. Then to the diy car wash before going in for the oil change at 8 am. So no more coffee for me and a different guy was working the desk so the dog wasn't there. Shop was busy and the guy was telling people on the phone they were booked for the day. They open at 7:30 am on Saturday.
Good memory Adam!
Matt: always good to hear about a positive experience
2011 Ford Ranger 2.3 98,000 miles. 4 qts with filter
Out: Valvoline dino with WiX filter
In : M1 EP with Motorcraft filter
2017 Ford Explorer 3.5 V6 Duratec 21000 miles. 6qts with filteri
Out: Valvoline Synpower (5qts) & Valvoline Dino (1qt) with Motorcraft filter
The lady’s 2014 jeep wrangler
OCI ~5k miles
OUT:
Valvoline full syn w/maxlife 5w30
Denso FIrst time fit oil filter (it help up well)
IN:
Pennzoil Platinum Full syn 5w30
Premium Guard extended life filter
Last Friday
2002 F150 5.4
out: Mile-Syn 5w30 and Supertech ST2 (Wix)
In: Valvoline Durablend 10w30 and a new ST2
also changed the rear gear oil because I had to do Rear seals/bearings on it.
drained whatever was in it(looked pretty nasty), I don't think it was factory fill because its now has over 200k on it and the diff cover came off rather easy which usually doesn't happen with factory sealant. anyways I put back in it 2 quarts of Supertech 75w140 and the remaining amount put to make it full i used Valvoline 75w140 and also put in Champion Friction modifier for the limited slip.
1987 BMW 535is 256,161
5,153 on oil.
Out: Valvoline VR 20w50 and Mann filter.
In: 4qts of Pennzoil 20w50 and 2qts of Pennzoil Platinum HM 10w30 + Champ filter.
2004 Corolla 122537
Out: VML 5w-30 TG4967 117530 2-8-18 OCI 5007 miles
In: Castrol Extended Performance Bosch 3311 Premium 7-18-18
In: AUTO TECH engine Air filter.
